You can connect to your Power BI Service data from Talend Studio via the high-performance Power BI Service ODBC Driver. We'll walk you through the entire setup.
In this section we will create a data source for Power BI Service in the Data Gateway. Let's follow these steps to accomplish that:
PowerBiServiceDSNZappySys API Driver
When the Configuration window appears give your data source a name if you haven't done that already, then select "Power BI Service" from the list of Popular Connectors. If "Power BI Service" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
PowerBiServiceDSNPower BI Service
- Configure the authentication in Power BI Service.
User Credentials
Power BI Service authentication
WARNING: If you are planning to automate processes, we recommend that you use a Application Credentials authentication method. In case, you still need to use User Credentials, then make sure you use a system/generic account (e.g.automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.- Navigate to the Azure Portal and log in using your credentials.
- Access Microsoft Entra ID.
Register a new application by going to App registrations and clicking on New registration button:
Supported account type
- Use
- Use
Redirect URI:
- Set the type to
- Set the type to
Copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration:
In the Scope field use the default value or select individual scopes, e.g.:
offline_access -
https://analysis.windows.net/powerbi/api/Workspace.Read.All -
https://analysis.windows.net/powerbi/api/Dataset.Read.All -
https://analysis.windows.net/powerbi/api/Dataset.ReadWrite.All
- If tenant policy blocks user consent, an administrator must approve the requested delegated permissions.
- Optional step. Choose Default Workspace from the drop down menu.
- Choose Default Dataset from the drop down menu.
PowerBiServiceDSNPower BI ServiceUser Credentials [OAuth]https://api.powerbi.com/v1.0/myorgRequired Parameters Authorization URL Fill-in the parameter... Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Scope Fill-in the parameter... Default Dataset (select after generating tokens) Fill-in the parameter... Optional Parameters Client Secret Redirect URI (must match App Redirect URI) Default Workspace (Keep Empty for My Workspace - select after generating tokens) RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503 RetryCountMax 20 RetryWaitTimeMs 1000 RetryMultiplyWaitTime True Login options
Find full details in the Power BI Service Connector authentication reference. -
ZappySys API Driver - Power BI ServiceRead and write Microsoft Power BI data effortlessly. Access, refresh, and manage datasets, reports, and dashboards — almost no coding required.PowerBiServiceDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Talend Studio to retrieve data from Power BI Service. Hit OK button to use this query in the next step.
SELECT * FROM Workspaces WHERE Id='aaaaaaaa-bbbb-cccc-dddd-eeeeeeeeeeee'
Some parameters configured in this window will be passed to the Power BI Service API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in Talend Studio:
ZappySys API Driver - Power BI ServiceRead and write Microsoft Power BI data effortlessly. Access, refresh, and manage datasets, reports, and dashboards — almost no coding required.PowerBiServiceDSNSELECT * FROM Workspaces WHERE Id='aaaaaaaa-bbbb-cccc-dddd-eeeeeeeeeeee'
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Power BI Service API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Power BI Service servers). -
Read Power BI Service data in Talend Studio
To read Power BI Service data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
PowerBiServiceDSN
Add input
Add output
Run the job
Finally, run the job and integrate your Power BI Service data:
Power BI Service Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Power BI Service operations directly in Talend Studio, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Workspaces
- Get a Workspace
- Get Datasets
- Get a Dataset
- Create a Push Dataset
- Delete a Dataset
- Refresh a Dataset
- Get Tables
- Get Table Columns
- Get Table Rows
- Insert Rows into Push Dataset Table
- Truncate a Push Dataset Table
- Execute a DAX query
- Get Dataflows
- Refresh a Dataflow
In this guide, we demonstrated how to connect to Power BI Service in Talend Studio and integrate your data — all without writing complex code.
