You can connect to your Apache Hive data from Power BI via the high-performance Apache Hive ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Apache Hive
  • Working with Apache Hive data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Hive.
Download Apache Hive JDBC driver
To connect to Apache Hive, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Hive website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Hive\hive-jdbc-4.2.0-standalone.jar.
  4. Download the standalone Hive JDBC JAR so you do not have to assemble Hadoop dependencies, e.g. hive-jdbc-4.2.0-standalone.jar.
  5. Done! That was easy, wasn't it? Let's proceed to the next step.
Create data source using Apache Hive ODBC Driver
To get data from Apache Hive using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Apache Hive.
    HiveServer2 (default)
    Apache Hive authentication
    Connect to HiveServer2 with the standalone JDBC JAR. JDBC Bridge then exposes Hive SQL to Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Note the HiveServer2 host and binary port (default 10000) and the default database name.
    2. Create a Hive / LDAP user if the cluster requires authentication. Lab clusters sometimes allow empty user and password.
    3. Replace hive-instance-host-name and the database in the JDBC URL after Finish (the wizard hides the URL; edit it on the DSN Main UI).
    4. Prefer the standalone JAR the wizard downloads. Do not mix it with a partial Hadoop classpath.
    3. Finally, hit OK button:
    • Connection string: jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]
    • Driver class: org.apache.hive.jdbc.HiveDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Hive\hive-jdbc-4.2.0-standalone.jar
    • Host: MyHostName
    • TCP port: 10000
    • Database name: MyDatabase
    • User name:
    • Password:
    ApacheHiveDSN
    optional for Apache Hive
    Find full details in the Apache Hive Connector authentication reference.
    Hive 4 (SSL / LDAP)
    Hive 4 HiveServer2 with SSL and user/password (LDAP or custom). Power BI's old Hive LLAP ODBC path is being deprecated; this JDBC standalone JAR is the durable Excel / SSIS / Linked Server path.
    1. Confirm Hive 4.x HiveServer2 host, port 10000 (or your HS2 port), and that SSL is enabled.
    2. Create or reuse an LDAP / Hive user. Paste user and password here. Do not use a personal employee login for unattended refresh.
    3. The wizard downloads hive-jdbc-4.2.0-standalone.jar. Keep SSL=true unless your lab is plaintext (then use Default Auth).
    4. After Finish, edit the JDBC URL on the DSN Main UI to replace the host (e.g. MyHostName) and database (e.g. MyDatabase).
    • Connection string: jdbc:hive2://[$HostName$]:[$Port$]/[$Database$];ssl=[$Ssl$]
    • Host: MyHostName
    • TCP port: 10000
    • SSL: true
    • User name:
    • Password:
    ApacheHiveDSN
    Jump to troubleshooter
    ApacheHiveDSN
    SHOW TABLES
    SHOW TABLES
Connect to Apache Hive data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ApacheHiveDSN and continue:
    ApacheHiveDSN
    ApacheHiveDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Apache Hive in a Power BI report:
If you wish to import Apache Hive data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ApacheHiveDSN
SHOW TABLES
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Hive ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ApacheHiveDSN"}
    dsn=ApacheHiveDSN
    dsn=ApacheHiveDSN
    = Odbc.Query("dsn=ApacheHiveDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Apache Hive data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Apache Hive Service
    SELECT * FROM OPENQUERY([LS_TO_APACHE_HIVE_IN_GATEWAY], 'SHOW TABLES')
    DirectQuery option for Power BI (read Apache Hive data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Apache Hive data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Apache Hive
    Read and write Apache Hive data effortlessly. Query, integrate, and manage tables and SQL on big data from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ApacheHiveDSN
    ApacheHiveDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]';ClassName='org.apache.hive.jdbc.HiveDriver';DriverPath='C:\ZappySys\Jdbc\Apache Hive\hive-jdbc-4.2.0-standalone.jar';UserName='';UserPassword='';ConnParams='optional for Apache Hive'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.hive.jdbc.HiveDriver):
  6. Go to the Libraries tab, click Add File, and select your Apache Hive driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Hive\hive-jdbc-4.2.0-standalone.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Hive data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Hive data source in the gateway
In this section we will create a data source for Apache Hive in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheHiveDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Hive ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ApacheHiveDSN
      ApacheHiveDSN
      ApacheHiveDSN
  5. Then set the default database property to ApacheHiveDSN (the one we used in the Data Gateway):
    ApacheHiveDSN
    ApacheHiveDSN
Finally, we are ready to read data from Apache Hive in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Apache Hive data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Hive in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Hive, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
