You can connect to your ClickHouse data from Talend Studio via the high-performance ClickHouse ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download ClickHouse JDBC driver
To connect to ClickHouse, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit ClickHouse website or MVN Repository.
C:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jar.
In this section we will create a data source for ClickHouse in the Data Gateway. Let's follow these steps to accomplish that:
ClickhouseDSNZappySys JDBC Bridge Driver
- Configure the authentication in ClickHouse.
HTTP
ClickHouse authentication
ClickHouse HTTP JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Copy the ClickHouse HTTP host and port (default
8123). - Create a user (
CREATE USER) with access to the database. Paste user and password. - Use the HTTPS Auth when the endpoint is TLS (often Cloud, port 8443).
Connection string :jdbc:clickhouse://[$HostName$]:[$Port$]/[$Database$] -
Driver class :com.clickhouse.jdbc.ClickHouseDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jar -
Host :MyHostName -
TCP port :8123 -
Database name :MyDatabase -
User name : -
Password :
ClickhouseDSNjdbc:clickhouse://[$HostName$]:[$Port$]/[$Database$]com.clickhouse.jdbc.ClickHouseDriverC:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jaroptional for ClickHouse
Find full details in the ClickHouse Connector authentication reference.HTTPS
ClickHouse HTTPS JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Use the Cloud or TLS HTTP interface (often port
8443). - Create a user in the ClickHouse Cloud console. Paste user and password.
- Do not disable TLS on Cloud.
Connection string :jdbc:clickhouse:https://[$HostName$]:[$Port$]/[$Database$] -
Host :MyHostName -
TCP port :8443 -
User name : -
Password :
ClickhouseDSNjdbc:clickhouse:https://[$HostName$]:[$Port$]/[$Database$]com.clickhouse.jdbc.ClickHouseDriverC:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jaroptional for ClickHouse
Find full details in the ClickHouse Connector authentication reference. -
ClickhouseDSNSHOW TABLES
SHOW TABLESYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Read ClickHouse data in Talend Studio
To read ClickHouse data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
ClickhouseDSN
Add input
Add output
Run the job
Finally, run the job and integrate your ClickHouse data:
Open DBeaver.
com.clickhouse.jdbc.ClickHouseDriver):
Go to the Libraries tab, click Add File, and select your ClickHouse driver library file(s), e.g.
C:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:clickhouse://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In this guide, we demonstrated how to connect to ClickHouse in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to ClickHouse, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
