You can connect to your Arrow Flight SQL data from C# via the high-performance Arrow Flight SQL ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  1. Visit Arrow Flight SQL website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar.
Create data source using Arrow Flight SQL ODBC Driver
Watch this quick walkthrough to see how to configure your Arrow Flight SQL ODBC data source, or scroll down for the step-by-step written guide.
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Arrow Flight SQL.
To get data from Arrow Flight SQL using C#, we first need to create an ODBC data source. We will later read this data in C#. Perform these steps:
    • Configure the authentication in Arrow Flight SQL.
    User and password
    1. Note the Flight SQL host and port (Dremio often uses 32010; other servers differ). Default encryption is on.
    2. Create a database user on the Flight SQL server. Paste user and password.
    3. If the Bridge JVM is Java 16 or newer, add --add-opens=java.base/java.nio=ALL-UNNAMED to the JDBC Bridge JVM options when Arrow reports module-access errors.
    4. After Finish, replace host and port. Set useEncryption=false only for a local plaintext lab.
    3. Finally, hit OK button:
    • Connection string: jdbc:arrow-flight-sql://[$HostName$]:[$Port$]
    • Driver class: org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar
    • Host: MyHostName
    • TCP port: 32010
    • User name:
    • Password:
    • Use encryption: true
    ArrowFlightSqlDSN
    optional for Arrow Flight SQL
    Find full details in the Arrow Flight SQL Connector authentication reference.
    Token
    1. Create an API token or personal access token in the Flight SQL server UI (same idea as a Stripe secret key).
    2. Paste the token into Token. Leave user/password empty unless the server requires both.
    3. Java 16+ may need --add-opens=java.base/java.nio=ALL-UNNAMED on the Bridge JVM.
    4. After Finish, replace host and port. Cloud endpoints often use 443 with TLS.
    • Host: MyHostName
    • TCP port: 32010
    • Token:
    ArrowFlightSqlDSN
    Jump to troubleshooter
    ArrowFlightSqlDSN
    SELECT * FROM information_schema.tables
Read data in C#
Using ODBC DSN
  1. Use this code snippet to read the data using ArrowFlightSqlDSN data source:
    "ArrowFlightSqlDSN" ;
    Make ZappySys Driver call in c#
  2. Press F5 to run the code and read the data:
    ZappySys Driver Output in c#
  3. Here is the code in text format:
    using System;
    using System.Data.Odbc;
    namespace ConsoleApp {
        class Program {
            static void Main() {
                var dsn = "ArrowFlightSqlDSN";
                using (var conn = new OdbcConnection(String.Format("DSN={0}", dsn)))
                    conn.Open();
                    var cmd = new OdbcCommand("SELECT * FROM Products", conn);
                    //Increase the timeout duration from the default 30 seconds, which may be insufficient in certain scenarios
                    cmd.CommandTimeout=600; // 600-Seconds
                    var rdr = cmd.ExecuteReader();
                    while (rdr.Read())
                        for (int i = 0; i < rdr.FieldCount; i++)
                                Console.Write("{0}\t", rdr[i]);
                        Console.WriteLine();
                Console.ReadKey();
Using a full ODBC connection string
If you want to avoid being dependent on a DSN and creating multiple DSNs for each platform (x86, x64), then you can use a fully qualified connection string. Simply go to your DSN and copy the Connection String:
    ZappySys JDBC Bridge Driver - Arrow Flight SQL
    Query any Arrow Flight SQL endpoint with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ArrowFlightSqlDSN
  3. Then in your C# code, pass the connection string as an argument when calling the OdbcConnection object's constructor, for example:
    var connectionString = @"DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:arrow-flight-sql://[$HostName$]:[$Port$]';ClassName='org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver';DriverPath='C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar';UserName='';UserPassword='';ConnParams='optional for Arrow Flight SQL'";
    using (var conn = new OdbcConnection(connectionString))
        // your code goes here
  6. Our troubles are over! Now you should be able to use this connection string in C# with no problems.
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
  6. Go to the Libraries tab, click Add File, and select your Arrow Flight SQL driver library file(s), e.g. C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:arrow-flight-sql://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Arrow Flight SQL data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in C# (client-side) to connect to it.
Create Arrow Flight SQL data source in the gateway
    ArrowFlightSqlDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Arrow Flight SQL ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ArrowFlightSqlDSN
      ArrowFlightSqlDSN
      ArrowFlightSqlDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from C#. To achieve that, let's perform these steps:
  5. Then set the default database property to ArrowFlightSqlDSN (the one we used in the Data Gateway):
    ArrowFlightSqlDSN
    ArrowFlightSqlDSN
Access data in C# via the gateway
Finally, we are ready to read data from Arrow Flight SQL in C# via the Data Gateway. Follow these final steps:
  1. Go back to C#.
  2. Use this code snippet to read the data using ZappySysGatewayDSN data source:
    "ZappySysGatewayDSN" ;
  3. Read the data the same way we discussed at the beginning of this article.
  4. That's it!
Now you can connect to Arrow Flight SQL data in C# via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Arrow Flight SQL using C# and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Arrow Flight SQL, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
