You can connect to your DuckDB (Parquet) data from Talend Studio via the high-performance DuckDB (Parquet) ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download DuckDB (Parquet) JDBC driver
To connect to DuckDB (Parquet), you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit DuckDB (Parquet) website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\DuckDB (Parquet)\duckdb_jdbc-1.4.5.0.jar.
In this section we will create a data source for DuckDB (Parquet) in the Data Gateway. Let's follow these steps to accomplish that:
    DuckdbParquetDSN
    • Configure the authentication in DuckDB (Parquet).
    In-Memory Connection
    DuckDB (Parquet) authentication
    Query Parquet with DuckDB JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. The wizard downloads DuckDB JDBC 1.4.5.0 (LTS) and the Titanic sample Parquet into C:\ZappySys\Jdbc\DuckDB (Parquet).
    2. This Auth is in-memory (jdbc:duckdb:memory:). After Finish, query the sample with SELECT * FROM "C:\ZappySys\Jdbc\DuckDB (Parquet)\titanic.parquet".
    3. Use the File Auth if you want a persistent .duckdb database instead of memory.
    3. Finally, hit OK button:
    • Connection string: jdbc:duckdb:memory:
    • Driver class: org.duckdb.DuckDBDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\DuckDB (Parquet)\duckdb_jdbc-1.4.5.0.jar
    DuckdbParquetDSN
    jdbc:duckdb:memory:
    optional for DuckDB (Parquet)
    Find full details in the DuckDB (Parquet) Connector authentication reference.
    Local DuckDB file
    Persistent DuckDB file from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. The wizard still downloads the JDBC JAR (and Titanic sample) into C:\ZappySys\Jdbc\DuckDB (Parquet).
    2. After Finish, point the JDBC URL at your .duckdb file if you do not want mydb.duckdb.
    3. You can still query Parquet with SELECT * FROM 'C:\ZappySys\Jdbc\DuckDB (Parquet)\titanic.parquet'.
    • Connection string: jdbc:duckdb:C:\ZappySys\Jdbc\DuckDB (Parquet)\mydb.duckdb
    DuckdbParquetDSN
    Jump to troubleshooter
    DuckdbParquetDSN
    SELECT *
    SELECT *
Read DuckDB (Parquet) data in Talend Studio
To read DuckDB (Parquet) data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    DuckdbParquetDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your DuckDB (Parquet) data: Integrating DuckDB (Parquet) data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.duckdb.DuckDBDriver):
  6. Go to the Libraries tab, click Add File, and select your DuckDB (Parquet) driver library file(s), e.g. C:\ZappySys\Jdbc\DuckDB (Parquet)\duckdb_jdbc-1.4.5.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:duckdb:memory:), click Test Connection to verify it works, and then click Finish:
    jdbc:duckdb:memory:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to DuckDB (Parquet) in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to DuckDB (Parquet), but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
