You can connect to your H2 data from Talend Studio via the high-performance H2 ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download H2 JDBC driver
To connect to H2, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit H2 website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\H2\h2-2.3.232.jar.
In this section we will create a data source for H2 in the Data Gateway. Let's follow these steps to accomplish that:
    H2DSN
    • Configure the authentication in H2.
    In-memory
    H2 authentication
    H2 in-memory JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. No server to install. Data lives in the Java process for this DSN and is gone when the connection closes unless you add DB_CLOSE_DELAY=-1.
    2. Optional user/password: default lab user is often sa with empty password.
    3. Finally, hit OK button:
    • Connection string: jdbc:h2:mem:[$Database$]
    • Driver class: org.h2.Driver
    • JDBC driver file(s): C:\ZappySys\Jdbc\H2\h2-2.3.232.jar
    • Database name: MyDatabase
    • User name:
    • Password:
    H2DSN
    org.h2.Driver
    optional for H2
    Find full details in the H2 Connector authentication reference.
    Local file
    H2 authentication
    H2 file JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. The wizard downloads the H2 JAR into C:\ZappySys\Jdbc\H2. The database file is created next to it as h2db.mv.db.
    2. Point the URL at another folder after Finish if you already have an H2 file.
    3. Optional user/password (sa / empty is common for local files).
    • Connection string: jdbc:h2:file:C:\ZappySys\Jdbc\H2\h2db
    • User name:
    • Password:
    H2DSN
    org.h2.Driver
    optional for H2
    TCP server
    H2 authentication
    H2 TCP JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Start the H2 server (default TCP 9092) or connect to an existing one.
    2. Replace the host (e.g. MyHostName), port (e.g. 9092), and database path. Fill user and password from that server.
    • Connection string: jdbc:h2:tcp://[$HostName$]:[$Port$]/~/[$Database$]
    • Host: MyHostName
    • TCP port: 9092
    • User name:
    • Password:
    H2DSN
    org.h2.Driver
    optional for H2
    Jump to troubleshooter
    H2DSN
    SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'PUBLIC' ORDER BY TABLE_NAME
Read H2 data in Talend Studio
To read H2 data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    H2DSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your H2 data: Integrating H2 data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.h2.Driver):
    org.h2.Driver
  6. Go to the Libraries tab, click Add File, and select your H2 driver library file(s), e.g. C:\ZappySys\Jdbc\H2\h2-2.3.232.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:h2:mem:[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to H2 in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to H2, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
