You can connect to your Apache Spark data from Talend Studio via the high-performance Apache Spark ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Apache Spark JDBC driver
To connect to Apache Spark, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Spark website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar.
  4. Download the standalone Hive JDBC JAR so you do not have to assemble Hadoop dependencies, e.g. hive-jdbc-4.2.0-standalone.jar (commonly used to connect to Spark Thrift Server).
  5. Done! That was easy, wasn't it? Let's proceed to the next step.
In this section we will create a data source for Apache Spark in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheSparkDSN
    • Configure the authentication in Apache Spark.
    Thrift Server
    Apache Spark authentication
    Spark Thrift Server from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Start Spark Thrift Server or note the existing host and HS2 port (default 10000).
    2. Download the standalone Hive JDBC JAR (the wizard does this). Do not mix a partial Hadoop classpath.
    3. Create a user if the cluster uses auth; otherwise leave user/password empty.
    4. After Finish, replace the host (e.g. MyHostName) on the DSN Main UI.
    3. Finally, hit OK button:
    • Connection string: jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]
    • Driver class: org.apache.hive.jdbc.HiveDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar
    • Host: MyHostName
    • TCP port: 10000
    • Database name: MyDatabase
    • User name:
    • Password:
    ApacheSparkDSN
    optional for Apache Spark
    Find full details in the Apache Spark Connector authentication reference.
    Thrift Server (SSL)
    Spark Thrift Server with SSL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Same as Default Auth, plus TLS. Fill LDAP/Hive user and password.
    2. Do not use a personal employee login for unattended Power BI or Linked Server refresh.
    • Connection string: jdbc:hive2://[$HostName$]:[$Port$]/[$Database$];ssl=[$Ssl$]
    • Host: MyHostName
    • TCP port: 10000
    • SSL: true
    • User name:
    • Password:
    ApacheSparkDSN
    Jump to troubleshooter
    ApacheSparkDSN
        id,
        name,
        salary
    FROM employees
    WHERE department = 'Sales';
        id,
        name,
        salary
    FROM employees
Read Apache Spark data in Talend Studio
To read Apache Spark data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    ApacheSparkDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your Apache Spark data: Integrating Apache Spark data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.hive.jdbc.HiveDriver):
  6. Go to the Libraries tab, click Add File, and select your Apache Spark driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Spark\hive-jdbc-4.2.0-standalone.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:hive2://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to Apache Spark in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Spark, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
