You can connect to your Custom API data from Power BI via the high-performance Custom API ODBC Driver. We'll walk you through the entire setup.
- Working with Custom API data directly inside Power BI
Create Custom API Connector
First of all, you will have to create your own API connector.
For demonstration purposes, in this section we will create a simple Hello-World API connector that
calls ZappySys Sandbox World API endpoint https://sandbox.zappysys.com/api/world/hello.
When developing your Custom API Connector, just replace it with your real API method/endpoint.
Let's dive in and follow these steps:
Create a User data source (User DSN) based on the ZappySys JSON Driver driver:
Once the data source configuration window opens, enter this URL into the text box:
Then go to the Preview tab and try to say "Hello!" to the World!
Since the test is successful, you are ready to create the Hello-World Connector:
The API Connector File Wizard opens, click Next:
Leave the default option, and click Next again:
Just click Next in the next window:
Let's give our new custom connector a name it deserves:
Then just click Next in the Connection Types window:
Let's name the hello endpoint (it deserves a name too!):
When the next window opens, delete the default table (we won't need it for now):
Finally, specify a path, where you want to save the newly created API Connector:
Create data source using Custom API ODBC Driver
To get data from Custom API using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already. Then set the path to your created Custom API Connector (in the example below, we use Hello-World Connector). Finally, click Continue >> to proceed:
Now it's time to configure the Connection Manager. Select Authentication Type, e.g. Token Authentication. Then select API Base URL (in most cases, the default one is the right one). Check your Custom API reference for more information on how to authenticate.
ZappySys API Driver - Custom APIRead / write Custom API data without coding.CustomApiDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Custom API. Hit OK button to use this query in the next step.
SELECT * FROM Orders
Some parameters configured in this window will be passed to the Custom API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - Custom APIRead / write Custom API data without coding.CustomApiDSNSELECT * FROM Orders
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Custom API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Custom API servers). -
Connect to Custom API data in Power BI
Another window opens and asks to select a Data Source we already created. Choose CustomApiDSN and continue:
CustomApiDSN
CustomApiDSN
Finally, finally, read extracted data from Custom API in a Power BI report:
If you wish to import Custom API data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Custom API ODBC data source:
ODBC{"connectionstring":"dsn=CustomApiDSN"}
dsn=CustomApiDSN
dsn=CustomApiDSN
= Odbc.Query("dsn=CustomApiDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Custom API data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_CUSTOM_API_IN_GATEWAY], 'SELECT * FROM Orders')
SELECT * FROM OPENQUERY([LS_TO_CUSTOM_API_IN_GATEWAY], 'SELECT * FROM Orders') - Click OK and load the data. Your Custom API data is now linked live rather than imported.
CustomApiDSNDRIVER={ZappySys API Driver};ServiceUrl=https://sandbox.zappysys.com/api/world;CredentialType=Basic;
In some situations, you may need to provide Custom API data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Custom API data source in the gateway
In this section we will create a data source for Custom API in the Data Gateway. Let's follow these steps to accomplish that:
CustomApiDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Custom API ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
CustomApiDSN
ZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - Custom APIRead / write Custom API data without coding.CustomApiDSN
CustomApiDSN(the one we used in the Data Gateway):CustomApiDSNCustomApiDSN
Finally, we are ready to read data from Custom API in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Custom API data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Custom API in Power BI and integrate your data — all without writing complex code.
