You can connect to your Mailchimp data from Talend Studio via the high-performance Mailchimp ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for Mailchimp in the Data Gateway. Let's follow these steps to accomplish that:
    MailchimpDSN
  5. When the Configuration window appears give your data source a name if you haven't done that already, then select "Mailchimp" from the list of Popular Connectors. If "Mailchimp" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    MailchimpDSN
    Mailchimp
    • Configure the authentication in Mailchimp.
    Mailchimp authentication
    To get the credentials you need in order to set up your OAuth workflow, you'll first need to register your application with Mailchimp:
    1. Login into your Mailchimp account, click on your Profile Icon, and hit Account & billing: Start by going to Mailchimp account
    2. Navigate to the Registered Apps page in your Mailchimp account: Go to registered OAuth apps in Mailchimp
    3. Click Register An App button: Register new OAuth app in Mailchimp
    4. Fill-in the Register An App form and click Create button: Enter OAuth app details in Mailchimp
      NOTE: For Redirect URI use Redirect URI (also called "Redirect URL" or "Callback URL") given by your IT administrator or just use https://zappysys.com/oauth, if you don't have one.
    5. After successfully registering your application, you'll see the Client ID and Client Secret, record these values and store them securely: Use OAuth app to get Mailchimp data via REST API
    6. Record your Mailchimp data center, since we will need it later. The data center is located in your browser's address bar URL. If the URL is https://us21.admin.mailchimp.com/account/api, then your data center is us21.
    7. Now go to SSIS package or ODBC data source OAuth authentication configuration.
    8. Proceed by entering the data center into the Data Center field that was recorded in the previous step.
    9. Then enter the Client ID value into the Client ID field that you recorded in the previous step.
    10. Enter the Client Secret value into the Client Secret field that was recorded in the previous step.
    11. Click Generate Token. If proper authentication occurs, you will see a confirmation notice. If you get an error, click Yes on the dialog box and then a large browser window will launch. Then log into your Mailchimp account and approve the use of the application.
    12. Finally, hit the Test Connection button at the bottom of the window to verify proper connectivity with your Mailchimp account.
    13. If the connection test succeeds, select OK.
    14. Done! Now you can use Mailchimp Connector!
    MailchimpDSN
    Mailchimp
    OAuth [OAuth]
    https://[$DataCenter$].api.mailchimp.com
    Data Center Fill-in the parameter...
    Client Id Fill-in the parameter...
    Default List Id Fill-in the parameter...
    Find full details in the Mailchimp Connector authentication reference.
    ApiKey Auth
    The simplest way to authenticate a request to the Mailchimp Marketing API is by using an API key (If you require access to Mailchimp on behalf of other Mailchimp users, you'll want to set up OAuth authentication instead)::
    2. Navigate to the API keys page in your Mailchimp account: Go to API Keys in Mailchimp
    3. In the Your API keys section of the page, click Create A Key button: Create new API Key in Mailchimp
    4. Give your new key a descriptive name that will remind you which application it's used for: Name API Key in Mailchimp
    5. Copy the API key immediately and store it in a secure location (you won't be able to see or copy the key once you finish generating it): Use API Key to get Mailchimp data via REST API
    7. Now go to SSIS package or ODBC data source ApiKey Auth authentication configuration.
    9. Then enter the API key into the Api Key field that you copied earlier.
    10. Finally, click the Test Connection button at the bottom of the window to verify proper connectivity with your Mailchimp account.
    11. Done! Now you can use Mailchimp Connector!
    1. Set Authentication Type to ApiKey Auth [Http]
    MailchimpDSN
    Mailchimp
    ApiKey Auth [Http]
    Api Key Fill-in the parameter...
    Data Center
    ZappySys API Driver - Mailchimp
    Read and write Mailchimp data effortlessly. Integrate, manage, and automate campaigns, lists, members, and reports — almost no coding required.
    MailchimpDSN
  8. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from Mailchimp. Hit OK button to use this query in the next step.
    SELECT * FROM Campaigns
    Some parameters configured in this window will be passed to the Mailchimp API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    MailchimpDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Mailchimp API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Mailchimp servers).
Read Mailchimp data in Talend Studio
To read Mailchimp data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    MailchimpDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your Mailchimp data: Integrating Mailchimp data in Talend Studio
Mailchimp Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Mailchimp operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In this guide, we demonstrated how to connect to Mailchimp in Talend Studio and integrate your data — all without writing complex code.
