While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Jira Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    JiraDSN
    Jira
    API Key based Authentication
    Jira authentication
    1. Go to Profile > Security.
    5. That's it!
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
      Name OAuth app in Atlassian
        • offline_access (a must)
        • read:jira-user
        • read:jira-work
        • write:jira-work
        • manage:jira-project
        • manage:jira-configuration
    JiraDSN
    Jira
    ZappySys API Driver - Jira
    JiraDSN
  8. Then simply select the Read Worklogs endpoint (action).
    Read Worklogs
    Fields id,key
    Issue Key(s) or Ids - Comma Separated (CBS-10,PRA-13)
    Search by JQL
    Project Key(s) - Comma Separated (CBS,BRK)
    JQL Expression (For Issue Search) created >= 1970-01-01
    CustomColumnsRegex
    PagingMaxRowsExpr $.total
    PagingMaxRowsDataPathExpr $.issues[*]
    Continue on Error String False
    Error String To Match does not exist
    PagingMode ByResponseAttribute
    NextUrlAttributeOrExpr $.nextPageToken
    NextUrlSuffix nextPageToken=<%nextlink%>
    SELECT * FROM Worklogs WITH (Jql='status IN (Done, Closed) AND created > -5d' )
    JiraDSN
Jira SQL query examples
Read worklogs for issues by JQL
Gets all worklogs for issues that match a JQL expression. The connector finds issues with the given JQL, then returns time entries for those issues. Use the same JQL syntax as in the “Read issues using JQL query” example.
Read worklogs
Gets all worklog (time) entries from every issue. Use this when you need a single list of all time entries. To limit by issue or date, use the examples that filter by issue ID/Key, by JQL, or by modified-after date.
get_worklogs endpoint belongs to Worklogs table(s), and can therefore be used via those table(s).
Read worklogs in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your JiraDSN DSN from the list.
Jira Connector actions
Need another use case? Pick the next Jira action in Alteryx below.
You now know how to read worklogs in Alteryx without writing complex code. Jira ODBC Driver handled pagination and authentication automatically.
