Google Analytics Connector for Power BI
Google Analytics Connector can be used to read data from Google Analytics Service without learning complex API. Easy to use interface allows you extract large amount of data adjusting parameters such as dimensions, metrics, filters, sortby, date range etc. You can also use inbuilt reports or specify direct query URL to get desired data.
In this article you will learn how to quickly and efficiently integrate Google Analytics data in Power BI without coding. We will use high-performance Google Analytics Connector to easily connect to Google Analytics and then access the data inside Power BI.
Let's follow the steps below to see how we can accomplish that!
Download Documentation
Create ODBC Data Source (DSN) based on
To get data from Google Analytics using Power BI we first need to create a DSN (Data Source) which will access data from Google Analytics. We will later be able to read data using Power BI. Perform these steps:
  1. Download and install ODBC PowerPack.
  2. Open ODBC Data Sources (x64):
  3. Create a User data source (User DSN) based on :
    Create new User DSN for
    • Create and use User DSN if the client application is run under a User Account. This is an ideal option in design-time, when developing a solution, e.g. in Visual Studio 2019. Use it for both type of applications - 64-bit and 32-bit.
    • Create and use System DSN if the client application is launched under a System Account, e.g. as a Windows Service. Usually, this is an ideal option to use in a production environment. Use ODBC Data Source Administrator (32-bit), instead of 64-bit version, if Windows Service is a 32-bit application.
    Power BI uses a Service Account, when a solution is deployed to production environment, therefore for production environment you have to create and use a System DSN.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Google Analytics" from the list of Popular Connectors. If "Google Analytics" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    GoogleAnalyticsDSN
    Google Analytics
  5. Now it's time to configure the Connection Manager. Select Authentication Type, e.g. Token Authentication. Then select API Base URL (in most cases, the default one is the right one). More info is available in the Authentication section.
    Google Analytics authentication
    Amazon OAuth Security Profile has be created in Amazon Developer portal. [API reference]
    1. Firstly, login into Amazon Developer portal in https://developer.amazon.com.
    2. Then click Sign in.
    3. If you don't have an account, press Create your Amazon Developer account button to create one.
    4. Once logged in, click on your profile icon on the right-top of the window and hit Settings: Amazon developer profile settings
    5. Then click Security Profiles and proceed with creating a new Security Profile:
    6. Create Amazon developer security profile
    7. After that, click Web Settings subtab, then hit Show Secret button to reveal the Client Secret (you will need it later), and click Edit to add a Redirect URL:
    8. Reveal client secret in Amazon developer security profile
    9. Continue by setting Allowed Return URLs (you can have your own or use https://zappysys.com/oauth): Set return URLs in Amazon developer security profile
    10. Done! Now you can use Client ID, Client Secret, and Redirect URL when configuring OAuth Authentication parameters: Use client ID and client secret to connect to REST API Amazon services
    1. Set Authentication Type to OAuth Authentication [OAuth]
    GoogleAnalyticsDSN
    Google Analytics
    https://advertising-api.amazon.com/v2
    AuthorizationUrl Fill-in the parameter...
    Profile (click 'Generate Token' before this) Fill-in the parameter...
    - Google Analytics
    GoogleAnalyticsDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Google Analytics. Hit OK button to use this query in the next step.
    SELECT * FROM Orders
    Some parameters configured in this window will be passed to the Google Analytics API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    - Google Analytics
    GoogleAnalyticsDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Google Analytics API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Google Analytics servers).
Read Google Analytics data in Power BI using ODBC
Importing Google Analytics data into Power BI from table or view
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose GoogleAnalyticsDSN and continue:
    GoogleAnalyticsDSN
    GoogleAnalyticsDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, use extracted data from Google Analytics in a Power BI report:
Importing Google Analytics data into Power BI using SQL query
If you wish to import Google Analytics data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
GoogleAnalyticsDSN
Using a full ODBC connection string
    - Configuration [Version: 2.0.1.10418]
    - Google Analytics
    GoogleAnalyticsDSN
    GoogleAnalyticsDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://advertising-api.amazon.com/v2;Provider=Custom;OAuthVersion=OAuth2;AuthUrl=[$AuthorizationUrl$];ClientId=[$AppId$];Scope=[$Scope$];TokenUrl=https://api.amazon.com/auth/o2/token;ScopeSeparator={space};ContentType=application/x-www-form-urlencoded;
Editing query for table in Power BI
Using parameters in Power BI (dynamic query)
                                = Odbc.Query("dsn=GoogleAnalyticsDSN",
                                              FROM Products
                                              ORDER BY UnitPrice")
Using DirectQuery Option rather than Import
So far we have seen how to Import Google Analytics data into Power BI, but what if you have too much data and you don't want to import but link it. Power BI Offers very useful feature for this scenario. It's called DirectQuery Option. In this section we will explore how to use DirectQuery along with ZappySys Drivers.
Out of the box ZappySys Drivers won't work in ODBC Connection Mode, so you have to use SQL Server Connection rather than ODBC if you wish to use Live data using DirectQuery option. See below step-by-step instructions to enable DirectQuery mode in Power BI for Google Analytics data.
Basically we will use ZappySys Data Gateway its part of ODBC PowerPack. We will then use Linked Server in SQL Server to Link API Service, then issue OPENROWSET queries from Power BI to SQL Server, and it will then call Google Analytics via ZappySys Data Gateway.
  1. First, create a data source in ZappySys Data Gateway and create a Linked Server based on it.
  2. Once SQL Server Linked Server is configured we are ready to issue a SQL query in Power BI.
  3. Click Get Data in Power BI, select SQL Server Database
  4. Enter your server name and any database name
  5. Select Mode as DirectQuery
  6. Click on Advanced and enter query like below (we are assuming you have created Google Analytics Data Source in Data Gateway and defined linked server - change the name below).
    SELECT * FROM OPENQUERY([LS_TO_GOOGLE_ANALYTICS_IN_GATEWAY], 'SELECT * FROM Orders')
    DirectQuery option for Power BI (Read Google Analytics Data Example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and Load data... That's it. Now your Google Analytics API data is linked rather than imported.
Publishing Power BI report to Power BI service
    If you need to periodically refresh Power BI semantic model (dataset) to ensure data accuracy and up-to-dateness, you can accomplish that by using Microsoft On-premises data gateway. Proceed to the next section - Refreshing Power BI semantic model (dataset) using On-premises data gateway - and learn how to do that.
Power BI allows to refresh semantic models which are based on data sources that reside on-premises. This can be achieved using Microsoft On-premises data gateway. There are two types of On-premises gateways:
  • Standard Mode
  • Personal Mode
Standard Mode supports Power BI and other Microsoft Data Fabric services. It fits perfectly for Enterprise solutions as it installs as a Windows Service and also supports Direct Query feature.
Personal Mode, on the other hand, can be configured faster, but is designed more for home users (you cannot install it as a Windows Service and it does not support DirectQuery). You will find a detailed comparison in the link above.
We recommend to go with Personal Mode for a quick POC solution, but use Standard Mode in production environment.
Below you will find instructions on how to refresh semantic model using both types of gateways.
Refresh using On-premises data gateway (standard mode)
Here are the instructions on how to refresh a Power BI semantic model using On-premises data gateway (standard mode):
  1. Go to Power BI My workspace, hover your mouse cursor on your semantic model and click Settings:
  2. If you see this view, it means you have to install On-premises data gateway (standard mode):
  3. Install On-premises data gateway (standard mode) and sign-in:
    signing in into on-premises data gateway standard
    Use the same email address you use when logging in into Power BI account.
  4. Register a new gateway (or migrate an existing one):
    registering or migrating on-premises data gateway standard
  5. If you are creating a new gateway, name your gateway, enter a Recovery key, and click Configure button:
    naming on-premises data gateway standard
  6. Now, let's get back to your semantic model settings in Power BI portal. Refresh the page and you should see your newly created gateway. Click arrow icon and then click on Add to gateway link:
    ODBC{"connectionstring":"dsn=GoogleAnalyticsDSN"}
  7. Once you do that, you will create a new gateway connection. Give it a name, set Authentication method, Privacy level, and click Create button:
    In this example, we used the least restrictive Privacy level.
    If your connection uses a full connection string you may hit a length limitation when entering it into the field. To create the connection, you will need to shorten it manually. Check the section about the limitation of a full connection string on how to accomplish it.
    On-premises data gateway (personal mode) does not have this limitation.
  8. Proceed by choosing the newly created connection:
  9. Finally, you are at the final step where you can refresh the semantic model:
Refresh using On-premises data gateway (personal mode)
Here are the instructions on how to refresh a Power BI semantic model using On-premises data gateway (personal mode):
  2. If you see this view, it means you have to install On-premises data gateway (personal mode):
  4. Again, go to your semantic model Settings, expand Data source credentials, click Edit credentials, select Authentication method together with Privacy level, and then click Sign in button:
  5. Finally, you are ready to refresh your semantic model:
Centralized data access via Data Gateway
In some situations, you may need to provide Google Analytics data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
If you need any of these requirements, you will have to create a data source in Data Gateway to connect to Google Analytics, and to create an ODBC data source to connect to Data Gateway in Power BI.
Creating Google Analytics data source in Gateway
In this section we will create a data source for Google Analytics in Data Gateway. Let's follow these steps to accomplish that:
  1. Search for gateway in Windows Start Menu and open ZappySys Data Gateway Configuration:
    Opening Data Gateway
  2. Go to Users tab and follow these steps to add a Data Gateway user:
    • Click Add button
    • In Login field enter username, e.g., john
    • Check Is Administrator checkbox
    Data Gateway - Adding User
    • Click Add button
    • Give Datasource a name (have it handy for later)
    • Then select Native -
    GoogleAnalyticsDSN
    Data Gateway - Adding data source
  4. When the configuration window opens, configure the Data Source the same way you configured it in ODBC Data Sources (64-bit), in the beginning of this article.
  5. Very important step. Now, after creating or modifying the data source make sure you:
    • Hit Yes, once asked if you want to restart the Data Gateway service.
    This will ensure all changes are properly applied:
    Skipping this step may result in the new settings not taking effect and, therefore you will not be able to connect to the data source.
Creating ODBC data source for Data Gateway
In this part we will create ODBC data source to connect to Data Gateway from Power BI. To achieve that, let's perform these steps:
  1. Open ODBC Data Sources (x64):
  2. Create a User data source (User DSN) based on ODBC Driver 17 for SQL Server:
    If you don't see ODBC Driver 17 for SQL Server driver in the list, choose a similar version driver.
  3. Then set a Name of the data source (e.g. Gateway) and the address of the Data Gateway:
    GatewayDSN
  4. Proceed with authentication part:
    • In Login ID field enter the user name you used in Data Gateway, e.g., john
    • Set Password to the one you configured in Data Gateway
  5. Then set the default database property to GoogleAnalyticsDSN (the one we used in Data Gateway):
    GoogleAnalyticsDSN
  6. Continue by checking Trust server certificate option:
  8. If connection is successful, everything is good:
Accessing data in Power BI via Data Gateway
Finally, we are ready to read data from Google Analytics in Power BI via Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
  4. Another window opens and asks to select a Data Source we already created. Choose GatewayDSN and continue:
    GatewayDSN
  5. Read the data the same way we discussed at the beginning of this article.
  6. That's it!
Now you can connect to Google Analytics data in Power BI via the Data Gateway.
If you are asked for authentication details, use Database authentication or SQL Authentication option and enter credentials you used when configuring Data Gateway, e.g. john and your password.
In this article we showed you how to connect to Google Analytics in Power BI and integrate data without any coding, saving you time and effort.
We encourage you to download Google Analytics Connector for Power BI and see how easy it is to use it for yourself or your team.
If you have any questions, feel free to contact ZappySys support team. You can also open a live chat immediately by clicking on the chat icon below.
Download Google Analytics Connector for Power BI Documentation
More integrations
Other connectors for Power BI
All
Big Data & NoSQL
Database
CRM & ERP
Marketing
Collaboration
Cloud Storage
Reporting
Commerce
API & Files
