You can connect to your XML data from Power BI via the high-performance XML ODBC Driver. We'll walk you through the entire setup.
- Working with XML data directly inside Power BI
- Exploring advanced XML Driver features
Create data source using XML ODBC Driver
To get data from XML using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
Create a User data source (User DSN) based on the ZappySys XML Driver driver:
ZappySys XML Driver
Select Url or File and paste the following Url for this example OR you can load existing connection string as per this article.
NOTE: Here for demo, We are using odata API, but you need to refer your own API documentation and based on that you need to use your own API URL and need to configure connection based on API Authentication type
Now enter Path expression in Array Filter textbox to extract only specific part of XML file as below ($.feed.entry[*] will get content of entry attribute from XML document. Entry attribute is array of XML documents so we have to use [*] to indicate we want all records of that array)
NOTE: Here, We are using our desired filter, but you need to select your desired filter based on your requirement.
Click on Test Connection button to view whether the Test Connection is SUCCESSFUL or Not.$.feed.entry[*]
Once you configured a data source, you can preview data. Hit Preview tab, and use similar settings to preview data:
That's it; we are done. In a few clicks we configured the call to XML API using ZappySys XML Connector.
Connect to XML data in Power BI
Another window opens and asks to select a Data Source we already created. Choose XmlDSN and continue:
XmlDSN
XmlDSN
Finally, finally, read extracted data from XML in a Power BI report:
If you wish to import XML data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ProductID,
ProductName,
SupplierID,
CategoryID,
QuantityPerUnit,
UnitPrice
FROM _root_
WHERE UnitPrice > 20
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local XML ODBC data source:
ODBC{"connectionstring":"dsn=XmlDSN"}
dsn=XmlDSN
dsn=XmlDSN
= Odbc.Query("dsn=XmlDSN", "SELECT * FROM _root_ WITH (SRC='http://my-api-provider.com/api/" & MyParameter & "/items')")
By default, Power BI imports XML data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_XML_IN_GATEWAY], 'SELECT * FROM Orders')
SELECT * FROM OPENQUERY([LS_TO_XML_IN_GATEWAY], 'SELECT * FROM Orders') - Click OK and load the data. Your XML data is now linked live rather than imported.
ZappySys XML Driver - XMLRead and write XML data effortlessly. Extract, filter, and sync XML from URLs, strings, and local files for analytics, reporting, and data pipelines — almost no coding required.XmlDSN
XmlDSNDRIVER={ZappySys XML Driver};DataPath='http://www.holidaywebservice.com/HolidayService_v2/HolidayService2.asmx';Filter='$.soapEnvelope.soap:Body.GetHolidaysAvailableResponse.GetHolidaysAvailableResult.HolidayCode[*]';
DRIVER={ZappySys XML Driver};SettingsFile=C:\temp\odbc-connection-string.txt - Our troubles are over! Now you should be able to use this connection string in Power BI with no problems.
Configuring pagination in the XML Driver
ZappySys XML Driver equips users with powerful tools for seamless data extraction and management from REST APIs, leveraging advanced pagination methods for enhanced efficiency. These options are designed to handle various types of pagination structures commonly used in APIs. Below are the detailed descriptions of these options:
Page-based Pagination: This method works by retrieving data in fixed-size pages from the Rest API. It allows you to specify the page size and navigate through the results by requesting different page numbers, ensuring that you can access all the data in a structured manner.
Offset-based Pagination: With this approach, you can extract data by specifying the starting point or offset from which to begin retrieving data. It allows you to define the number of records to skip and fetch subsequent data accordingly, providing precise control over the data extraction process.
Cursor-based Pagination: This technique involves using a cursor or a marker that points to a specific position in the dataset. It enables you to retrieve data starting from the position indicated by the cursor and proceed to subsequent segments, ensuring that you capture all the relevant information without missing any records.
Token-based Pagination: In this method, a token serves as a unique identifier for a specific data segment. It allows you to access the next set of data by using the token provided in the response from the previous request. This ensures that you can systematically retrieve all the data segments without duplication or omission.
Utilizing these comprehensive pagination features in the ZappySys XML Driver facilitates efficient data management and extraction from REST APIs, optimizing the integration and analysis of extensive datasets.
Authentication
ZappySys offers various authentication methods to securely access data from various sources. These authentication methods include OAuth, Basic Authentication, Token-based Authentication, and more, allowing users to connect to a wide range of data sources securely.
ZappySys Authentication is a robust system that facilitates secure access to data from a diverse range of sources. It includes a variety of authentication methods tailored to meet the specific requirements of different data platforms and services. These authentication methods may involve:
OAuth: ZappySys supports OAuth for authentication, which allows users to grant limited access to their data without revealing their credentials. It's commonly used for applications that require access to user account information.
Basic Authentication: This method involves sending a username and password with every request. ZappySys allows users to securely access data using this traditional authentication approach.
Token-based Authentication: ZappySys enables users to utilize tokens for authentication. This method involves exchanging a unique token with each request to authenticate the user's identity without revealing sensitive information.
By implementing these authentication methods, ZappySys ensures the secure and reliable retrieval of data from various sources, providing users with the necessary tools to access and integrate data securely and efficiently. For more comprehensive details on the authentication process, please refer to the official ZappySys documentation or reach out to their support team for further assistance.
For more details, please refer to this link: ZappySys Connections
In some situations, you may need to provide XML data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create XML data source in the gateway
In this section we will create a data source for XML in the Data Gateway. Let's follow these steps to accomplish that:
- Then select Native - ZappySys XML Driver
XmlDSNZappySys XML Driver
When the ZappySys XML Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the XML ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
XmlDSN
ZappySys XML Driver - Configuration [Version: 2.0.1.10418]ZappySys XML Driver - XMLRead and write XML data effortlessly. Extract, filter, and sync XML from URLs, strings, and local files for analytics, reporting, and data pipelines — almost no coding required.XmlDSN
XmlDSN(the one we used in the Data Gateway):XmlDSNXmlDSN
Finally, we are ready to read data from XML in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to XML data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to XML in Power BI and integrate your data — all without writing complex code.
