You can connect to your Zoho SalesIQ data from Talend Studio via the high-performance Zoho SalesIQ ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for Zoho SalesIQ in the Data Gateway. Let's follow these steps to accomplish that:
    ZohoSalesiqDSN
  5. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZohoSalesiqDSN
    Zoho SalesIQ
    • Configure the authentication in Zoho SalesIQ.
    Zoho SalesIQ authentication
    1. Go to Zoho API Console
    2. Click Add Client link
    7. Click CREATE.
    ZohoSalesiqDSN
    Zoho SalesIQ
    OAuth [OAuth]
    https://salesiq.zoho.com/api/v2/[$Compnay$]
    Company Screen Name for URL (e.g. mycompany)
    ClientId
    ClientSecret
    Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ
    Find full details in the Zoho SalesIQ Connector authentication reference.
    ZappySys API Driver - Zoho SalesIQ
    Read and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.
    ZohoSalesiqDSN
  8. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from Zoho SalesIQ. Hit OK button to use this query in the next step.
    SELECT * FROM Departments
    Some parameters configured in this window will be passed to the Zoho SalesIQ API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    ZohoSalesiqDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers).
Read Zoho SalesIQ data in Talend Studio
To read Zoho SalesIQ data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    ZohoSalesiqDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your Zoho SalesIQ data: Integrating Zoho SalesIQ data in Talend Studio
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zoho SalesIQ operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In this guide, we demonstrated how to connect to Zoho SalesIQ in Talend Studio and integrate your data — all without writing complex code.
