You can connect to your Starburst data from Power BI via the high-performance Starburst ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Starburst
- Working with Starburst data directly inside Power BI
Minimum required version: Java 11
Download Starburst JDBC driver
To connect to Starburst, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Starburst website or MVN Repository.
C:\ZappySys\Jdbc\Starburst\trino-jdbc-476.jar.
Create data source using Starburst ODBC Driver
To get data from Starburst using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Starburst.
Non-SSL connection
Starburst authentication
Starburst from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Note coordinator host and HTTP port (often
8080for lab,443for Cloud TLS). - Create an application user if the cluster requires a password. Some labs allow any user with an empty password.
- After Finish, set catalog/schema on the DSN Main UI or qualify tables as
tpch.sf1.orders. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:trino://[$HostName$]:[$Port$] -
Driver class :io.trino.jdbc.TrinoDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Starburst\trino-jdbc-476.jar -
Host :MyHostName -
TCP port :443 -
User name : -
Password :
StarburstDSNjdbc:trino://[$HostName$]:[$Port$]io.trino.jdbc.TrinoDriverC:\ZappySys\Jdbc\Starburst\trino-jdbc-476.jaroptional for Starburst
Find full details in the Starburst Connector authentication reference.SSL connection
Starburst with TLS from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Same as Non-SSL Auth. Use port 443 (or your TLS port) and
SSL=true. - Fill user and password from the coordinator or Starburst Galaxy/Galaxy-like console.
Connection string :jdbc:trino://[$HostName$]:[$Port$]?SSL=[$Ssl$] -
Host :MyHostName -
TCP port :443 -
SSL :true -
User name : -
Password :
StarburstDSNjdbc:trino://[$HostName$]:[$Port$]?SSL=[$Ssl$]io.trino.jdbc.TrinoDriverC:\ZappySys\Jdbc\Starburst\trino-jdbc-476.jaroptional for Starburst
Find full details in the Starburst Connector authentication reference. -
StarburstDSNSELECT * FROM tpch.sf1.orders
SELECT * FROM tpch.sf1.ordersYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Starburst data in Power BI
Another window opens and asks to select a Data Source we already created. Choose StarburstDSN and continue:
StarburstDSN
StarburstDSN
Finally, finally, read extracted data from Starburst in a Power BI report:
If you wish to import Starburst data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Starburst ODBC data source:
ODBC{"connectionstring":"dsn=StarburstDSN"}
dsn=StarburstDSN
dsn=StarburstDSN
= Odbc.Query("dsn=StarburstDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Starburst data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_STARBURST_IN_GATEWAY], 'SELECT * FROM tpch.sf1.orders')
SELECT * FROM OPENQUERY([LS_TO_STARBURST_IN_GATEWAY], 'SELECT * FROM tpch.sf1.orders') - Click OK and load the data. Your Starburst data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - StarburstQuery Starburst catalogs from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.StarburstDSN
StarburstDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:trino://[$HostName$]:[$Port$]';ClassName='io.trino.jdbc.TrinoDriver';DriverPath='C:\ZappySys\Jdbc\Starburst\trino-jdbc-476.jar';UserName='';UserPassword='';ConnParams='optional for Starburst'
Open DBeaver.
io.trino.jdbc.TrinoDriver):
Go to the Libraries tab, click Add File, and select your Starburst driver library file(s), e.g.
C:\ZappySys\Jdbc\Starburst\trino-jdbc-476.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:trino://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Starburst data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Starburst data source in the gateway
In this section we will create a data source for Starburst in the Data Gateway. Let's follow these steps to accomplish that:
StarburstDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Starburst ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
StarburstDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - StarburstQuery Starburst catalogs from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.StarburstDSN
StarburstDSN(the one we used in the Data Gateway):StarburstDSNStarburstDSN
Finally, we are ready to read data from Starburst in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Starburst data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Starburst in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Starburst, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
