You can connect to your MySQL data from Power BI via the high-performance MySQL ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to MySQL
- Working with MySQL data directly inside Power BI
Download MySQL JDBC driver
To connect to MySQL, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit MySQL website or MVN Repository.
C:\ZappySys\Jdbc\MySQL\mysql-connector-j-9.3.0.jar.
Create data source using MySQL ODBC Driver
To get data from MySQL using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in MySQL.
Standard connection
MySQL authentication
MySQL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Note the host, port (default
3306), and database name. - Create an application user (not a personal DBA login) with SELECT on the schemas you need.
- Paste user and password. After Finish, edit the host (e.g. MyHostName) and database (e.g. MyDatabase) on the DSN Main UI.
Connection string :jdbc:mysql://[$HostName$]:[$Port$]/[$Database$]?useOldAliasMetadataBehavior=true -
Driver class :com.mysql.cj.jdbc.Driver -
JDBC driver file(s) :C:\ZappySys\Jdbc\MySQL\mysql-connector-j-9.3.0.jar -
Host :MyHostName -
TCP port :3306 -
Database name :MyDatabase -
User name : -
Password :
MysqlDSNjdbc:mysql://[$HostName$]:[$Port$]/[$Database$]?useOldAliasMetadataBehavior=truecom.mysql.cj.jdbc.DriverC:\ZappySys\Jdbc\MySQL\mysql-connector-j-9.3.0.jaroptional for MySQL
Find full details in the MySQL Connector authentication reference.SSL connection
MySQL with TLS from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Same as Default Auth. Use this when the server requires TLS (managed Cloud SQL, RDS, SkySQL).
- After Finish, confirm
sslModeon the JDBC URL matches your server (REQUIRED vs VERIFY_CA). - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:mysql://[$HostName$]:[$Port$]/[$Database$]?sslMode=[$SslMode$]&useOldAliasMetadataBehavior=true -
Host :MyHostName -
TCP port :3306 -
SSL mode :REQUIRED -
User name : -
Password :
MysqlDSNjdbc:mysql://[$HostName$]:[$Port$]/[$Database$]?sslMode=[$SslMode$]&useOldAliasMetadataBehavior=truecom.mysql.cj.jdbc.DriverC:\ZappySys\Jdbc\MySQL\mysql-connector-j-9.3.0.jaroptional for MySQL
Find full details in the MySQL Connector authentication reference. -
MysqlDSNSELECT * FROM orders
SELECT * FROM ordersYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to MySQL data in Power BI
Another window opens and asks to select a Data Source we already created. Choose MysqlDSN and continue:
MysqlDSN
MysqlDSN
Finally, finally, read extracted data from MySQL in a Power BI report:
If you wish to import MySQL data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local MySQL ODBC data source:
ODBC{"connectionstring":"dsn=MysqlDSN"}
dsn=MysqlDSN
dsn=MysqlDSN
= Odbc.Query("dsn=MysqlDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports MySQL data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_MYSQL_IN_GATEWAY], 'SELECT * FROM orders')
SELECT * FROM OPENQUERY([LS_TO_MYSQL_IN_GATEWAY], 'SELECT * FROM orders') - Click OK and load the data. Your MySQL data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - MySQLRead and write MySQL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.MysqlDSN
MysqlDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:mysql://[$HostName$]:[$Port$]/[$Database$]?useOldAliasMetadataBehavior=true';ClassName='com.mysql.cj.jdbc.Driver';DriverPath='C:\ZappySys\Jdbc\MySQL\mysql-connector-j-9.3.0.jar';UserName='';UserPassword='';ConnParams='optional for MySQL'
Open DBeaver.
com.mysql.cj.jdbc.Driver):
Go to the Libraries tab, click Add File, and select your MySQL driver library file(s), e.g.
C:\ZappySys\Jdbc\MySQL\mysql-connector-j-9.3.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:mysql://[$HostName$]:[$Port$]/[$Database$]?useOldAliasMetadataBehavior=true), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide MySQL data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create MySQL data source in the gateway
In this section we will create a data source for MySQL in the Data Gateway. Let's follow these steps to accomplish that:
MysqlDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the MySQL ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
MysqlDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - MySQLRead and write MySQL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.MysqlDSN
MysqlDSN(the one we used in the Data Gateway):MysqlDSNMysqlDSN
Finally, we are ready to read data from MySQL in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to MySQL data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to MySQL in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to MySQL, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
