You can connect to your Jira data from Talend Studio via the high-performance Jira ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for Jira in the Data Gateway. Let's follow these steps to accomplish that:
    JiraDSN
  5. When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    JiraDSN
    Jira
    API Key based Authentication
    Jira authentication
    1. Go to Profile > Security.
    5. That's it!
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
      Name OAuth app in Atlassian
        • offline_access (a must)
        • read:jira-user
        • read:jira-work
        • write:jira-work
        • manage:jira-project
        • manage:jira-configuration
    JiraDSN
    Jira
    ZappySys API Driver - Jira
    JiraDSN
  8. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from Jira. Hit OK button to use this query in the next step.
    SELECT * FROM Issues
    --//Query single issue by numeric Issue Id
    --SELECT * FROM Issues Where Id=101234
    --//Query issue by numeric Issue Ids (multiple)
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='101234,101235,101236')
    --//Query issue by Issue Key(s) (alpha-numeric)
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11')
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11,PROJ-12,PROJ-13')
    --//Query issue by project(s)
    --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ')
    --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ,KAN,CS')
    --//Query issue by JQL expression
    --SELECT * FROM Issues WITH(SearchBy='Jql', Jql='status IN (Done, Closed) AND created > -5d' )
    Some parameters configured in this window will be passed to the Jira API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    JiraDSN
Read Jira data in Talend Studio
To read Jira data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    JiraDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your Jira data: Integrating Jira data in Talend Studio
Jira Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Jira operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In this guide, we demonstrated how to connect to Jira in Talend Studio and integrate your data — all without writing complex code.
