You can connect to your OData data from Talend Studio via the high-performance OData ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for OData in the Data Gateway. Let's follow these steps to accomplish that:
    OdataDSN
  5. When the Configuration window appears give your data source a name if you haven't done that already, then select "OData" from the list of Popular Connectors. If "OData" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    OdataDSN
    OData
    • Configure the authentication in OData.
    No Authentication
    OData authentication
    No instructions available.
    1. Set Authentication Type to No Authentication [Http]
    OdataDSN
    OData
    https://services.odata.org/V3/Northwind/Northwind.svc
    IgnoreSSLCertificateErrors
    SslVersion
    Find full details in the OData Connector authentication reference.
    Windows Authentication
    1. Set Authentication Type to Windows Authentication [Http]
    OdataDSN
    OData
    There are no parameters to configure.
    Basic Authentication
    1. Set Authentication Type to Basic Authentication [Http]
    OdataDSN
    OData
    SslVersion
    NTLM Authentication
    1. Set Authentication Type to NTLM Authentication [Http]
    OdataDSN
    OData
    UserName (i.e. Domain\UserName) Fill-in the parameter...
    SslVersion
    Token Authentication
    1. Set Authentication Type to Token Authentication [Http]
    OdataDSN
    OData
    AuthScheme Bearer
    AuthHeader Authorization
    SslVersion
    OAuth Connection for OData API
    1. Set Authentication Type to OAuth Connection for OData API [OAuth]
    OdataDSN
    OData
    GrantType Default
    OAuthVersion Default
    ClientId
    ClientSecret
    UserName
    Password
    Scope
    AuthUrl https://some-domain.com/api/auth
    TokenUrl https://some-domain.com/api/token
    ReturnUrl https://zappysys.com/oauth
    ExtraAttributesForTokenRequest
    ExtraAttributesForAuthRequest
    DoNotIncludeCredentialsInHeader
    DoNotIncludeCredentialsInBody
    RenewBeforeSec
    ExtraHeaders (e.g. x-hdr1:AAA||x-hdr2:BBB)
    ContentType
    EnableCodeVerifier
    RemoveAuthHeader
    CustomAuthHeader
    CustomTokenPrefix
    SslVersion
    ZappySys API Driver - OData
    Read and write OData API data effortlessly. Query, integrate, and manage entities and feeds — almost no coding required.
    OdataDSN
  8. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from OData. Hit OK button to use this query in the next step.
    SELECT * FROM Customers
    Some parameters configured in this window will be passed to the OData API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    OdataDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the OData API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in OData servers).
Read OData data in Talend Studio
To read OData data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    OdataDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your OData data: Integrating OData data in Talend Studio
OData Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential OData operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In this guide, we demonstrated how to connect to OData in Talend Studio and integrate your data — all without writing complex code.
