You can connect to your Apache Spark data from Power BI via the high-performance Apache Spark ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Apache Spark
- Working with Apache Spark data directly inside Power BI
Download Apache Spark JDBC driver
To connect to Apache Spark, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Apache Spark website or MVN Repository.
C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar.
Download the standalone Hive JDBC JAR so you do not have to assemble Hadoop dependencies, e.g. hive-jdbc-4.2.0-standalone.jar (commonly used to connect to Spark Thrift Server).
Create data source using Apache Spark ODBC Driver
To get data from Apache Spark using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Apache Spark.
Thrift Server
Apache Spark authentication
Spark Thrift Server from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Start Spark Thrift Server or note the existing host and HS2 port (default
10000). - Download the standalone Hive JDBC JAR (the wizard does this). Do not mix a partial Hadoop classpath.
- Create a user if the cluster uses auth; otherwise leave user/password empty.
- After Finish, replace the host (e.g. MyHostName) on the DSN Main UI.
Connection string :jdbc:hive2://[$HostName$]:[$Port$]/[$Database$] -
Driver class :org.apache.hive.jdbc.HiveDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar -
Host :MyHostName -
TCP port :10000 -
Database name :MyDatabase -
User name : -
Password :
ApacheSparkDSNjdbc:hive2://[$HostName$]:[$Port$]/[$Database$]org.apache.hive.jdbc.HiveDriverC:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jaroptional for Apache Spark
Find full details in the Apache Spark Connector authentication reference.Thrift Server (SSL)
Spark Thrift Server with SSL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Same as Default Auth, plus TLS. Fill LDAP/Hive user and password.
- Do not use a personal employee login for unattended Power BI or Linked Server refresh.
Connection string :jdbc:hive2://[$HostName$]:[$Port$]/[$Database$];ssl=[$Ssl$] -
Host :MyHostName -
TCP port :10000 -
SSL :true -
User name : -
Password :
ApacheSparkDSNjdbc:hive2://[$HostName$]:[$Port$]/[$Database$];ssl=[$Ssl$]org.apache.hive.jdbc.HiveDriverC:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jaroptional for Apache Spark
Find full details in the Apache Spark Connector authentication reference. -
ApacheSparkDSNSELECT id, name, salary FROM employees WHERE department = 'Sales';
SELECT id, name, salary FROM employees WHERE department = 'Sales';You can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Apache Spark data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ApacheSparkDSN and continue:
ApacheSparkDSN
ApacheSparkDSN
Finally, finally, read extracted data from Apache Spark in a Power BI report:
If you wish to import Apache Spark data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
id,
name,
salary
FROM employees
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Spark ODBC data source:
ODBC{"connectionstring":"dsn=ApacheSparkDSN"}
dsn=ApacheSparkDSN
dsn=ApacheSparkDSN
= Odbc.Query("dsn=ApacheSparkDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Apache Spark data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_APACHE_SPARK_IN_GATEWAY], 'SELECT id, name, salary FROM employees WHERE department = ''Sales'';')
SELECT * FROM OPENQUERY([LS_TO_APACHE_SPARK_IN_GATEWAY], 'SELECT id, name, salary FROM employees WHERE department = ''Sales'';') - Click OK and load the data. Your Apache Spark data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Apache SparkQuery Apache Spark Thrift Server (HiveServer2 protocol) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheSparkDSN
ApacheSparkDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]';ClassName='org.apache.hive.jdbc.HiveDriver';DriverPath='C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar';UserName='';UserPassword='';ConnParams='optional for Apache Spark'
Open DBeaver.
org.apache.hive.jdbc.HiveDriver):
Go to the Libraries tab, click Add File, and select your Apache Spark driver library file(s), e.g.
C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Apache Spark data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Spark data source in the gateway
In this section we will create a data source for Apache Spark in the Data Gateway. Let's follow these steps to accomplish that:
ApacheSparkDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Spark ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ApacheSparkDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Apache SparkQuery Apache Spark Thrift Server (HiveServer2 protocol) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheSparkDSN
ApacheSparkDSN(the one we used in the Data Gateway):ApacheSparkDSNApacheSparkDSN
Finally, we are ready to read data from Apache Spark in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Apache Spark data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Spark in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Spark, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
