You can connect to your Infor Data Lake data from Power BI via the high-performance Infor Data Lake ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Infor Data Lake
- Working with Infor Data Lake data directly inside Power BI
Download Infor Data Lake JDBC driver
To connect to Infor Data Lake, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Infor Data Lake video tutorial or official website.
C:\ZappySys\Jdbc\Infor Data Lake\infor-compass-jdbc.jar. -
Then download ION API file from Infor. With the ION API file (stored in the connection) sign-in method you pick that file in the next step and it can stay anywhere; each connection can use a different tenant's file.
With the ION API file next to the driver jar sign-in method, place it in the same directory as the JDBC driver, e.g.C:\ZappySys\Jdbc\Infor Data Lake\Infor Compass JDBC Driver.ionapi, and do not rename it, or the driver will fail to load. That folder can then serve one tenant only. -
Create data source using Infor Data Lake ODBC Driver
To get data from Infor Data Lake using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Infor Data Lake.
Infor Data Lake authentication
Infor Compass JDBC (Data Lake) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools. Use this sign-in method when you connect to more than one tenant, or when you cannot place files next to the driver.
- Download the Compass JDBC JAR from the Infor documentation page (not Maven Central). Put it under
C:\ZappySys\Jdbc\Infor Data Lake. - Download the ION API file for your tenant from Infor ION API and pick it in ION API file. It can stay anywhere; its content is saved with this connection.
- Replace
MY_DATALAKE_IDon the DSN Main UI after Finish. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:infordatalake://[$DataLakeId$] -
Driver class :com.infor.idl.jdbc.Driver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Infor Data Lake\infor-compass-jdbc.jar -
Data lake id :MY_DATALAKE_ID -
ION API file :
InforDataLakeDSNjdbc:infordatalake://[$DataLakeId$]com.infor.idl.jdbc.DriverC:\ZappySys\Jdbc\Infor Data Lake\infor-compass-jdbc.jaroptional for Infor Data Lakeoptional for Infor Data Lakeoptional for Infor Data Lake
Find full details in the Infor Data Lake Connector authentication reference.ION API file next to the driver jar
Infor Compass JDBC (Data Lake) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools. The driver reads the ION API file from the folder that holds the driver jar, so that folder serves one tenant.
C:\ZappySys\Jdbc\Infor Data Lake. - Download the ION API file (
Infor Compass JDBC Driver.ionapi) and place it in the same folder. Do not rename it. - Replace
MY_DATALAKE_IDon the DSN Main UI after Finish. - Optional: watch the setup video.
Find full details in the Infor Data Lake Connector authentication reference. -
InforDataLakeDSNSELECT "RCM"."CCUST" AS "CustomerNumber", "RCM"."CNAME" AS "CustomerName", "RCM"."CSTAT" AS "CustomerStatus" FROM "default"."RCM" WHERE infor.lastmodified() >= '2026-02-01T00:00:00.000Z'
SELECT "RCM"."CCUST" AS "CustomerNumber", "RCM"."CNAME" AS "CustomerName", "RCM"."CSTAT" AS "CustomerStatus" FROM "default"."RCM" WHERE infor.lastmodified() >= '2026-02-01T00:00:00.000Z'You can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Infor Data Lake data in Power BI
Another window opens and asks to select a Data Source we already created. Choose InforDataLakeDSN and continue:
InforDataLakeDSN
InforDataLakeDSN
Finally, finally, read extracted data from Infor Data Lake in a Power BI report:
If you wish to import Infor Data Lake data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Infor Data Lake ODBC data source:
ODBC{"connectionstring":"dsn=InforDataLakeDSN"}
= Odbc.Query("dsn=InforDataLakeDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Infor Data Lake data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_INFOR_DATA_LAKE_IN_GATEWAY], 'SELECT "RCM"."CCUST" AS "CustomerNumber", "RCM"."CNAME" AS "CustomerName", "RCM"."CSTAT" AS "CustomerStatus" FROM "default"."RCM" WHERE infor.lastmodified() >= ''2026-02-01T00:00:00.000Z''')
SELECT * FROM OPENQUERY([LS_TO_INFOR_DATA_LAKE_IN_GATEWAY], 'SELECT "RCM"."CCUST" AS "CustomerNumber", "RCM"."CNAME" AS "CustomerName", "RCM"."CSTAT" AS "CustomerStatus" FROM "default"."RCM" WHERE infor.lastmodified() >= ''2026-02-01T00:00:00.000Z''') - Click OK and load the data. Your Infor Data Lake data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Infor Data LakeQuery Infor Data Lake from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.InforDataLakeDSN
InforDataLakeDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:infordatalake://[$DataLakeId$]';ClassName='com.infor.idl.jdbc.Driver';DriverPath='C:\ZappySys\Jdbc\Infor Data Lake\infor-compass-jdbc.jar';UserName='optional for Infor Data Lake';UserPassword='optional for Infor Data Lake';ConnParams='optional for Infor Data Lake'
Open DBeaver.
com.infor.idl.jdbc.Driver):
Go to the Libraries tab, click Add File, and select your Infor Data Lake driver library file(s), e.g.
C:\ZappySys\Jdbc\Infor Data Lake\infor-compass-jdbc.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:infordatalake://[$DataLakeId$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Infor Data Lake data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Infor Data Lake data source in the gateway
In this section we will create a data source for Infor Data Lake in the Data Gateway. Let's follow these steps to accomplish that:
InforDataLakeDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Infor Data Lake ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
InforDataLakeDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Infor Data LakeQuery Infor Data Lake from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.InforDataLakeDSN
InforDataLakeDSN(the one we used in the Data Gateway):InforDataLakeDSNInforDataLakeDSN
Finally, we are ready to read data from Infor Data Lake in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Infor Data Lake data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Infor Data Lake in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Infor Data Lake, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
