You can connect to your Cosmos DB data from Talend Studio via the high-performance Cosmos DB ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for Cosmos DB in the Data Gateway. Let's follow these steps to accomplish that:
CosmosDbDSNZappySys API Driver
When the Configuration window appears give your data source a name if you haven't done that already, then select "Cosmos DB" from the list of Popular Connectors. If "Cosmos DB" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
CosmosDbDSNCosmos DB
- Configure the authentication in Cosmos DB.
API Key
Cosmos DB authentication
Connecting to your Azure Cosmos DB data requires you to authenticate your REST API access. Follow the instructions below:- Go to your Azure portal homepage: https://portal.azure.com/.
- In the search bar at the top of the homepage, enter Azure Cosmos DB. In the dropdown that appears, select Azure Cosmos DB.
- Click on the name of the database account you want to connect to (also copy and paste the name of the database account for later use).
On the next page where you can see all of the database account information, look along the left side and select Keys:
- On the Keys page, you will have two tabs: Read-write Keys and Read-only Keys. If you are going to write data to your database, you need to remain on the Read-write Keys tab. If you are only going to read data from your database, you should select the Read-only Keys tab.
- On the Keys page, copy the PRIMARY KEY value and paste it somewhere for later use (the SECONDARY KEY value may also be copied and used).
- Now go to SSIS package or ODBC data source and use this PRIMARY KEY in API Key authentication configuration.
- Enter the primary or secondary key you recorded in step 6 into the Primary or Secondary Key field.
- Then enter the database account you recorded in step 3 into the Database Account field.
- Next, enter or select the default database you want to connect to using the Default Database field.
- Continue by entering or selecting the default table (i.e. container/collection) you want to connect to using the Default Table (Container/Collection) field.
- Select the Test Connection button at the bottom of the window to verify proper connectivity with your Azure Cosmos DB account.
- If the connection test succeeds, select OK.
- Done! Now you are ready to use Cosmos DB Connector!
API Key [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
CosmosDbDSNCosmos DBAPI Key [Http]https://[$Account$].documents.azure.comRequired Parameters Primary or Secondary Key Fill-in the parameter... Account Name (Case-Sensitive) Fill-in the parameter... Database Name (keep blank to use default) Case-Sensitive Fill-in the parameter... API Version Fill-in the parameter... Optional Parameters Default Table (needed to invoke #DirectSQL)
Find full details in the Cosmos DB Connector authentication reference. -
ZappySys API Driver - Cosmos DBRead and write Azure Cosmos DB data effortlessly. Query, integrate, and manage databases, containers, documents, and users — almost no coding required.CosmosDbDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from Cosmos DB. Hit OK button to use this query in the next step.
#DirectSQL SELECT * FROM root where root.id !=null order by root._ts desc
Some parameters configured in this window will be passed to the Cosmos DB API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in Talend Studio:
ZappySys API Driver - Cosmos DBRead and write Azure Cosmos DB data effortlessly. Query, integrate, and manage databases, containers, documents, and users — almost no coding required.CosmosDbDSN#DirectSQL SELECT * FROM root where root.id !=null order by root._ts desc
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Cosmos DB API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Cosmos DB servers). -
Read Cosmos DB data in Talend Studio
To read Cosmos DB data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
CosmosDbDSN
Add input
Add output
Run the job
Finally, run the job and integrate your Cosmos DB data:
Cosmos DB Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Cosmos DB operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get List of Databases
- Get Database Information by Id or Name
- Get List of Tables
- Get table information by Id or Name
- Get table partition key ranges
- Query documents using Cosmos DB SQL query language
- Get All Documents for a Table
- Get Document by Id
- Delete a Document by Id
- Get All Users for a Database
- Get User by Id or Name
- Create User for Database
- Create a document in the container
- Upsert a document in the container
- Update Document in the Container
- Create Permission Token for a User (One Table)
In this guide, we demonstrated how to connect to Cosmos DB in Talend Studio and integrate your data — all without writing complex code.
