While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Jira Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    JiraDSN
    Jira
    API Key based Authentication
    Jira authentication
    1. Go to Profile > Security.
    5. That's it!
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
      Name OAuth app in Atlassian
        • offline_access (a must)
        • read:jira-user
        • read:jira-work
        • write:jira-work
        • manage:jira-project
        • manage:jira-configuration
    JiraDSN
    Jira
    ZappySys API Driver - Jira
    JiraDSN
  8. Then simply select the Make Generic REST API Request endpoint (action).
    HTTP - Url or File Path Select the value from the dropdown
    HTTP - Request Body
    HTTP - Headers (e.g. hdr1:aaa || hdr2:bbb) Accept: */* || Cache-Control: no-cache
    Parser - Filter (e.g. $.rows[*] )
    Download - Enable reading binary data False
    Download - File overwrite mode AlwaysOverwrite
    Download - Save file path
    Download - Enable raw output mode as single row False
    Download - Raw output data RowTemplate {Status:'Downloaded'}
    Download - Request Timeout (Milliseconds) 0
    HTTP - Request Method GET
    HTTP - Is MultiPart Body (Pass File data/Mixed Key/value) False
    HTTP - Request Format (Content-Type) ApplicationJson
    Parser - Response Format (Default=Json) Default
    Parser - Include Parent Columns True
    Parser - Parent Column Prefix P_
    Parser - Include Parent When Child Null False
    Parser - Encoding
    Parser - CharacterSet
    General - Enable Custom Search/Replace False
    General - SearchFor (e.g. (\d)-(\d)--regex)
    General - ReplaceWith (e.g. $1-***)
    General - File Compression Type None
    General - Date Format
    General - Enable Big Number Handling False
    General - Wait time (Ms) - Helps to slow down pagination (Use for throttling) 0
    JSON/XML - Exclude columns (e.g. meta,info)
    JSON/XML - ExcludedProperties (deprecated, no effect: use Exclude columns)
    JSON/XML - Flatten Small Array (Not preferred for more than 10 items) False
    JSON/XML - Max Array Items To Flatten 10
    JSON/XML - Array Transform Type None
    JSON/XML - Array Transform Column Name Filter
    JSON/XML - Array Transform Row Value Filter
    JSON/XML - Array Transform Enable Custom Columns False
    JSON/XML - Enable Pivot Transform False
    JSON/XML - Array Transform Custom Columns
    JSON/XML - Pivot Path Replace With
    JSON/XML - Enable Pivot Path Search Replace False
    JSON/XML - Pivot Path Search For
    JSON/XML - Include Pivot Path False
    JSON/XML - Throw Error When No Match for Filter False
    Pagination - Mode ByResponseAttribute
    Pagination - Attribute Name (e.g. page)
    Pagination - Increment By (e.g. 100) 1
    Pagination - Expression for Next URL (e.g. $.nextUrl)
    Pagination - Wait time after each request (milliseconds) 0
    Pagination - Max Rows Expr
    Pagination - Max Pages Expr
    Pagination - Max Rows DataPath Expr
    Pagination - Max Pages 0
    Pagination - End Rules
    Pagination - Next URL Suffix
    Pagination - FetchXML Parameter (paging cookie)
    Pagination - Delta Link Expression
    Pagination - Next URL End Indicator
    Pagination - Stop Indicator Expr
    Pagination - Current Page
    Pagination - End Strategy Type DetectBasedOnRecordCount
    Pagination - Stop based on this Response StatusCode
    Pagination - When EndStrategy Condition Equals True
    Pagination - Max Response Bytes
    Pagination - Min Response Bytes
    Pagination - Error String Match
    Pagination - Enable Page Token in Body False
    Pagination - Placeholders (e.g. {page})
    Pagination - Has Different NextPage Info False
    Pagination - First Page Body Part
    Pagination - Next Page Body Part
    Csv - Column Delimiter ,
    Csv - Has Header Row True
    Csv - Throw error when column count mismatch False
    Csv - Throw error when no record found False
    Csv - Allow comments (i.e. line starts with # treat as comment and skip line) False
    Csv - Comment Character #
    Csv - Skip rows 0
    Csv - Ignore Blank Lines True
    Csv - Skip Empty Records False
    Csv - Skip Header Comment Rows 0
    Csv - Trim Headers False
    Csv - Trim Fields False
    Csv - Ignore Quotes False
    Csv - Treat Any Blank Value As Null False
    Xml - ElementsToTreatAsArray
    JiraDSN
Jira SQL query examples
Get __DynamicRequest__
generic_request endpoint belongs to __DynamicRequest__ table(s), and can therefore be used via those table(s).
  6. Once the ODBC window opens, click Connect Asset and select your JiraDSN DSN from the list.
Jira Connector actions
Need another use case? Pick the next Jira action in Alteryx below.
You now know how to make generic REST API request in Alteryx without writing complex code. Jira ODBC Driver handled pagination and authentication automatically.
