You can connect to your InfluxDB 3 data from Talend Studio via the high-performance InfluxDB 3 ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download InfluxDB 3 JDBC driver
To connect to InfluxDB 3, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit InfluxDB 3 website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\InfluxDB 3\flight-sql-jdbc-driver-19.0.0.jar.
In this section we will create a data source for InfluxDB 3 in the Data Gateway. Let's follow these steps to accomplish that:
    Influxdb3DSN
    • Configure the authentication in InfluxDB 3.
    Flight SQL (token)
    InfluxDB 3 authentication
    InfluxDB 3 SQL is exposed over Arrow Flight SQL. Create an API token in the Influx console (same idea as a Stripe secret key).
    1. Log in to your InfluxDB 3 Cloud or Core/Enterprise UI.
    2. Open API Tokens (or influx auth create on Core) and create a token with query permission on the database.
    3. Copy the host (no https://) and Flight/SQL port. Cloud often uses 443 with TLS.
    4. Paste the token into Token. Set database name to your Influx database/bucket equivalent.
    5. Do not point the Flight URL at a random redirect; this is host:port of the Flight SQL endpoint, not an OAuth callback.
    6. Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
    7. Done. You can query from C#, Python, PowerShell, and ODBC apps.
    3. Finally, hit OK button:
    • Connection string: jdbc:arrow-flight-sql://[$HostName$]:[$Port$]?useEncryption=true
    • Driver class: org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\InfluxDB 3\flight-sql-jdbc-driver-19.0.0.jar
    • Host: MyHostName
    • TCP port: 443
    • Token:
    • Database:
    • Use encryption: true
    Influxdb3DSN
    optional for InfluxDB 3
    Find full details in the InfluxDB 3 Connector authentication reference.
    Jump to troubleshooter
    Influxdb3DSN
    SELECT * FROM information_schema.tables
Read InfluxDB 3 data in Talend Studio
To read InfluxDB 3 data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    Influxdb3DSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your InfluxDB 3 data: Integrating InfluxDB 3 data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
  6. Go to the Libraries tab, click Add File, and select your InfluxDB 3 driver library file(s), e.g. C:\ZappySys\Jdbc\InfluxDB 3\flight-sql-jdbc-driver-19.0.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:arrow-flight-sql://[$HostName$]:[$Port$]?useEncryption=true), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to InfluxDB 3 in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to InfluxDB 3, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
