You can connect to your HSQLDB data from Talend Studio via the high-performance HSQLDB ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download HSQLDB JDBC driver
To connect to HSQLDB, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit HSQLDB website or MVN Repository.
C:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jar.
In this section we will create a data source for HSQLDB in the Data Gateway. Let's follow these steps to accomplish that:
HsqldbDSNZappySys JDBC Bridge Driver
- Configure the authentication in HSQLDB.
In-memory
HSQLDB authentication
HSQLDB in-memory JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- No server. Data lasts for this DSN process only.
- Default user is often
SAwith empty password. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:hsqldb:mem:[$Database$] -
Driver class :org.hsqldb.jdbc.JDBCDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jar -
Database name :MyDatabase -
User name : -
Password :
HsqldbDSNjdbc:hsqldb:mem:[$Database$]org.hsqldb.jdbc.JDBCDriverC:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jaroptional for HSQLDB
Find full details in the HSQLDB Connector authentication reference.Local file
HSQLDB file JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- The wizard downloads the JDK 8 JAR into
C:\ZappySys\Jdbc\HSQLDB. The database files are created ashsqldb.*in that folder. - Default user
SA/ empty password unless you set one. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:hsqldb:file:C:\ZappySys\Jdbc\HSQLDB\hsqldb -
User name : -
Password :
HsqldbDSNjdbc:hsqldb:file:C:\ZappySys\Jdbc\HSQLDB\hsqldborg.hsqldb.jdbc.JDBCDriverC:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jaroptional for HSQLDB
Find full details in the HSQLDB Connector authentication reference.HSQL server
HSQLDB server JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Start an HSQL server (default port
9001) or use an existing one. - Replace host, port, and catalog. Fill user and password from that server.
Connection string :jdbc:hsqldb:hsql://[$HostName$]:[$Port$]/[$Database$] -
Host :MyHostName -
TCP port :9001 -
User name : -
Password :
HsqldbDSNjdbc:hsqldb:hsql://[$HostName$]:[$Port$]/[$Database$]org.hsqldb.jdbc.JDBCDriverC:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jaroptional for HSQLDB
Find full details in the HSQLDB Connector authentication reference. -
HsqldbDSNSELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'PUBLIC' ORDER BY TABLE_NAME
SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'PUBLIC' ORDER BY TABLE_NAMEYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Read HSQLDB data in Talend Studio
To read HSQLDB data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
HsqldbDSN
Add input
Add output
Run the job
Finally, run the job and integrate your HSQLDB data:
Open DBeaver.
org.hsqldb.jdbc.JDBCDriver):
Go to the Libraries tab, click Add File, and select your HSQLDB driver library file(s), e.g.
C:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:hsqldb:mem:[$Database$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In this guide, we demonstrated how to connect to HSQLDB in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to HSQLDB, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
