You can connect to your Hubspot data from Talend Studio via the high-performance Hubspot ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for Hubspot in the Data Gateway. Let's follow these steps to accomplish that:
HubspotDSNZappySys API Driver
When the Configuration window appears give your data source a name if you haven't done that already, then select "Hubspot" from the list of Popular Connectors. If "Hubspot" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
HubspotDSNHubspot
- Configure the authentication in Hubspot.
Private app (Static Access Token)
Hubspot authentication
Private apps allow you to use HubSpot's APIs to access specific data from your HubSpot account. You can authorize what each private app can request or change in your account, which will generate an access token that's unique to your app. [API reference]
Follow these instructions to create a Private app in HubSpot and configure HubSpot authentication in SSIS package or ODBC data source:
- First of all, go to HubSpot portal.
Then click Data Management option on the left
and then hit Integrations menu item:
Move on by clicking Private Apps menu item
and then click Create a private app button to create one:
- Then continue by following the instructions on HubSpot Docs.
Once you create an app, go to SSIS package or ODBC data source and in Private App authentication set these parameters:
- For AccessToken field use Access token value from the Private app configuration in HubSpot.
- Done! Now you are ready to use HubSpot Connector!
Private app (Static Access Token) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
HubspotDSNHubspotPrivate app (Static Access Token) [Http]https://api.hubapi.comRequired Parameters AccessToken Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Hubspot Connector authentication reference.Public app
In HubSpot, a public app is a type of integration that can be installed on customer accounts or listed on the App Marketplace. It requires authentication via OAuth. Once a user installs your app on their HubSpot account, you’ll be able to make API calls to that account using an OAuth access token. [API reference]
Follow these instructions to create a Public app in HubSpot and configure HubSpot authentication in SSIS package or ODBC data source:
- First of all, if you don't have HubSpot Developer's account, register one.
- Go to HubSpot and select your Developer account.
Click Apps on the left hand side and then click Create app button to create a Public app:
Then continue by following the instructions in HubSpot Docs.
NOTE: If you don't have a working Redirect URL, you can use
https://zappysys.com/oauth(it's safe).- Once you create an app, go to SSIS package or ODBC data source and in Public app authentication set these parameters (use values from your Public app configuration in HubSpot):
- For ClientId field use Client ID value.
- For ClientSecret field use Client secret value.
For Scope field use Scopes values, e.g.:
accounting tickets files crm.lists.read crm.lists.write crm.objects.contacts.read crm.objects.contacts.write crm.schemas.contacts.read crm.objects.custom.read crm.objects.custom.write crm.schemas.custom.read crm.objects.companies.read crm.objects.companies.write crm.schemas.companies.read crm.objects.deals.read crm.objects.deals.write crm.schemas.deals.read crm.objects.quotes.read crm.objects.quotes.write crm.schemas.quotes.read crm.objects.line_items.read crm.objects.line_items.write crm.schemas.line_items.read
NOTE: You can use other scopes too, but they must match the scopes defined in your Public app.- For ReturnUrl field use one of Redirect URLs.
Public app [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
HubspotDSNHubspotPublic app [OAuth]https://api.hubapi.comRequired Parameters UseCustomApp Fill-in the parameter... Scope (Must Match with App Scopes) Fill-in the parameter... Optional Parameters Client ID Client Secret ReturnUrl Authorization URL (leave blank for default) Token URL (leave blank for default) RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Developer API key (Deprecated)
Deprecated authentication method. Use [Private app] instead. [API reference]
Using HubSpot API key is deprecated method for authentication. Use Private app authentication instead. If you still need one, then follow these instructions to get HubSpot API key:
Click Apps on the left hand side and then click Get HubSpot API key button to get one:
When a popup appears, click Show Key button and then hit Copy button to copy API key:
Once copy the API key, go to SSIS package or ODBC data source and use it in API Key authentication configuration:
- Paste it in ApiKey parameter field.
Developer API key (Deprecated) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
HubspotDSNHubspotDeveloper API key (Deprecated) [Http]https://api.hubapi.comRequired Parameters ApiKey Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Hubspot Connector authentication reference. - Once you create an app, go to SSIS package or ODBC data source and in Public app authentication set these parameters (use values from your Public app configuration in HubSpot):
ZappySys API Driver - HubspotRead and write HubSpot data effortlessly. Integrate, manage, and automate contacts, companies, deals, and tickets — almost no coding required.HubspotDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from Hubspot. Hit OK button to use this query in the next step.
SELECT * FROM Companies -- WHERE Id=123
Some parameters configured in this window will be passed to the Hubspot API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster .Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in Talend Studio:
ZappySys API Driver - HubspotRead and write HubSpot data effortlessly. Integrate, manage, and automate contacts, companies, deals, and tickets — almost no coding required.HubspotDSNSELECT * FROM Companies -- WHERE Id=123
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Hubspot API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Hubspot servers).Click OK to finish creating the data source.
Skipping this step may cause the new settings to fail, preventing you from connecting to the data source.Read Hubspot data in Talend Studio
To read Hubspot data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
This article is compatible with Talend Open Studio (a free version, currently retired by Qlik). If you don't have it, you can still purchase a shareware version of Talend Studio from Qlik.Create connection for input
Create a new connection:
Name your connection:
HubspotDSN
Add input
Add output
Run the job
Finally, run the job and integrate your Hubspot data:
Hubspot Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Hubspot operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Search Companies
- Search Contacts
- Search Tickets
- Search Deals
- Search Products
- Search LineItems
- Search Quotes
- Get Contacts
- Get Contact By ID
- Get Contact Properties
- Create Contacts
- Update Contacts
- Archive Contacts
- Get Deals
- Get Deal Properties
- Get Deal By ID
- Create Deals
- Archive Deals
- Update Deals
- Get Products
- Get Product By ID
- Get Product Properties
- Create Products
- Archive Products
- Update Products
- Get Companies
- Get Company By ID
- Get Company Properties
- Create Companies
- Archive Companies
- Update Companies
- Get Line Items
- Get Line Item By ID
- Get Line Item Properties
- Create Line Items
- Archive Line Items
- Update Line items
- Get Tickets
- Get Ticket By ID
- Get Tickets Properties
- Create Tickets
- Archive Tickets
- Update Tickets
- Get Quotes
- Get Quote By ID
- Get Quotes Properties
- Create Quotes
- Archive Quotes
- Update Quotes
- Get Owners
- Upload File from Local Disk
In this guide, we demonstrated how to connect to Hubspot in Talend Studio and integrate your data — all without writing complex code.
Want more?Don't stop here. Discover more integrations.
Explore all Talend Studio connectors
Explore all Hubspot integration scenarios
