While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Jira Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    JiraDSN
    Jira
    API Key based Authentication
    Jira authentication
    1. Go to Profile > Security.
    5. That's it!
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
      Name OAuth app in Atlassian
        • offline_access (a must)
        • read:jira-user
        • read:jira-work
        • write:jira-work
        • manage:jira-project
        • manage:jira-configuration
    JiraDSN
    Jira
    ZappySys API Driver - Jira
    JiraDSN
    Url /something/123
    Filter
    Request Method POST
    IsMultiPart False
    Body {$rows$}
    JsonOutputFormat Multicontent
    DoNotOutputNullProperty False
    Batch Size (Default=1) 1
    Request Format Default
    Response Format Default
    Csv - Column Delimiter ,
    Csv - Row Delimiter {NEWLINE}
    Csv - Quote Around Value True
    Encoding
    CharacterSet
    Writer DateTime Format
    Csv - Has Header Row True
    Xml - ElementsToTreatAsArray
        "Url" = '/something/123',
        "RequestMethod" = 'POST'
    JiraDSN
Jira SQL query examples
Make generic rest api request
  6. Once the ODBC window opens, click Connect Asset and select your JiraDSN DSN from the list.
Jira Connector actions
Need another use case? Pick the next Jira action in Alteryx below.
You now know how to make generic REST API request (bulk write) in Alteryx without writing complex code. Jira ODBC Driver handled pagination and authentication automatically.
