You can connect to your Neo4j data from Talend Studio via the high-performance Neo4j ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Neo4j JDBC driver
To connect to Neo4j, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Neo4j website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Neo4j\neo4j-jdbc-full-bundle-6.3.1.jar.
In this section we will create a data source for Neo4j in the Data Gateway. Let's follow these steps to accomplish that:
    Neo4jDSN
    • Configure the authentication in Neo4j.
    Non-SSL Connection (SQL queries)
    Neo4j authentication
    Neo4j JDBC (full bundle) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. This Auth sets enableSQLTranslation=true so you can run SQL such as SELECT * FROM Movie from Power BI.
    2. Create a database user in Neo4j Desktop, Aura console, or CREATE USER. Paste user and password.
    3. After Finish, replace the host (e.g. MyHostName) on the DSN Main UI. Aura always uses TLS (neo4j+s).
    4. Do not use a personal employee login for unattended Linked Server or Power BI refresh.
    3. Finally, hit OK button:
    • Connection string: jdbc:neo4j://[$HostName$]:[$Port$]?enableSQLTranslation=true
    • Driver class: org.neo4j.jdbc.Neo4jDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Neo4j\neo4j-jdbc-full-bundle-6.3.1.jar
    • Host: MyHostName
    • TCP port: 7687
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    Find full details in the Neo4j Connector authentication reference.
    Non-SSL Connection (Cypher queries)
    1. This Auth omits SQL translation. Use Cypher (MATCH ... RETURN) from the DSN query window.
    • Host: MyHostName
    • TCP port: 7687
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    • Connection string: jdbc:neo4j+s://[$HostName$]:[$Port$]?enableSQLTranslation=true
    • Host: MyHostName
    • TCP port: 7687
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    • Host: MyHostName
    • TCP port: 7687
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    Neo4j AuraDB Connection (SQL queries)
    1. Copy the Aura connection URI host (something like 1234abcd.databases.neo4j.io). This Auth uses neo4j+s plus SQL translation.
    • Connection string: jdbc:neo4j+s://[$HostName$]?enableSQLTranslation=true
    • Host: MyHostName
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    Neo4j Aura Connection (Cypher queries)
    1. Same Aura host as SQL Auth, but Cypher only (no SQL translation).
    • Host: MyHostName
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    Jump to troubleshooter
    Neo4jDSN
    SELECT * FROM Movie
    SELECT * FROM Movie
Read Neo4j data in Talend Studio
To read Neo4j data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    Neo4jDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your Neo4j data: Integrating Neo4j data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.neo4j.jdbc.Neo4jDriver):
  6. Go to the Libraries tab, click Add File, and select your Neo4j driver library file(s), e.g. C:\ZappySys\Jdbc\Neo4j\neo4j-jdbc-full-bundle-6.3.1.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:neo4j://[$HostName$]:[$Port$]?enableSQLTranslation=true), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to Neo4j in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Neo4j, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
