You can connect to your JDBC data source data from Talend Studio via the high-performance JDBC-ODBC Bridge Driver. We'll walk you through the entire setup.
Download your Java application JDBC driver
To connect to your Java application, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit your Java application website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to D:\Drivers\JDBC\app-jdbc.jar.
In this section we will create a data source for JDBC-ODBC Bridge in the Data Gateway. Let's follow these steps to accomplish that:
    JdbcOdbcBridgeDSN
    • Configure the authentication in JDBC-ODBC Bridge.
    MixedMode
    JDBC-ODBC Bridge authentication
    3. Finally, hit OK button:
    • Connection string: jdbc:exampleApp://app-service-host-name.com:1234
    • Driver class: com.provider.exampleApp.jdbc.AppDriver
    • JDBC driver file(s): D:\Drivers\JDBC\app-jdbc.jar
    • User name: admin
    • User password: *************
    • Connection parameters: [{"Name":"AppParameter","Value":"12345"}]
    JdbcOdbcBridgeDSN
    admin
    Find full details in the JDBC-ODBC Bridge Connector authentication reference.
    Jump to troubleshooter
    JdbcOdbcBridgeDSN
    SELECT * FROM orders
Read JDBC-ODBC Bridge data in Talend Studio
To read JDBC-ODBC Bridge data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
    JdbcOdbcBridgeDSN
Add input
    Create a job in Talend Studio
Add output
Run the job
Finally, run the job and integrate your JDBC-ODBC Bridge data: Integrating JDBC-ODBC Bridge data in Talend Studio
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (com.provider.exampleApp.jdbc.AppDriver):
  6. Go to the Libraries tab, click Add File, and select your JDBC-ODBC Bridge driver library file(s), e.g. D:\Drivers\JDBC\app-jdbc.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:exampleApp://app-service-host-name.com:1234), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In this guide, we demonstrated how to connect to JDBC-ODBC Bridge in Talend Studio and integrate your data — all without writing complex code. ZappySys JDBC Bridge Driver allows you to connect to any Java application that supports JDBC.
