You can connect to your Apache Drill data from Talend Studio via the high-performance Apache Drill ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Apache Drill JDBC driver
To connect to Apache Drill, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Apache Drill website or MVN Repository.
C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar.
In this section we will create a data source for Apache Drill in the Data Gateway. Let's follow these steps to accomplish that:
ApacheDrillDSNZappySys JDBC Bridge Driver
- Configure the authentication in Apache Drill.
Drillbit
Apache Drill authentication
Apache Drill JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Note the Drillbit host and JDBC port (default
31010). - Create a Drill user if authentication is enabled, or leave user/password empty for anonymous clusters.
- Replace
hostnamein the JDBC URL. Enable SSL only if your cluster requires it (see the Drill JDBC docs). - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:drill:drillbit=[$HostName$]:[$Port$] -
Driver class :org.apache.drill.jdbc.Driver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar -
Host :MyHostName -
TCP port :31010 -
User name : -
Password :
ApacheDrillDSNjdbc:drill:drillbit=[$HostName$]:[$Port$]org.apache.drill.jdbc.DriverC:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jaroptional for Apache Drill
Find full details in the Apache Drill Connector authentication reference.ZooKeeper
Apache Drill (ZooKeeper) JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Get the ZooKeeper quorum and Drill cluster path from your ops team (often
/drill/drillbits1). - Replace host and path in the JDBC URL. User/password only if Drill auth is on.
Connection string :jdbc:drill:zk=[$HostName$]:[$Port$]/drill/drillbits1 -
Host :MyHostName -
TCP port :31010 -
User name : -
Password :
ApacheDrillDSNjdbc:drill:zk=[$HostName$]:[$Port$]/drill/drillbits1org.apache.drill.jdbc.DriverC:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jaroptional for Apache Drill
Find full details in the Apache Drill Connector authentication reference. -
ApacheDrillDSNSHOW DATABASES
SHOW DATABASESYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Read Apache Drill data in Talend Studio
To read Apache Drill data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
ApacheDrillDSN
Add input
Add output
Run the job
Finally, run the job and integrate your Apache Drill data:
Open DBeaver.
org.apache.drill.jdbc.Driver):
Go to the Libraries tab, click Add File, and select your Apache Drill driver library file(s), e.g.
C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:drill:drillbit=[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In this guide, we demonstrated how to connect to Apache Drill in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Drill, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
