You can connect to your Databend data from Talend Studio via the high-performance Databend ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download Databend JDBC driver
To connect to Databend, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Databend website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jar.
In this section we will create a data source for Databend in the Data Gateway. Let's follow these steps to accomplish that:
    DatabendDSN
    • Configure the authentication in Databend.
    Host (HTTP)
    Databend authentication
    Databend JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. In Databend Cloud or self-hosted, copy the warehouse host and port (often 8000 HTTP or 443 TLS).
    2. Create a SQL user and database. Paste user and password here.
    3. For Cloud SSL, use the HTTPS Auth and keep SSL flags as documented in Databend JDBC Connection.md.
    3. Finally, hit OK button:
    • Connection string: jdbc:databend://[$HostName$]:[$Port$]/[$Database$]
    • Driver class: com.databend.jdbc.DatabendDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jar
    • Host: MyHostName
    • TCP port: 8000
    • Database name: MyDatabase
    • User name:
    • Password:
    DatabendDSN
    optional for Databend
    Find full details in the Databend Connector authentication reference.
    Host (SSL)
    Databend SSL JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Use the Cloud SQL endpoint and port 443.
    2. Create a user in the Databend console. Paste user and password.
    3. Do not turn SSL off on Cloud.
    • Connection string: jdbc:databend://[$HostName$]:[$Port$]/[$Database$]?ssl=[$Ssl$]
    • Host: MyHostName
    • TCP port: 443
    • SSL: true
    • User name:
    • Password:
    DatabendDSN
    Jump to troubleshooter
    DatabendDSN
    SHOW TABLES
    SHOW TABLES
Read Databend data in Talend Studio
To read Databend data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    DatabendDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your Databend data: Integrating Databend data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (com.databend.jdbc.DatabendDriver):
  6. Go to the Libraries tab, click Add File, and select your Databend driver library file(s), e.g. C:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:databend://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to Databend in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Databend, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
