You can connect to your Google Drive data from Power BI via the high-performance Google Drive ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Google Drive
- Working with Google Drive data directly inside Power BI
Create data source using Google Drive ODBC Driver
To get data from Google Drive using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Google Drive" from the list of Popular Connectors. If "Google Drive" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
GoogleDriveDSNGoogle Drive
- Configure the authentication in Google Drive.
User Account
Google Drive authentication
User accounts represent a developer, administrator, or any other person who interacts with Google APIs and services. User accounts are managed as Google Accounts, either with Google Workspace or Cloud Identity. They can also be user accounts that are managed by a third-party identity provider and federated with Workforce Identity Federation. [API reference]
Follow these steps on how to create Client Credentials (User Account principle) to authenticate and access Google Drive API in SSIS package or ODBC data source:
WARNING: If you are planning to automate processes, we recommend that you use a Service Account authentication method. In case, you still need to use User Account, then make sure you use a system/generic account (e.g.automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.Step-1: Create project
This step is optional, if you already have a project in Google Cloud and can use it. However, if you don't, proceed with these simple steps to create one:
First of all, go to Google API Console.
Then click Select a project button and then click NEW PROJECT button:
Name your project and click CREATE button:
Wait until the project is created:
- Done! Let's proceed to the next step.
Step-2: Enable Google Drive API
In this step we will enable Google Drive API:
Select your project on the top bar:
Then click the "hamburger" icon on the top left and access APIs & Services:
Now let's enable several APIs by clicking ENABLE APIS AND SERVICES button:
In the search bar search for
driveand then locate and select Google Drive API:
Enable Google Drive API:
Step-3: Create OAuth application
First of all, click the "hamburger" icon on the top left and then hit VIEW ALL PRODUCTS:
Then access Google Auth Platform to start creating an OAuth application:
Start by pressing GET STARTED button:
Next, continue by filling in App name and User support email fields:
Choose Internal option, if it's enabled, otherwise select External:
Optional step if you used
Internaloption in the previous step. Nevertheless, if you had to useExternaloption, then click ADD USERS to add a user:
Then add your contact Email address:
Finally, check the checkbox and click CREATE button:
- Done! Let's create Client Credentials in the next step.
Step-4: Create Client Credentials
In Google Auth Platform, select Clients menu item and click CREATE CLIENT button:
Choose
Desktop appas Application type and name your credentials:
Continue by opening the created credentials:
Finally, copy Client ID and Client secret for the later step:
- Done! We have all the data needed for authentication, let's proceed to the last step!
Step-5: Configure connection
Now go to SSIS package or ODBC data source and use previously copied values in User Account authentication configuration:
- In the ClientId field paste the Client ID value.
- In the ClientSecret field paste the Client secret value.
Press Generate Token button to generate Access and Refresh Tokens.
Finally, click Test Connection to confirm the connection is working.
- Done! Now you are ready to use Google Drive Connector!
User Account [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
GoogleDriveDSNGoogle DriveUser Account [OAuth]https://www.googleapis.com/Required Parameters UseCustomApp Fill-in the parameter... Optional Parameters ClientId ClientSecret Scope https://www.googleapis.com/auth/drive RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 403|429 RetryCountMax 5 RetryMultiplyWaitTime True Redirect URL (Only for Web App)
Find full details in the Google Drive Connector authentication reference.Service Account (Using *.json OR *.p12 key file)
Service accounts are accounts that do not represent a human user. They provide a way to manage authentication and authorization when a human is not directly involved, such as when an application needs to access Google Cloud resources. Service accounts are managed by IAM. [API reference]
Follow these steps on how to create Service Account to authenticate and access Google Drive API in SSIS package or ODBC data source:
Step-3: Create Service Account
Use the steps below to create a Service Account in Google Cloud:
First of all, go to IAM & Admin in Google Cloud console:
Once you do that, click Service Accounts on the left side and click CREATE SERVICE ACCOUNT button:
Then name your service account and click CREATE AND CONTINUE button:
Continue by clicking Select a role dropdown and start granting service account Project Viewer roles:
Find Project group and select Viewer role:
Finish adding roles by clicking CONTINUE button:
You can always add or modify permissions later in IAM & Admin. -
Finally, in the last step, just click button DONE:
Done! We are ready to add a Key to this service account in the next step.
Step-4: Add Key to Service Account
We are ready to add a Key (JSON or P12 file) to the created Service Account:
In Service Accounts open newly created service account:
Next, copy email address of your service account for the later step:
Continue by selecting KEYS tab, then press ADD KEY dropdown, and click Create new key menu item:
Finally, select JSON (Engine v19+) or P12 option and hit CREATE button:
- Key file downloads into your machine. We have all the data needed for authentication, let's proceed to the last step!
Step-5: Share Google Drive files and folders with Service Account
Now it's time to grant Google Drive read/write permissions to the created service account:
- Login to https://drive.google.com with Google account credentials whose files/folders you want to share with the service account.
Select the file or folder, right-click on it, click Share menu item, and then hit Share subitem:
Share it with your service account:
Grant it appropriate permissions, e.g.
ViewerorEditor(for reading or writing):
- That's it! Let's proceed to the configuration!
Step-6: Configure connection
Now go to SSIS package or ODBC data source and configure these fields in Service Account authentication configuration:
- In the Service Account Email field paste the service account Email address value you copied in the previous step.
- In the Service Account Private Key Path (i.e. *.json or *.p12) field use downloaded certificate's file path.
Service Account (Using *.json OR *.p12 key file) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
GoogleDriveDSNGoogle DriveService Account (Using *.json OR *.p12 key file) [OAuth]https://www.googleapis.com/Required Parameters Service Account Email Fill-in the parameter... Service Account Private Key Path (i.e. *.json OR *.p12) Fill-in the parameter... Optional Parameters Scope https://www.googleapis.com/auth/drive RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 403|429 RetryCountMax 5 RetryMultiplyWaitTime True Impersonate As (Google account email address)
Find full details in the Google Drive Connector authentication reference. -
ZappySys API Driver - Google DriveRead and write Google Drive data effortlessly. Integrate, manage, and automate files, folders, and shared drives — almost no coding required.GoogleDriveDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Google Drive. Hit OK button to use this query in the next step.
SELECT * FROM Drive
Some parameters configured in this window will be passed to the Google Drive API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - Google DriveRead and write Google Drive data effortlessly. Integrate, manage, and automate files, folders, and shared drives — almost no coding required.GoogleDriveDSNSELECT * FROM Drive
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Google Drive API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Google Drive servers). -
Connect to Google Drive data in Power BI
Another window opens and asks to select a Data Source we already created. Choose GoogleDriveDSN and continue:
GoogleDriveDSN
GoogleDriveDSN
Finally, finally, read extracted data from Google Drive in a Power BI report:
If you wish to import Google Drive data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
SELECT * FROM Drive
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Google Drive ODBC data source:
ODBC{"connectionstring":"dsn=GoogleDriveDSN"}
dsn=GoogleDriveDSN
dsn=GoogleDriveDSN
= Odbc.Query("dsn=GoogleDriveDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Google Drive data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_GOOGLE_DRIVE_IN_GATEWAY], 'SELECT * FROM Drive')
SELECT * FROM OPENQUERY([LS_TO_GOOGLE_DRIVE_IN_GATEWAY], 'SELECT * FROM Drive') - Click OK and load the data. Your Google Drive data is now linked live rather than imported.
GoogleDriveDSNDRIVER={ZappySys API Driver};ServiceUrl=https://www.googleapis.com/;Provider=GoogleSheets;ScopeSeparator={space};RetryMode=[$RetryMode$];RetryStatusCodeList=[$RetryStatusCodeList$]
Google Drive Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Google Drive operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Drive account info
- Lists shared drives
- List files (Recursive)
- List files / folders from a parent folder (Recursive)
- Search items (i.e. files / folders)
- List folders
- List deleted files / folders
- Get file info
- Download a file
- Export a file
- Upload a file
- Upload a file (with overwrite action)
- Create a folder
- Delete an item
- Duplicate a file
- Replace file data (keep same file id)
- Update metadata in a file
- Empty trash
- Delete all items
In some situations, you may need to provide Google Drive data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Google Drive data source in the gateway
In this section we will create a data source for Google Drive in the Data Gateway. Let's follow these steps to accomplish that:
GoogleDriveDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Google Drive ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
GoogleDriveDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - Google DriveRead and write Google Drive data effortlessly. Integrate, manage, and automate files, folders, and shared drives — almost no coding required.GoogleDriveDSN
GoogleDriveDSN(the one we used in the Data Gateway):GoogleDriveDSNGoogleDriveDSN
Finally, we are ready to read data from Google Drive in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Google Drive data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Google Drive in Power BI and integrate your data — all without writing complex code.
