You can connect to your Apache Drill data from Power BI via the high-performance Apache Drill ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Apache Drill
- Working with Apache Drill data directly inside Power BI
Download Apache Drill JDBC driver
To connect to Apache Drill, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Apache Drill website or MVN Repository.
C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar.
Create data source using Apache Drill ODBC Driver
To get data from Apache Drill using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Apache Drill.
Drillbit
Apache Drill authentication
Apache Drill JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Note the Drillbit host and JDBC port (default
31010). - Create a Drill user if authentication is enabled, or leave user/password empty for anonymous clusters.
- Replace
hostnamein the JDBC URL. Enable SSL only if your cluster requires it (see the Drill JDBC docs). - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:drill:drillbit=[$HostName$]:[$Port$] -
Driver class :org.apache.drill.jdbc.Driver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar -
Host :MyHostName -
TCP port :31010 -
User name : -
Password :
ApacheDrillDSNjdbc:drill:drillbit=[$HostName$]:[$Port$]org.apache.drill.jdbc.DriverC:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jaroptional for Apache Drill
Find full details in the Apache Drill Connector authentication reference.ZooKeeper
Apache Drill (ZooKeeper) JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Get the ZooKeeper quorum and Drill cluster path from your ops team (often
/drill/drillbits1). - Replace host and path in the JDBC URL. User/password only if Drill auth is on.
Connection string :jdbc:drill:zk=[$HostName$]:[$Port$]/drill/drillbits1 -
Host :MyHostName -
TCP port :31010 -
User name : -
Password :
ApacheDrillDSNjdbc:drill:zk=[$HostName$]:[$Port$]/drill/drillbits1org.apache.drill.jdbc.DriverC:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jaroptional for Apache Drill
Find full details in the Apache Drill Connector authentication reference. -
ApacheDrillDSNSHOW DATABASES
SHOW DATABASESYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Apache Drill data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ApacheDrillDSN and continue:
ApacheDrillDSN
ApacheDrillDSN
Finally, finally, read extracted data from Apache Drill in a Power BI report:
If you wish to import Apache Drill data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
SHOW DATABASES
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Drill ODBC data source:
ODBC{"connectionstring":"dsn=ApacheDrillDSN"}
dsn=ApacheDrillDSN
dsn=ApacheDrillDSN
= Odbc.Query("dsn=ApacheDrillDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Apache Drill data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_APACHE_DRILL_IN_GATEWAY], 'SHOW DATABASES')
SELECT * FROM OPENQUERY([LS_TO_APACHE_DRILL_IN_GATEWAY], 'SHOW DATABASES') - Click OK and load the data. Your Apache Drill data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Apache DrillQuery files, Hive, and S3 with Apache Drill SQL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheDrillDSN
ApacheDrillDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:drill:drillbit=[$HostName$]:[$Port$]';ClassName='org.apache.drill.jdbc.Driver';DriverPath='C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar';UserName='';UserPassword='';ConnParams='optional for Apache Drill'
Open DBeaver.
org.apache.drill.jdbc.Driver):
Go to the Libraries tab, click Add File, and select your Apache Drill driver library file(s), e.g.
C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:drill:drillbit=[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Apache Drill data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Drill data source in the gateway
In this section we will create a data source for Apache Drill in the Data Gateway. Let's follow these steps to accomplish that:
ApacheDrillDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Drill ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ApacheDrillDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Apache DrillQuery files, Hive, and S3 with Apache Drill SQL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheDrillDSN
ApacheDrillDSN(the one we used in the Data Gateway):ApacheDrillDSNApacheDrillDSN
Finally, we are ready to read data from Apache Drill in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Apache Drill data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Drill in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Drill, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
