You can connect to your Amazon Neptune data from Power BI via the high-performance Amazon Neptune ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Amazon Neptune
- Working with Amazon Neptune data directly inside Power BI
Download Amazon Neptune JDBC driver
To connect to Amazon Neptune, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Amazon Neptune website or MVN Repository.
C:\ZappySys\Jdbc\Amazon Neptune\amazon-neptune-jdbc-driver-3.0.3-all.jar.
Create data source using Amazon Neptune ODBC Driver
To get data from Amazon Neptune using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Amazon Neptune.
None (no IAM)
Amazon Neptune authentication
Amazon Neptune JDBC (SQL-Gremlin) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools. Neptune is VPC-only. Use this Auth when IAM DB authentication is off, or when you already opened an SSH tunnel to port 8182.
- Confirm the cluster endpoint in the Neptune console (not a public hostname). Default port is
8182. - From outside the VPC, open an SSH tunnel through a bastion in the same VPC, or run JDBC Bridge on an EC2 host that can reach the cluster.
- Enable SSL on the cluster. After Finish, replace the host (e.g. MyHostName) on the DSN Main UI. Keep
authScheme=Nonefor this profile. - Prefer SQL-Gremlin (
jdbc:neptune:sqlgremlin://) for Power BI and other ODBC tools. Gremlin / openCypher / SPARQL URLs are for graph-native clients. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:neptune:sqlgremlin://[$HostName$];port=[$Port$];authScheme=None;enableSsl=[$EnableSsl$] -
Driver class :software.amazon.neptune.jdbc.NeptuneDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Amazon Neptune\amazon-neptune-jdbc-driver-3.0.3-all.jar -
Host :MyHostName -
TCP port :8182 -
Enable SSL :true -
User name : -
Password :
AmazonNeptuneDSNjdbc:neptune:sqlgremlin://[$HostName$];port=[$Port$];authScheme=None;enableSsl=[$EnableSsl$]software.amazon.neptune.jdbc.NeptuneDriverC:\ZappySys\Jdbc\Amazon Neptune\amazon-neptune-jdbc-driver-3.0.3-all.jaroptional for Amazon Neptune
Find full details in the Amazon Neptune Connector authentication reference.IAM SigV4
IAM SigV4 for Neptune JDBC. SSL is required. Create IAM access keys in the console (same idea as a Stripe secret key), or rely on the default credential chain on an EC2 instance / role.
- Sign in to the IAM console.
- Create (or reuse) an IAM user or role with Neptune connect/query permissions. Do not use a personal employee login for unattended Linked Server or Power BI refresh.
- Open Security credentials and create an access key. Copy Access key ID into User name and Secret access key into Password. Alternatively leave them empty and use an instance profile /
AWS_PROFILE. - Set Service region to the cluster region (for example
us-east-1). KeepenableSsl=true. - Neptune has no public endpoint. After Finish, replace the host (e.g. MyHostName) (and SSH-tunnel port if you forwarded 8182 locally).
Connection string :jdbc:neptune:sqlgremlin://[$HostName$];port=[$Port$];authScheme=IAMSigV4;enableSsl=[$EnableSsl$];serviceRegion=[$serviceRegion$] -
Host :MyHostName -
TCP port :8182 -
Enable SSL :true -
Service region :us-east-1 -
Access key ID : -
Secret access key :
AmazonNeptuneDSNjdbc:neptune:sqlgremlin://[$HostName$];port=[$Port$];authScheme=IAMSigV4;enableSsl=[$EnableSsl$];serviceRegion=[$serviceRegion$]software.amazon.neptune.jdbc.NeptuneDriverC:\ZappySys\Jdbc\Amazon Neptune\amazon-neptune-jdbc-driver-3.0.3-all.jaroptional for Amazon Neptune
Find full details in the Amazon Neptune Connector authentication reference. -
AmazonNeptuneDSNSELECT * FROM country
SELECT * FROM countryYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Amazon Neptune data in Power BI
Another window opens and asks to select a Data Source we already created. Choose AmazonNeptuneDSN and continue:
AmazonNeptuneDSN
AmazonNeptuneDSN
Finally, finally, read extracted data from Amazon Neptune in a Power BI report:
If you wish to import Amazon Neptune data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Amazon Neptune ODBC data source:
ODBC{"connectionstring":"dsn=AmazonNeptuneDSN"}
= Odbc.Query("dsn=AmazonNeptuneDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Amazon Neptune data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_AMAZON_NEPTUNE_IN_GATEWAY], 'SELECT * FROM country')
SELECT * FROM OPENQUERY([LS_TO_AMAZON_NEPTUNE_IN_GATEWAY], 'SELECT * FROM country') - Click OK and load the data. Your Amazon Neptune data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Amazon NeptuneQuery Amazon Neptune graphs with SQL-Gremlin JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.AmazonNeptuneDSN
AmazonNeptuneDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:neptune:sqlgremlin://[$HostName$];port=[$Port$];authScheme=None;enableSsl=[$EnableSsl$]';ClassName='software.amazon.neptune.jdbc.NeptuneDriver';DriverPath='C:\ZappySys\Jdbc\Amazon Neptune\amazon-neptune-jdbc-driver-3.0.3-all.jar';UserName='';UserPassword='';ConnParams='optional for Amazon Neptune'
Open DBeaver.
software.amazon.neptune.jdbc.NeptuneDriver):
Go to the Libraries tab, click Add File, and select your Amazon Neptune driver library file(s), e.g.
C:\ZappySys\Jdbc\Amazon Neptune\amazon-neptune-jdbc-driver-3.0.3-all.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:neptune:sqlgremlin://[$HostName$];port=[$Port$];authScheme=None;enableSsl=[$EnableSsl$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Amazon Neptune data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Amazon Neptune data source in the gateway
In this section we will create a data source for Amazon Neptune in the Data Gateway. Let's follow these steps to accomplish that:
AmazonNeptuneDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Amazon Neptune ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
AmazonNeptuneDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Amazon NeptuneQuery Amazon Neptune graphs with SQL-Gremlin JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.AmazonNeptuneDSN
AmazonNeptuneDSN(the one we used in the Data Gateway):AmazonNeptuneDSNAmazonNeptuneDSN
Finally, we are ready to read data from Amazon Neptune in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Amazon Neptune data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Amazon Neptune in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Amazon Neptune, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
