You can connect to your Apache Drill data from C# via the high-performance Apache Drill ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Apache Drill JDBC driver
To connect to Apache Drill, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Apache Drill website or MVN Repository.
C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar.
Create data source using Apache Drill ODBC Driver
Watch this quick walkthrough to see how to configure your Apache Drill ODBC data source, or scroll down for the step-by-step written guide.
To get data from Apache Drill using C#, we first need to create an ODBC data source. We will later read this data in C#. Perform these steps:
- Configure the authentication in Apache Drill.
Drillbit
Apache Drill authentication
Apache Drill JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Note the Drillbit host and JDBC port (default
31010). - Create a Drill user if authentication is enabled, or leave user/password empty for anonymous clusters.
- Replace
hostnamein the JDBC URL. Enable SSL only if your cluster requires it (see the Drill JDBC docs). - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:drill:drillbit=[$HostName$]:[$Port$] -
Driver class :org.apache.drill.jdbc.Driver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar -
Host :MyHostName -
TCP port :31010 -
User name : -
Password :
ApacheDrillDSNjdbc:drill:drillbit=[$HostName$]:[$Port$]org.apache.drill.jdbc.DriverC:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jaroptional for Apache Drill
Find full details in the Apache Drill Connector authentication reference.ZooKeeper
Apache Drill (ZooKeeper) JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Get the ZooKeeper quorum and Drill cluster path from your ops team (often
/drill/drillbits1). - Replace host and path in the JDBC URL. User/password only if Drill auth is on.
Connection string :jdbc:drill:zk=[$HostName$]:[$Port$]/drill/drillbits1 -
Host :MyHostName -
TCP port :31010 -
User name : -
Password :
ApacheDrillDSNjdbc:drill:zk=[$HostName$]:[$Port$]/drill/drillbits1org.apache.drill.jdbc.DriverC:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jaroptional for Apache Drill
Find full details in the Apache Drill Connector authentication reference. -
ApacheDrillDSNSHOW DATABASES
SHOW DATABASESYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Read data in C#
Using ODBC DSN
Use this code snippet to read the data using
ApacheDrillDSNdata source:"ApacheDrillDSN" ;
Press F5 to run the code and read the data:
Here is the code in text format:
using System; using System.Data.Odbc; namespace ConsoleApp { class Program { static void Main() { var dsn = "ApacheDrillDSN"; using (var conn = new OdbcConnection(String.Format("DSN={0}", dsn))) { conn.Open(); var cmd = new OdbcCommand("SELECT * FROM Products", conn); //Increase the timeout duration from the default 30 seconds, which may be insufficient in certain scenarios cmd.CommandTimeout=600; // 600-Seconds var rdr = cmd.ExecuteReader(); while (rdr.Read()) { for (int i = 0; i < rdr.FieldCount; i++) { Console.Write("{0}\t", rdr[i]); } Console.WriteLine(); } } Console.ReadKey(); } } }
Using a full ODBC connection string
If you want to avoid being dependent on a DSN and creating multiple DSNs for each platform (x86, x64), then you can use a fully qualified connection string. Simply go to your DSN and copy the Connection String:
ZappySys JDBC Bridge Driver - Apache DrillQuery files, Hive, and S3 with Apache Drill SQL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheDrillDSN
Then in your C# code, pass the connection string as an argument when calling the OdbcConnection object's constructor, for example:
var connectionString = @"DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:drill:drillbit=[$HostName$]:[$Port$]';ClassName='org.apache.drill.jdbc.Driver';DriverPath='C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar';UserName='';UserPassword='';ConnParams='optional for Apache Drill'"; using (var conn = new OdbcConnection(connectionString)) { // your code goes here }
DRIVER={ZappySys JDBC Bridge Driver};SettingsFile=C:\temp\odbc-connection-string.txt - Our troubles are over! Now you should be able to use this connection string in C# with no problems.
Open DBeaver.
org.apache.drill.jdbc.Driver):
Go to the Libraries tab, click Add File, and select your Apache Drill driver library file(s), e.g.
C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:drill:drillbit=[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Apache Drill data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in C# (client-side) to connect to it.
Create Apache Drill data source in the gateway
In this section we will create a data source for Apache Drill in the Data Gateway. Let's follow these steps to accomplish that:
ApacheDrillDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Drill ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ApacheDrillDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Apache DrillQuery files, Hive, and S3 with Apache Drill SQL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheDrillDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from C#. To achieve that, let's perform these steps:
ApacheDrillDSN(the one we used in the Data Gateway):ApacheDrillDSNApacheDrillDSN
Access data in C# via the gateway
Finally, we are ready to read data from Apache Drill in C# via the Data Gateway. Follow these final steps:
Go back to C#.
ZappySysGatewayDSNdata source:"ZappySysGatewayDSN" ;
Now you can connect to Apache Drill data in C# via the ZappySys Data Gateway.
john and your password.
In this guide, we demonstrated how to connect to Apache Drill using C# and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Drill, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
