You can connect to your FastSpring data from Talend Studio via the high-performance FastSpring ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for FastSpring in the Data Gateway. Let's follow these steps to accomplish that:
FastspringDSNZappySys API Driver
When the Configuration window appears give your data source a name if you haven't done that already, then select "FastSpring" from the list of Popular Connectors. If "FastSpring" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
FastspringDSNFastSpring
- Configure the authentication in FastSpring.
API Credentials
FastSpring authentication
- In the FastSpring portal, navigate to Developer Tools > APIs > API Credentials.
Click Create, FastSpring will automatically generate your Username and Password.
Copy them, we will need them in the next step:
WARNING: Securely store the credentials for future reference. -
Now go to SSIS package or ODBC data source and use this token in API Credentials authentication configuration:
- In the UserName field paste the Username value you copied in the previous step.
- In the Password field paste the Password value you copied in the previous step.
- Done! Now you are ready to use FastSpring Connector!
API Credentials [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
FastspringDSNFastSpringAPI Credentials [Http]https://api.fastspring.comRequired Parameters UserName Fill-in the parameter... Password Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True Your Webstore URL (Only used by get_products_visibility endpoint) https://YOUR-STORE.onfastspring.com
Find full details in the FastSpring Connector authentication reference. -
ZappySys API Driver - FastSpringRead and write FastSpring data effortlessly. Integrate, manage, and automate orders, subscriptions, quotes, products, and accounts — almost no coding required.FastspringDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from FastSpring. Hit OK button to use this query in the next step.
SELECT * FROM Orders
Some parameters configured in this window will be passed to the FastSpring API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in Talend Studio:
ZappySys API Driver - FastSpringRead and write FastSpring data effortlessly. Integrate, manage, and automate orders, subscriptions, quotes, products, and accounts — almost no coding required.FastspringDSNSELECT * FROM Orders
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the FastSpring API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in FastSpring servers). -
Read FastSpring data in Talend Studio
To read FastSpring data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
FastspringDSN
Add input
Add output
Run the job
Finally, run the job and integrate your FastSpring data:
FastSpring Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential FastSpring operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Product IDs
- Get Products
- Get Products Publish Status
- Get Product
- Create Product
- Update Product
- Get Product Prices
- Get Order Items
- Get Order Items by OrderId
- Get Orders
- Get Order by Id
- Get Accounts
- Get Account Orders (For all accounts)
- Get Account Charges
- Get Account Orders (For a single account)
- Get Account Charges by Id
- Get Account By Id
- Get Subscriptions Ids
- Get Subscriptions
- Get Subscription By Id
- Get Quote By Id
- Get Quotes
- Get Subscription Report
- Get Revenue Report
In this guide, we demonstrated how to connect to FastSpring in Talend Studio and integrate your data — all without writing complex code.
