You can connect to your Apache Pinot data from Power BI via the high-performance Apache Pinot ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Apache Pinot
- Working with Apache Pinot data directly inside Power BI
Download Apache Pinot JDBC driver
To connect to Apache Pinot, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Apache Pinot website or MVN Repository.
C:\ZappySys\Jdbc\Apache Pinot\pinot-jdbc-client-1.5.0-shaded.jar.
Create data source using Apache Pinot ODBC Driver
To get data from Apache Pinot using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Apache Pinot.
Controller
Apache Pinot authentication
Apache Pinot JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Use the Pinot controller host and port (default
9000). - If the cluster is authenticated, fill user and password from Pinot controller config.
- Broker discovery is handled by the JDBC client; the DSN host must reach controller and brokers.
Connection string :jdbc:pinot://[$HostName$]:[$Port$] -
Driver class :org.apache.pinot.client.PinotDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Pinot\pinot-jdbc-client-1.5.0-shaded.jar -
Host :MyHostName -
TCP port :9000 -
User name : -
Password :
ApachePinotDSNjdbc:pinot://[$HostName$]:[$Port$]org.apache.pinot.client.PinotDriverC:\ZappySys\Jdbc\Apache Pinot\pinot-jdbc-client-1.5.0-shaded.jaroptional for Apache Pinot
Find full details in the Apache Pinot Connector authentication reference. -
ApachePinotDSNSELECT tableName FROM default.tables
SELECT tableName FROM default.tablesYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Apache Pinot data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ApachePinotDSN and continue:
ApachePinotDSN
ApachePinotDSN
Finally, finally, read extracted data from Apache Pinot in a Power BI report:
If you wish to import Apache Pinot data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Pinot ODBC data source:
ODBC{"connectionstring":"dsn=ApachePinotDSN"}
dsn=ApachePinotDSN
dsn=ApachePinotDSN
= Odbc.Query("dsn=ApachePinotDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Apache Pinot data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_APACHE_PINOT_IN_GATEWAY], 'SELECT tableName FROM default.tables')
SELECT * FROM OPENQUERY([LS_TO_APACHE_PINOT_IN_GATEWAY], 'SELECT tableName FROM default.tables') - Click OK and load the data. Your Apache Pinot data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Apache PinotQuery Apache Pinot OLAP tables with JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApachePinotDSN
ApachePinotDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:pinot://[$HostName$]:[$Port$]';ClassName='org.apache.pinot.client.PinotDriver';DriverPath='C:\ZappySys\Jdbc\Apache Pinot\pinot-jdbc-client-1.5.0-shaded.jar';UserName='';UserPassword='';ConnParams='optional for Apache Pinot'
Open DBeaver.
org.apache.pinot.client.PinotDriver):
Go to the Libraries tab, click Add File, and select your Apache Pinot driver library file(s), e.g.
C:\ZappySys\Jdbc\Apache Pinot\pinot-jdbc-client-1.5.0-shaded.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:pinot://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Apache Pinot data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Pinot data source in the gateway
In this section we will create a data source for Apache Pinot in the Data Gateway. Let's follow these steps to accomplish that:
ApachePinotDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Pinot ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ApachePinotDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Apache PinotQuery Apache Pinot OLAP tables with JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApachePinotDSN
ApachePinotDSN(the one we used in the Data Gateway):ApachePinotDSNApachePinotDSN
Finally, we are ready to read data from Apache Pinot in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Apache Pinot data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Pinot in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Pinot, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
