When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
JiraDSNJira
- Configure the authentication in Jira.
API Key based Authentication
Jira authentication
Firstly, login into your Atlassian account and then go to your Jira profile:- Go to Profile > Security.
- Click Create and manage API tokens.
- Then click Create API token button and give your token a label.
- When window appears with new API token, copy and use it in this connection manager.
- That's it!
API Key based Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
JiraDSNJiraAPI Key based Authentication [Http]https://[$Subdomain$].atlassian.net/rest/api/3Required Parameters Subdomain Fill-in the parameter... Atlassian User Name (email) Fill-in the parameter... API Key Fill-in the parameter... Optional Parameters CustomColumnsRegex RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Jira Connector authentication reference.Personal Access Token (PAT) Authentication
Jira authentication
Follow official Atlassian instructions on how to create a PAT (Personal Access Token) for JIRAAPI Connection Manager configuration
Personal Access Token (PAT) Authentication [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
JiraDSNJiraPersonal Access Token (PAT) Authentication [Http]https://[$Subdomain$].atlassian.net/rest/api/3Required Parameters Subdomain Fill-in the parameter... Token (PAT Bearer Token) Fill-in the parameter... Optional Parameters CustomColumnsRegex RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Jira Connector authentication reference.OAuth (**Must change API Base URL to V3 OAuth**)
Jira authentication
Firstly, login into your Atlassian account and then create Jira application:- Go to Atlassian Developer area.
Click Create and select OAuth 2.0 integration item to create an OAuth app:
Give your app a name, accept the terms and hit Create:
To enable permissions/scopes for your application, click Permissions tab, then hit Add button, and click Configure button, once it appears:
Continue by hitting Edit Scopes button to assign scopes for the application:
Select these scopes or all of them:
Then click Authorization option on the left and click Add button:
Enter your own Callback URL (Redirect URL) or simply enter
https://zappysys.com/oauth, if you don't have one:
Then hit Settings option and copy Client ID and Secret into your favorite text editor (we will need them in the next step):
Now go to SSIS package or ODBC data source and in OAuth authentication set these parameters:
- For ClientId parameter use Client ID value from the previous steps.
- For ClientSecret parameter use Secret value from the previous steps.
- For Scope parameter use the Scopes you set previously (specify them all here):
- offline_access (a must)
- read:jira-user
- read:jira-work
- write:jira-work
- manage:jira-project
- manage:jira-configuration
NOTE: A full list of available scopes is available in Atlassian documentation. -
For Subdomain parameter use your Atlassian subdomain value
(e.g.
mycompany, if full host name ismycompany.atlassian.net).
- Click Generate Token to generate tokens.
- Finally, select Organization Id from the drop down.
- That's it! You can now use Jira Connector!
OAuth (**Must change API Base URL to V3 OAuth**) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
JiraDSNJiraOAuth (**Must change API Base URL to V3 OAuth**) [OAuth]https://[$Subdomain$].atlassian.net/rest/api/3Required Parameters ClientId Fill-in the parameter... ClientSecret Fill-in the parameter... Scope Fill-in the parameter... ReturnUrl Fill-in the parameter... Organization Id (Select after clicking [Generate Token]) Fill-in the parameter... Optional Parameters Custom Columns for output (Select after clicking [Generate Token]) RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Jira Connector authentication reference. -
ZappySys API Driver - JiraRead and write Jira data effortlessly. Track, manage, and automate issues, projects, worklogs, and comments — almost no coding required.JiraDSN
Then simply select the Projects table and Insert operation.
ZappySys API Driver - JiraRead and write Jira data effortlessly. Track, manage, and automate issues, projects, worklogs, and comments — almost no coding required.JiraDSNINSERT INTO Projects(ProjectKey, Name, ProjectTypeKey, LeadAccountId, AssigneeType) VALUES ('TEST', 'Test Project', 'software', '70122:XXXXXXXX-XXXX-XXXX-XXXX-c5da8c98b9e2', 'PROJECT_LEAD') WITH (Output=1)
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Jira API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Jira servers).
Jira SQL query examples
Create a project
Creates a single project. Supply ProjectKey, Name, ProjectTypeKey, LeadAccountId, and AssigneeType. Use WITH (Output=1) to return the created project.
WITH (Output=1)
create_project endpoint belongs to
Projects
Create project in Alteryx via SQL view
Once the ODBC window opens, click Connect Asset and select your JiraDSN DSN from the list.
Jira Connector actions
Need another use case? Pick the next Jira action in Alteryx below.
- Create Issue Comment
- Create Issues
- Create User
- Create Worklog
- Delete Issue
- Delete Issue Comment
- Delete Project
- Delete User
- Delete Worklog
- Get custom field context options
- Get custom field contexts
- Read Application Roles
- Read Changelog Details
- Read Changelogs
- Read Changelogs by IDs
- Read Comments
- Read Custom Fields
- Read Fields
- Read Groups
- Read Issue (By Id)
- Read Issue Types
- Read Issues
- Read Projects
- Read Resources
- Read Users
- Read Worklogs
- Read Worklogs modified after a specified date
- Update Issue
- Update Issue Comment
- Update Worklog
- Upsert Project
You now know how to create project in Alteryx without writing complex code. Jira ODBC Driver handled pagination and authentication automatically.
