You can connect to your Apache Drill data from Excel via the high-performance Apache Drill ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Apache Drill JDBC driver
To connect to Apache Drill, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Drill website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar.
Create data source using Apache Drill ODBC Driver
Watch this quick walkthrough to see how to configure your Apache Drill ODBC data source, or scroll down for the step-by-step written guide.
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Drill.
To get data from Apache Drill using Excel, we first need to create an ODBC data source. We will later read this data in Excel. Perform these steps:
    • Configure the authentication in Apache Drill.
    Drillbit
    Apache Drill authentication
    Apache Drill JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Note the Drillbit host and JDBC port (default 31010).
    2. Create a Drill user if authentication is enabled, or leave user/password empty for anonymous clusters.
    3. Replace hostname in the JDBC URL. Enable SSL only if your cluster requires it (see the Drill JDBC docs).
    3. Finally, hit OK button:
    • Connection string: jdbc:drill:drillbit=[$HostName$]:[$Port$]
    • Driver class: org.apache.drill.jdbc.Driver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar
    • Host: MyHostName
    • TCP port: 31010
    • User name:
    • Password:
    ApacheDrillDSN
    optional for Apache Drill
    Find full details in the Apache Drill Connector authentication reference.
    ZooKeeper
    Apache Drill (ZooKeeper) JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Get the ZooKeeper quorum and Drill cluster path from your ops team (often /drill/drillbits1).
    2. Replace host and path in the JDBC URL. User/password only if Drill auth is on.
    • Connection string: jdbc:drill:zk=[$HostName$]:[$Port$]/drill/drillbits1
    • Host: MyHostName
    • TCP port: 31010
    • User name:
    • Password:
    ApacheDrillDSN
    Jump to troubleshooter
    ApacheDrillDSN
    SHOW DATABASES
    SHOW DATABASES
Read data in Excel from the DSN
  1. In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from ODBC data source we created:
    Create ODBC data source in Excel
  2. A small window opens, then simply select the data source you created in previous steps:
    ApacheDrillDSN
    Select DSN data source in Excel
  3. Most likely, you will be asked to authenticate to a newly created DSN. Just select Windows authentication option together with Use my current credentials option:
    ApacheDrillDSN
    Excel DSN Authentication
  4. Finally, you will be asked to select a table or view to get data from. Select one and load the data!
  5. Finally, finally, use data extracted from Apache Drill API in an Excel worksheet:
    Excel Select DSN Table
Refresh data source in Excel
When data updates in Apache Drill, it is not automatically refreshed in Excel. To update the worksheet, go to Data or Table Design tab and click the Refresh button:
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.drill.jdbc.Driver):
  6. Go to the Libraries tab, click Add File, and select your Apache Drill driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Drill\drill-jdbc-all-1.22.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:drill:drillbit=[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Drill data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in Excel (client-side) to connect to it.
Create Apache Drill data source in the gateway
In this section we will create a data source for Apache Drill in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheDrillDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Drill ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ZappySys JDBC Bridge Driver - Apache Drill
      Query files, Hive, and S3 with Apache Drill SQL from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
      ApacheDrillDSN
      ApacheDrillDSN
      ApacheDrillDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from Excel. To achieve that, let's perform these steps:
  5. Then set the default database property to ApacheDrillDSN (the one we used in the Data Gateway):
    ApacheDrillDSN
    ApacheDrillDSN
Access data in Excel via the gateway
Finally, we are ready to read data from Apache Drill in Excel via the Data Gateway. Follow these final steps:
  1. Go back to Excel.
  2. In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from ODBC data source we created:
  3. A small window opens, then simply select the data source you created in previous steps:
  4. Read the data the same way we discussed at the beginning of this article.
  5. That's it!
Now you can connect to Apache Drill data in Excel via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Drill in Excel and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Drill, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
