You can connect to your Stripe data from Talend Studio via the high-performance Stripe ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for Stripe in the Data Gateway. Let's follow these steps to accomplish that:
    StripeDSN
  5. When the Configuration window appears give your data source a name if you haven't done that already, then select "Stripe" from the list of Popular Connectors. If "Stripe" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    StripeDSN
    Stripe
    Stripe
    Stripe authentication
    3. Then create a Secret key.
    StripeDSN
    Stripe
    Stripe [Http]
    https://api.stripe.com/v1
    ZappySys API Driver - Stripe
    StripeDSN
  8. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from Stripe. Hit OK button to use this query in the next step.
    SELECT * FROM Products
    Some parameters configured in this window will be passed to the Stripe API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    StripeDSN
Read Stripe data in Talend Studio
To read Stripe data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    StripeDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your Stripe data: Integrating Stripe data in Talend Studio
Stripe Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Stripe operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In this guide, we demonstrated how to connect to Stripe in Talend Studio and integrate your data — all without writing complex code.
