You can connect to your SOAP data from Talend Studio via the high-performance SOAP ODBC Driver. We'll walk you through the entire setup.
What is SOAP Web Service?
If you are new to SOAP Web Service sometimes referred as XML Web Service then please read some concept about SOAP Web service standard from this link
There are two important aspects in SOAP Web service.
  1. Getting WSDL file or URL
  2. Knowing exact Web Service URL
What is WSDL
What is Service URL
Service URL is actual API URL you can call to get data. When you make a request to SOAP service url make sure following things.
  1. Use correct service URL (Its not same as WSDL url). If you are not sure about service URL contact API vendor or refer API documentation.
  2. Each service call you have to supply function you want to call. This can be done in 3 different ways.
    1. Pass via SOAPAction HTTP Header
    2. Pass via Url parameter or Url Path (http://myserver/service/function1  — http://myserver/service/?method=function1 )
    3. Pass via Request BODY
  3. Find out how to pass credentials. It can be done via Basic Authorization or WSS Security Header in the Request body. Check this link to learn more
Using SoapUI to test SOAP API call / Create Request Body XML
If you do not have WSDL file or URL handy then contact your API provider (sometimes you just have to add ?wsdl at the end of your Service URL to get WSDL so try that. Example: http://mycompany/myservice?wsdl ). If you don't know what is WSDL then in short, WSDL is Web service Description Language (i.e. XML file which describes your SOAP Service). WSDL helps to craft SOAP API request Body for ZappySys XML Driver. So Let's get started.
  1. Download and Install SoapUI (It’s a Free tool to test SOAP / REST Services)
  2. Open SoapUI and click SOAP button to create new SOAP Project
  3. Enter WSDL URL or File Path of WSDLFor example WSDL for our sample service can be accessed via this URL
    http://www.holidaywebservice.com/HolidayService_v2/HolidayService2.asmx?wsdl
    Create new SOAP API Project in SoapUI tool for SOAP API Testing
  4. Once WSDL is loaded you will see possible operations you can call for your SOAP Web Service.
  5. If your web service requires credentials then you have to configure it. There are two common credential types for public services (SOAP WSS or BASIC )
    1. To use SOAP WSS Credentials select request node and enter UserId, Password, and WSS-PasswordType (PasswordText or PasswordHash)
      Configure SOAP WSS Credentials for SoapUI (SOAP API Testing Tool)
    2. To use BASIC Auth Credentials select request node and double-click it. At the bottom click on Auth (Basic) and From Authorization dropdown click Add New and Select Basic. Configure Basic Authorization for SoapUI (SOAP API Testing Tool)
  6. Now you can test your request first Double-click on the request node to open request editor.
  7. Change necessary parameters, remove optional or unwanted parameters. If you want to regenerate request you can click on Recreate default request toolbar icon. Create SOAP Request XML (With Optional Parameters)
  8. Once your SOAP Request XML is ready, Click the Play button in the toolbar to execute SOAP API Request and Response will appear in Right side panel. Test SOAP API using SoapUI Tool (Change Default XML Body / Parameters, Execute and See Response)
Once you have tested your SOAP API in SoapUI tool, we are ready to use ZappySys SSIS Tasks/Components or ODBC Drivers to call SOAP API in SSIS or your preferred BI tool or Programming language.
In this section we will create a data source for SOAP in the Data Gateway. Let's follow these steps to accomplish that:
    • Then select Native - ZappySys XML Driver
    SoapDSN
    ZappySys XML Driver
  5. Configure API URL, Request Method and Request Body as below screen. Select Url or File and paste the following Url for this example OR you can load existing connection string as per this article.
    NOTE: Here i am using demo SOAP API URL, but you need to refer your own API documentation and based on that you need to use your own API URL and need to configure connection based on API Authentication type.
    ZappySys XML Driver - Calling SOAP API - Configure URL, Method, Body
  6. (This step is Optional) If your SOAP API requires credentials then Select Connection Type to HTTP and configure as below.
    ZappySys XML Driver - Configure SOAP WSS Credentials or Basic Authorization (Userid, Password)
  7. Configure-Request Headers as below (You can get it from Request > Raw tab from SoapUI after you test the request by clicking the Play button)
    Configure SOAP API Request Headers - ZappySys XML Driver
  8. Once credentials entered you can select Filter to extract data from the desired node. Make sure to select array node (see special icon) or select the node which contains all necessary columns if you don't have array node.
    Select Filter - Extract data from nested XML / SOAP API Response (Denormalize Hierarchy)
  9. If prompted select yes to treat selected node as Array (This is helpful when you expect one or more record for selected node)
    Treat selected node as XML Array Option for SOAP API Response XML
  10. Once the data source has been configured, Go to Preview tab and click on preview data to view the data.
    You can create the default query, generated based on settings you entered in previous sections also, by using Query Builder. Attributes listed in WITH clause are optional. If you omit attribute in WITH clause it will use it from Properties tab.
    Preview SOAP API Response in ZappySys XML Driver
  11. Click OK to finish creating the data source.
  12. That's it; we are done. In a few clicks we configured the call to SOAP API using ZappySys SOAP Connector.
  13. Once done, go to the Network Settings tab and Add a firewall rule for inbound traffic:
  14. Crucial Step: After creating or modifying the data source, you must:
Read SOAP data in Talend Studio
To read SOAP data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    SoapDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your SOAP data: Integrating SOAP data in Talend Studio
Configuring pagination in the XML Driver
ZappySys XML Driver equips users with powerful tools for seamless data extraction and management from REST APIs, leveraging advanced pagination methods for enhanced efficiency. These options are designed to handle various types of pagination structures commonly used in APIs. Below are the detailed descriptions of these options:
Utilizing these comprehensive pagination features in the ZappySys XML Driver facilitates efficient data management and extraction from REST APIs, optimizing the integration and analysis of extensive datasets.
Authentication
ZappySys offers various authentication methods to securely access data from various sources. These authentication methods include OAuth, Basic Authentication, Token-based Authentication, and more, allowing users to connect to a wide range of data sources securely.
ZappySys Authentication is a robust system that facilitates secure access to data from a diverse range of sources. It includes a variety of authentication methods tailored to meet the specific requirements of different data platforms and services. These authentication methods may involve:
  1. OAuth: ZappySys supports OAuth for authentication, which allows users to grant limited access to their data without revealing their credentials. It's commonly used for applications that require access to user account information.
  2. Basic Authentication: This method involves sending a username and password with every request. ZappySys allows users to securely access data using this traditional authentication approach.
  3. Token-based Authentication: ZappySys enables users to utilize tokens for authentication. This method involves exchanging a unique token with each request to authenticate the user's identity without revealing sensitive information.
By implementing these authentication methods, ZappySys ensures the secure and reliable retrieval of data from various sources, providing users with the necessary tools to access and integrate data securely and efficiently. For more comprehensive details on the authentication process, please refer to the official ZappySys documentation or reach out to their support team for further assistance.
For more details, please refer to this link: ZappySys Connections
In this guide, we demonstrated how to connect to SOAP in Talend Studio and integrate your data — all without writing complex code.
