You can connect to your Apache Kyuubi data from Power BI via the high-performance Apache Kyuubi ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Apache Kyuubi
  • Working with Apache Kyuubi data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Kyuubi.
Download Apache Kyuubi JDBC driver
To connect to Apache Kyuubi, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Kyuubi website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Kyuubi\kyuubi-hive-jdbc-shaded-1.11.1.jar.
Create data source using Apache Kyuubi ODBC Driver
To get data from Apache Kyuubi using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Apache Kyuubi.
    Kyuubi connection
    Apache Kyuubi authentication
    Apache Kyuubi JDBC (shaded HiveServer2 client) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools. This tile is distinct from Apache Hive and Apache Spark: Kyuubi speaks jdbc:kyuubi:// on port 10009 by default and uses KyuubiHiveDriver.
    1. Note the Kyuubi server host and binary port (default 10009) and the default schema name.
    2. Create a Kyuubi / LDAP user if the server requires authentication. Lab clusters sometimes allow empty user and password.
    3. The wizard downloads kyuubi-hive-jdbc-shaded 1.11.1. Do not mix it with a standalone Hive JAR on the same DSN.
    4. After Finish, replace the host (e.g. MyHostName) and schema on the DSN Main UI.
    3. Finally, hit OK button:
    • Connection string: jdbc:kyuubi://[$HostName$]:[$Port$]/[$Database$]
    • Driver class: org.apache.kyuubi.jdbc.KyuubiHiveDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Kyuubi\kyuubi-hive-jdbc-shaded-1.11.1.jar
    • Host: MyHostName
    • TCP port: 10009
    • Database name: MyDatabase
    • User name:
    • Password:
    ApacheKyuubiDSN
    optional for Apache Kyuubi
    Find full details in the Apache Kyuubi Connector authentication reference.
    SSL / LDAP
    Kyuubi with SSL and user/password (LDAP-style). URL session vars use semicolons, same family as HiveServer2.
    1. Confirm TLS is enabled on the Kyuubi server and that you have an LDAP or custom user.
    2. This Auth sets ssl=true. Paste user and password. If the driver asks for a trust store password, set JVM truststore properties on the Bridge rather than putting a secret in XML.
    3. Keep this tile separate from Hive (port 10000, jdbc:hive2://) and Spark Thrift Server.
    4. After Finish, replace host, port, and schema.
    • Connection string: jdbc:kyuubi://[$HostName$]:[$Port$]/[$Database$];ssl=[$Ssl$]
    • Host: MyHostName
    • TCP port: 10009
    • SSL: true
    • User name:
    • Password:
    ApacheKyuubiDSN
    Jump to troubleshooter
    ApacheKyuubiDSN
    SHOW TABLES
    SHOW TABLES
Connect to Apache Kyuubi data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ApacheKyuubiDSN and continue:
    ApacheKyuubiDSN
    ApacheKyuubiDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Apache Kyuubi in a Power BI report:
If you wish to import Apache Kyuubi data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ApacheKyuubiDSN
SHOW TABLES
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Kyuubi ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ApacheKyuubiDSN"}
    dsn=ApacheKyuubiDSN
    dsn=ApacheKyuubiDSN
    = Odbc.Query("dsn=ApacheKyuubiDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Apache Kyuubi data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Apache Kyuubi Service
    SELECT * FROM OPENQUERY([LS_TO_APACHE_KYUUBI_IN_GATEWAY], 'SHOW TABLES')
    DirectQuery option for Power BI (read Apache Kyuubi data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Apache Kyuubi data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Apache Kyuubi
    Query Apache Kyuubi (HiveServer2-compatible) with JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ApacheKyuubiDSN
    ApacheKyuubiDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:kyuubi://[$HostName$]:[$Port$]/[$Database$]';ClassName='org.apache.kyuubi.jdbc.KyuubiHiveDriver';DriverPath='C:\ZappySys\Jdbc\Apache Kyuubi\kyuubi-hive-jdbc-shaded-1.11.1.jar';UserName='';UserPassword='';ConnParams='optional for Apache Kyuubi'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.kyuubi.jdbc.KyuubiHiveDriver):
  6. Go to the Libraries tab, click Add File, and select your Apache Kyuubi driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Kyuubi\kyuubi-hive-jdbc-shaded-1.11.1.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:kyuubi://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Kyuubi data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Kyuubi data source in the gateway
In this section we will create a data source for Apache Kyuubi in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheKyuubiDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Kyuubi ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ApacheKyuubiDSN
      ApacheKyuubiDSN
      ApacheKyuubiDSN
  5. Then set the default database property to ApacheKyuubiDSN (the one we used in the Data Gateway):
    ApacheKyuubiDSN
    ApacheKyuubiDSN
Finally, we are ready to read data from Apache Kyuubi in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Apache Kyuubi data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Kyuubi in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Kyuubi, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
