You can connect to your Apache Spark data from Excel via the high-performance Apache Spark ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Apache Spark JDBC driver
To connect to Apache Spark, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Spark website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar.
  4. Download the standalone Hive JDBC JAR so you do not have to assemble Hadoop dependencies, e.g. hive-jdbc-4.2.0-standalone.jar (commonly used to connect to Spark Thrift Server).
  5. Done! That was easy, wasn't it? Let's proceed to the next step.
Create data source using Apache Spark ODBC Driver
Watch this quick walkthrough to see how to configure your Apache Spark ODBC data source, or scroll down for the step-by-step written guide.
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Spark.
To get data from Apache Spark using Excel, we first need to create an ODBC data source. We will later read this data in Excel. Perform these steps:
    • Configure the authentication in Apache Spark.
    Thrift Server
    Apache Spark authentication
    Spark Thrift Server from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Start Spark Thrift Server or note the existing host and HS2 port (default 10000).
    2. Download the standalone Hive JDBC JAR (the wizard does this). Do not mix a partial Hadoop classpath.
    3. Create a user if the cluster uses auth; otherwise leave user/password empty.
    4. After Finish, replace the host (e.g. MyHostName) on the DSN Main UI.
    3. Finally, hit OK button:
    • Connection string: jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]
    • Driver class: org.apache.hive.jdbc.HiveDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar
    • Host: MyHostName
    • TCP port: 10000
    • Database name: MyDatabase
    • User name:
    • Password:
    ApacheSparkDSN
    optional for Apache Spark
    Find full details in the Apache Spark Connector authentication reference.
    Thrift Server (SSL)
    Spark Thrift Server with SSL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Same as Default Auth, plus TLS. Fill LDAP/Hive user and password.
    2. Do not use a personal employee login for unattended Power BI or Linked Server refresh.
    • Connection string: jdbc:hive2://[$HostName$]:[$Port$]/[$Database$];ssl=[$Ssl$]
    • Host: MyHostName
    • TCP port: 10000
    • SSL: true
    • User name:
    • Password:
    ApacheSparkDSN
    Jump to troubleshooter
    ApacheSparkDSN
        id,
        name,
        salary
    FROM employees
    WHERE department = 'Sales';
        id,
        name,
        salary
    FROM employees
Read data in Excel from the DSN
  1. In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from ODBC data source we created:
    Create ODBC data source in Excel
  2. A small window opens, then simply select the data source you created in previous steps:
    ApacheSparkDSN
    Select DSN data source in Excel
  3. Most likely, you will be asked to authenticate to a newly created DSN. Just select Windows authentication option together with Use my current credentials option:
    ApacheSparkDSN
    Excel DSN Authentication
  4. Finally, you will be asked to select a table or view to get data from. Select one and load the data!
  5. Finally, finally, use data extracted from Apache Spark API in an Excel worksheet:
    Excel Select DSN Table
Refresh data source in Excel
When data updates in Apache Spark, it is not automatically refreshed in Excel. To update the worksheet, go to Data or Table Design tab and click the Refresh button:
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.hive.jdbc.HiveDriver):
  6. Go to the Libraries tab, click Add File, and select your Apache Spark driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Spark data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in Excel (client-side) to connect to it.
Create Apache Spark data source in the gateway
In this section we will create a data source for Apache Spark in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheSparkDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Spark ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ZappySys JDBC Bridge Driver - Apache Spark
      Query Apache Spark Thrift Server (HiveServer2 protocol) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
      ApacheSparkDSN
      ApacheSparkDSN
      ApacheSparkDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from Excel. To achieve that, let's perform these steps:
  5. Then set the default database property to ApacheSparkDSN (the one we used in the Data Gateway):
    ApacheSparkDSN
    ApacheSparkDSN
Access data in Excel via the gateway
Finally, we are ready to read data from Apache Spark in Excel via the Data Gateway. Follow these final steps:
  1. Go back to Excel.
  2. In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from ODBC data source we created:
  3. A small window opens, then simply select the data source you created in previous steps:
  4. Read the data the same way we discussed at the beginning of this article.
  5. That's it!
Now you can connect to Apache Spark data in Excel via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Spark in Excel and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Spark, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
