You can connect to your MariaDB data from Talend Studio via the high-performance MariaDB ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Download MariaDB JDBC driver
To connect to MariaDB, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit MariaDB website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\MariaDB\mariadb-java-client-3.5.3.jar.
In this section we will create a data source for MariaDB in the Data Gateway. Let's follow these steps to accomplish that:
    MariadbDSN
    • Configure the authentication in MariaDB.
    Standard connection
    MariaDB authentication
    MariaDB from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Note the host, port (default 3306), and database name.
    2. Create an application user (not a personal DBA login) with SELECT on the schemas you need.
    3. Paste user and password. After Finish, edit the host (e.g. MyHostName) and database (e.g. MyDatabase) on the DSN Main UI.
    3. Finally, hit OK button:
    • Connection string: jdbc:mariadb://[$HostName$]:[$Port$]/[$Database$]
    • Driver class: org.mariadb.jdbc.Driver
    • JDBC driver file(s): C:\ZappySys\Jdbc\MariaDB\mariadb-java-client-3.5.3.jar
    • Host: MyHostName
    • TCP port: 3306
    • Database name: MyDatabase
    • User name:
    • Password:
    MariadbDSN
    optional for MariaDB
    Find full details in the MariaDB Connector authentication reference.
    SSL connection
    MariaDB with TLS from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Same as Default Auth. Use this when the server requires TLS (managed Cloud SQL, RDS, SkySQL).
    2. After Finish, confirm sslMode on the JDBC URL matches your server (REQUIRED vs VERIFY_CA).
    • Connection string: jdbc:mariadb://[$HostName$]:[$Port$]/[$Database$]?sslMode=[$SslMode$]
    • Host: MyHostName
    • TCP port: 3306
    • SSL mode: trust
    • User name:
    • Password:
    MariadbDSN
    Jump to troubleshooter
    MariadbDSN
    SELECT * FROM orders
Read MariaDB data in Talend Studio
To read MariaDB data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    MariadbDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your MariaDB data: Integrating MariaDB data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.mariadb.jdbc.Driver):
  6. Go to the Libraries tab, click Add File, and select your MariaDB driver library file(s), e.g. C:\ZappySys\Jdbc\MariaDB\mariadb-java-client-3.5.3.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:mariadb://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to MariaDB in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to MariaDB, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
