You can connect to your JDBC data source data from Power BI via the high-performance JDBC-ODBC Bridge Driver. We'll walk you through the entire setup.
- Configuring a secure connection to JDBC data source
- Working with JDBC data source data directly inside Power BI
Download your Java application JDBC driver
To connect to your Java application, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit your Java application website or MVN Repository.
D:\Drivers\JDBC\app-jdbc.jar.
Create data source using JDBC-ODBC Bridge ODBC Driver
To get data from JDBC-ODBC Bridge using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in JDBC-ODBC Bridge.
MixedMode
JDBC-ODBC Bridge authentication
Connection string :jdbc:exampleApp://app-service-host-name.com:1234 -
Driver class :com.provider.exampleApp.jdbc.AppDriver -
JDBC driver file(s) :D:\Drivers\JDBC\app-jdbc.jar -
User name :admin -
User password :************* -
Connection parameters :[{"Name":"AppParameter","Value":"12345"}]
JdbcOdbcBridgeDSNjdbc:exampleApp://app-service-host-name.com:1234com.provider.exampleApp.jdbc.AppDriverD:\Drivers\JDBC\app-jdbc.jaradmin*************[{"Name":"AppParameter","Value":"12345"}]
Find full details in the JDBC-ODBC Bridge Connector authentication reference. -
JdbcOdbcBridgeDSNSELECT * FROM orders
SELECT * FROM ordersYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to JDBC-ODBC Bridge data in Power BI
Another window opens and asks to select a Data Source we already created. Choose JdbcOdbcBridgeDSN and continue:
JdbcOdbcBridgeDSN
JdbcOdbcBridgeDSN
Finally, finally, read extracted data from JDBC-ODBC Bridge in a Power BI report:
If you wish to import JDBC-ODBC Bridge data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local JDBC-ODBC Bridge ODBC data source:
ODBC{"connectionstring":"dsn=JdbcOdbcBridgeDSN"}
= Odbc.Query("dsn=JdbcOdbcBridgeDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports JDBC-ODBC Bridge data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_JDBC_ODBC_BRIDGE_IN_GATEWAY], 'SELECT * FROM orders')
SELECT * FROM OPENQUERY([LS_TO_JDBC_ODBC_BRIDGE_IN_GATEWAY], 'SELECT * FROM orders') - Click OK and load the data. Your JDBC-ODBC Bridge data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - JDBC-ODBC BridgeRead and write JDBC data effortlessly. Connect ODBC applications to Java-based services using standard JDBC drivers (.jar) for analytics, reporting, and data pipelines — almost no coding required.JdbcOdbcBridgeDSN
JdbcOdbcBridgeDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:exampleApp://app-service-host-name.com:1234';ClassName='com.provider.exampleApp.jdbc.AppDriver';DriverPath='D:\Drivers\JDBC\app-jdbc.jar';UserName='admin';UserPassword='*************';ConnParams='[{"Name":"AppParameter","Value":"12345"}]'
Open DBeaver.
com.provider.exampleApp.jdbc.AppDriver):
Go to the Libraries tab, click Add File, and select your JDBC-ODBC Bridge driver library file(s), e.g.
D:\Drivers\JDBC\app-jdbc.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:exampleApp://app-service-host-name.com:1234), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide JDBC-ODBC Bridge data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create JDBC-ODBC Bridge data source in the gateway
In this section we will create a data source for JDBC-ODBC Bridge in the Data Gateway. Let's follow these steps to accomplish that:
JdbcOdbcBridgeDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the JDBC-ODBC Bridge ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
JdbcOdbcBridgeDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - JDBC-ODBC BridgeRead and write JDBC data effortlessly. Connect ODBC applications to Java-based services using standard JDBC drivers (.jar) for analytics, reporting, and data pipelines — almost no coding required.JdbcOdbcBridgeDSN
JdbcOdbcBridgeDSN(the one we used in the Data Gateway):JdbcOdbcBridgeDSNJdbcOdbcBridgeDSN
Finally, we are ready to read data from JDBC-ODBC Bridge in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to JDBC-ODBC Bridge data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to JDBC-ODBC Bridge in Power BI and integrate your data — all without writing complex code. ZappySys JDBC Bridge Driver allows you to connect to any Java application that supports JDBC.
