You can connect to your Trino data from Talend Studio via the high-performance Trino ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Trino JDBC driver
To connect to Trino, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Trino website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Trino\trino-jdbc-476.jar.
In this section we will create a data source for Trino in the Data Gateway. Let's follow these steps to accomplish that:
    TrinoDSN
    • Configure the authentication in Trino.
    Non-SSL connection
    Trino authentication
    Trino from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Note coordinator host and HTTP port (often 8080 for lab, 443 for Cloud TLS).
    2. Create an application user if the cluster requires a password. Some labs allow any user with an empty password.
    3. After Finish, set catalog/schema on the DSN Main UI or qualify tables as tpch.sf1.orders.
    3. Finally, hit OK button:
    • Connection string: jdbc:trino://[$HostName$]:[$Port$]
    • Driver class: io.trino.jdbc.TrinoDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Trino\trino-jdbc-476.jar
    • Host: MyHostName
    • TCP port: 8080
    • User name:
    • Password:
    TrinoDSN
    optional for Trino
    Find full details in the Trino Connector authentication reference.
    SSL connection
    Trino with TLS from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Same as Non-SSL Auth. Use port 443 (or your TLS port) and SSL=true.
    2. Fill user and password from the coordinator or Starburst Galaxy/Galaxy-like console.
    • Connection string: jdbc:trino://[$HostName$]:[$Port$]?SSL=[$Ssl$]
    • Host: MyHostName
    • TCP port: 443
    • SSL: true
    • User name:
    • Password:
    TrinoDSN
    optional for Trino
    Jump to troubleshooter
    TrinoDSN
    SELECT * FROM tpch.sf1.orders
Read Trino data in Talend Studio
To read Trino data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    TrinoDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your Trino data: Integrating Trino data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (io.trino.jdbc.TrinoDriver):
  6. Go to the Libraries tab, click Add File, and select your Trino driver library file(s), e.g. C:\ZappySys\Jdbc\Trino\trino-jdbc-476.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:trino://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to Trino in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Trino, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
