You can connect to your Zoho CRM data from Talend Studio via the high-performance Zoho CRM ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for Zoho CRM in the Data Gateway. Let's follow these steps to accomplish that:
ZohoCrmDSNZappySys API Driver
When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho CRM" from the list of Popular Connectors. If "Zoho CRM" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ZohoCrmDSNZoho CRM
- Configure the authentication in Zoho CRM.
Zoho CRM authentication
- Click Add Client link
- Click CREATE.
ZohoCrmDSNZoho CRMOAuth [OAuth]https://www.zohoapis.com/crm/[$Version$]Optional Parameters ClientId ClientSecret Permissions ZohoCRM.settings.all ZohoCRM.modules.all ZohoCRM.coql.READ AccountUrl https://accounts.zoho.com RedirectUrl https://zappysys.com/oauth API Version v2 RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zoho CRM Connector authentication reference. -
ZappySys API Driver - Zoho CRMRead and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.ZohoCrmDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from Zoho CRM. Hit OK button to use this query in the next step.
SELECT * from Accounts
Some parameters configured in this window will be passed to the Zoho CRM API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in Talend Studio:
ZappySys API Driver - Zoho CRMRead and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.ZohoCrmDSNSELECT * from Accounts
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Zoho CRM API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho CRM servers). -
Read Zoho CRM data in Talend Studio
To read Zoho CRM data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
ZohoCrmDSN
Add input
Add output
Run the job
Finally, run the job and integrate your Zoho CRM data:
Zoho CRM Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zoho CRM operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Read Data (Direct COQL Query - Auto Paging)
- Read Data (COQL Query Builder)
- List Modules
- List Territories
- List Module Settings
- List Tags
- Gets record count for specific tag for module
- Add / Update Tags for records
- List Module Fields
- List Views
- Read [Dynamic Endpoint]
- Read [Dynamic Endpoint] (Use this for fewer than 50 Fields in v3+)
- Search [Dynamic Endpoint]
- Delete [Dynamic Endpoint]
- Insert [Dynamic Endpoint]
- Update [Dynamic Endpoint]
- Upsert [Dynamic Endpoint] (Update or Insert)
In this guide, we demonstrated how to connect to Zoho CRM in Talend Studio and integrate your data — all without writing complex code.
