You can connect to your Jira data from Power BI via the high-performance Jira ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Jira
  • Working with Jira data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Jira Connector.
To get data from Jira using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    JiraDSN
    Jira
    API Key based Authentication
    Jira authentication
    1. Go to Profile > Security.
    5. That's it!
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
      Name OAuth app in Atlassian
        • offline_access (a must)
        • read:jira-user
        • read:jira-work
        • write:jira-work
        • manage:jira-project
        • manage:jira-configuration
    JiraDSN
    Jira
    ZappySys API Driver - Jira
    JiraDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Jira. Hit OK button to use this query in the next step.
    SELECT * FROM Issues
    --//Query single issue by numeric Issue Id
    --SELECT * FROM Issues Where Id=101234
    --//Query issue by numeric Issue Ids (multiple)
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='101234,101235,101236')
    --//Query issue by Issue Key(s) (alpha-numeric)
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11')
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11,PROJ-12,PROJ-13')
    --//Query issue by project(s)
    --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ')
    --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ,KAN,CS')
    --//Query issue by JQL expression
    --SELECT * FROM Issues WITH(SearchBy='Jql', Jql='status IN (Done, Closed) AND created > -5d' )
    Some parameters configured in this window will be passed to the Jira API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    JiraDSN
Connect to Jira data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose JiraDSN and continue:
    JiraDSN
    JiraDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Jira in a Power BI report:
If you wish to import Jira data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
JiraDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Jira ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=JiraDSN"}
    dsn=JiraDSN
    dsn=JiraDSN
    = Odbc.Query("dsn=JiraDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Jira data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Jira Service
    SELECT * FROM OPENQUERY([LS_TO_JIRA_IN_GATEWAY], 'SELECT * FROM Issues --//Query single issue by numeric Issue Id --SELECT * FROM Issues Where Id=101234 --//Query issue by numeric Issue Ids (multiple) --SELECT * FROM Issues WITH(SearchBy=''Key'', Key=''101234,101235,101236'') --//Query issue by Issue Key(s) (alpha-numeric) --SELECT * FROM Issues WITH(SearchBy=''Key'', Key=''PROJ-11'') --SELECT * FROM Issues WITH(SearchBy=''Key'', Key=''PROJ-11,PROJ-12,PROJ-13'') --//Query issue by project(s) --SELECT * FROM Issues WITH(SearchBy=''Project'', Project=''PROJ'') --SELECT * FROM Issues WITH(SearchBy=''Project'', Project=''PROJ,KAN,CS'') --//Query issue by JQL expression --SELECT * FROM Issues WITH(SearchBy=''Jql'', Jql=''status IN (Done, Closed) AND created > -5d'' )')
    DirectQuery option for Power BI (read Jira data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Jira data is now linked live rather than imported.
    JiraDSN
    JiraDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://[$Subdomain$].atlassian.net/rest/api/3;CredentialType=Basic;
Jira Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Jira operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Jira data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Jira data source in the gateway
In this section we will create a data source for Jira in the Data Gateway. Let's follow these steps to accomplish that:
    JiraDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Jira ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      JiraDSN
      JiraDSN
      JiraDSN
  5. Then set the default database property to JiraDSN (the one we used in the Data Gateway):
    JiraDSN
    JiraDSN
Finally, we are ready to read data from Jira in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Jira data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Jira in Power BI and integrate your data — all without writing complex code.
