You can connect to your Apache Derby data from Talend Studio via the high-performance Apache Derby ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Apache Derby JDBC driver
To connect to Apache Derby, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Apache Derby website or MVN Repository.
Download the JDBC drivers, and save them locally.
In this section we will create a data source for Apache Derby in the Data Gateway. Let's follow these steps to accomplish that:
ApacheDerbyDSNZappySys JDBC Bridge Driver
- Configure the authentication in Apache Derby.
Client/server
Apache Derby authentication
Apache Derby network server from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Start Network Server (default port
1527) or use an existing one. - Create a database user if authentication is on. Lab often uses a simple user/password.
- Seed Driver class as
ClientDriver(SPI can also load EmbeddedDriver). - After Finish, replace the host (e.g. MyHostName) and database name (e.g. MyDatabase) on the DSN Main UI.
Connection string :jdbc:derby://[$HostName$]:[$Port$]/[$Database$] -
Driver class :org.apache.derby.jdbc.ClientDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Derby\derbyclient-10.14.2.0.jar -
Host :MyHostName -
TCP port :1527 -
Database name :MyDatabase -
User name : -
Password :
ApacheDerbyDSNjdbc:derby://[$HostName$]:[$Port$]/[$Database$]org.apache.derby.jdbc.ClientDriverC:\ZappySys\Jdbc\Apache Derby\derbyclient-10.14.2.0.jaroptional for Apache Derby
Find full details in the Apache Derby Connector authentication reference.Embedded file
Apache Derby embedded from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- No server. The database folder is created under
C:\ZappySys\Jdbc\Apache Derby. - Use
EmbeddedDriver(do not leave class blank -- SPI is ambiguous with the client JAR). - Optional: add
;create=true(already in this URL) the first time. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:derby:C:\ZappySys\Jdbc\Apache Derby\mydatabase;create=true -
Driver class :org.apache.derby.jdbc.EmbeddedDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Derby\derby-10.14.2.0.jar
ApacheDerbyDSNjdbc:derby:C:\ZappySys\Jdbc\Apache Derby\mydatabase;create=trueorg.apache.derby.jdbc.EmbeddedDriverC:\ZappySys\Jdbc\Apache Derby\derby-10.14.2.0.jaroptional for Apache Derbyoptional for Apache Derbyoptional for Apache Derby
Find full details in the Apache Derby Connector authentication reference.In-memory
Apache Derby in-memory from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Data lasts for this DSN Java process only.
- Keep EmbeddedDriver. Use for labs and Excel previews.
Connection string :jdbc:derby:memory:[$Database$];create=true -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Derby\derby-10.14.2.0.jar -
ApacheDerbyDSNjdbc:derby:memory:[$Database$];create=trueorg.apache.derby.jdbc.EmbeddedDriverC:\ZappySys\Jdbc\Apache Derby\derby-10.14.2.0.jaroptional for Apache Derbyoptional for Apache Derbyoptional for Apache Derby
Find full details in the Apache Derby Connector authentication reference. -
ApacheDerbyDSNSELECT * FROM "APP"."ORDERS"
SELECT * FROM "APP"."ORDERS"You can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Read Apache Derby data in Talend Studio
To read Apache Derby data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
ApacheDerbyDSN
Add input
Add output
Run the job
Finally, run the job and integrate your Apache Derby data:
Open DBeaver.
org.apache.derby.jdbc.ClientDriver):
Go to the Libraries tab, click Add File, and select your Apache Derby driver library file(s), e.g.
C:\ZappySys\Jdbc\Apache Derby\derbyclient-10.14.2.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:derby://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In this guide, we demonstrated how to connect to Apache Derby in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Derby, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
