While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Jira Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    JiraDSN
    Jira
    API Key based Authentication
    Jira authentication
    1. Go to Profile > Security.
    5. That's it!
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
      Name OAuth app in Atlassian
        • offline_access (a must)
        • read:jira-user
        • read:jira-work
        • write:jira-work
        • manage:jira-project
        • manage:jira-configuration
    JiraDSN
    Jira
    ZappySys API Driver - Jira
    JiraDSN
  8. Then simply select the Issues table and Update operation.
    Issues
    Update
    IssueIdOrKey
    NotifyUsers false
    OverrideScreenSecurity false
    OverrideEditableFlag false
    Continue On 404 Error (When record not found) False
    UPDATE Issues
    SET Summary = 'This is my summary'
       ,Description = 'Lot''s of stuff to describe'
       ,Labels = '[ "bugfix" ]'
       ,DueDate = '2029-10-10'
    --WHERE Id=1234
    --WHERE Id='ISSKEY'
    WITH (
    	IssueIdOrKey='ISSKEY', --or use Id in where clause
    	Output=1,
    	NotifyUsers=0,
    	OverrideScreenSecurity=0,
    	OverrideEditableFlag=0,
    	ContinueOn404Error=0
    JiraDSN
    UPDATE Issues
    --WHERE Id=1234
    --WHERE Id='ISSKEY'
    WITH (
    	Output=1,
    	NotifyUsers=0,
Jira SQL query examples
Update an issue
Updates an existing issue. Set the columns you want to change (Summary, Description, Labels, DueDate, etc.) and identify the issue with IssueIdOrKey in WITH or in a WHERE clause. Optional WITH parameters control notifications and security overrides.
UPDATE Issues
--WHERE Id=1234
--WHERE Id='ISSKEY'
WITH (
	Output=1,
	NotifyUsers=0,
Update or create an issue with custom fields
Updates or creates an issue including custom fields of various types: dropdown, radio, checkboxes, date, labels, number, paragraph, URL, user, team, and single-line text. Use the custom field ID (e.g. customfield_10050) and the appropriate suffix or raw JSON format as shown in the example. For insert, use the same column list in INSERT INTO Issues(...).
UPDATE Issues
SET customfield_10050='[{"value":"AAA"},{"value":"BBB"}]'	--CUSTOM Checkboxes field update (Must use Raw JSON)
,customfield_10051='2020-12-31'	--CUSTOM Date field update
,customfield_10052='2020-12-31T23:59:59'	--CUSTOM DateTime field update
--Custom Dropdown / Radio fields
,customfield_10048_value='BBB'	--CUSTOM Dropdown field update (Using value - i.e. item label)
--OR--
--,customfield_10048_id='10022'	--CUSTOM Dropdown field update (Using id - i.e. item id)
--OR--
--,customfield_10048='{"value":"BBB"}'	--CUSTOM Dropdown (Using Raw value)
,customfield_10053='["bugfix","test"]'	--CUSTOM Labels field update (Must use Raw JSON)
,customfield_10057='[{"value":"AAA"},{"value":"BBB"}]'	--CUSTOM Listbox Multiselect field update (Must use Raw JSON)
,customfield_10049=123455555.123	--CUSTOM Number field update
,customfield_10054_text='Long string...line-1
	Long string... line-2
	Long string... line-3'	--CUSTOM Paragraph field update
,customfield_10055_value='BBB'	--CUSTOM Radio field update by value
--OR--
--,customfield_10055_id='10023'	--CUSTOM Radio field update
,customfield_10058='https://zappysys.com'	--CUSTOM Url field update
,customfield_10059_accountId="5dd64082af96bc0efbe55103" --CUSTOM User field update (update by accountId)
--OR--
--,customfield_10059='{"accountId":"5dd64082af96bc0efbe55103","displayName":"System"}'	--CUSTOM User field update --accountId=5dd64082af96bc0efbe55103
,customfield_10060='Custom text single line'	--CUSTOM text single line field
,customfield_10001='577069e1-1bcd-4b1e-9070-0b2475830d1c'	--CUSTOM Team field update (update by Team Id)
--WHERE Id=10000
WITH (
	Output=1,
	NotifyUsers=0,
--For INSERT use same values with same fields like below. For Insert you do not have to specify Id or Key
--INSERT INTO Issues(ProjectKey, IssueTypeName, Summary, Description, customfield_10050,....., customfield_10060)
--VALUES ('SMP', 'Task', 'My ticket inserted through the API', 'A description about an issue', '[{"value":"AAA"},{"value":"BBB"}]' ,... 'Custom text single line')
Update multiple issues by JQL
Updates every issue that matches a JQL expression. Add a WHERE condition (e.g. Where 1=1) so the connector uses the lookup path, then supply the JQL in WITH (jql='...'). All matching issues receive the same column updates.
UPDATE Issues
SET Summary = 'This is done on <<fun_now>>'
Where 1=1
WITH (jql='status=done' , ContinueOn404Error=0)
--WITH (jql='key in(10001, 10002, 10003)' , ContinueOn404Error=0)
--WITH (jql='key in(CS-1, CS-2, CS-3)', ContinueOn404Error=0)
Update custom option field (dropdown or radio)
Shows how to update a custom field that uses a single option (dropdown or radio). You can set the value by option label (customfield_xxxx_value), by option ID (customfield_xxxx_id), or with raw JSON. To clear the field, set it to null. Replace the custom field ID with your own from Fields.
--(By value)
UPDATE Issues
SET customfield_10048_value ='BBB' --supply value (label) of dropdown/radio
WITH (IssueIdOrKey='10020')
--OR-- (By item ID)
UPDATE Issues
SET customfield_10048_id =10023 --supply id of dropdown/radio item
--OR-- (Raw id)
UPDATE Issues
SET customfield_10048='{"id":"10023"}' --supply raw json
--OR--  (Raw value)
UPDATE Issues
SET customfield_10048='{"value":"BBB"}' --supply raw json
--OR--  (set null)
UPDATE Issues
SET customfield_10048 =null
Update custom multi-select, user, or team fields (raw JSON)
Shows how to update custom fields that hold multiple values or complex types (e.g. multi-select, user, team) using raw JSON. Supply a JSON array or object as required by the field type; to clear, set the column to null. Use SELECT * FROM Fields to find your custom field IDs.
UPDATE Issues
SET customfield_10048='[{"value":"AAA"}, {"value":"CCC"}]' --supply raw json
--OR--
UPDATE Issues
SET customfield_10048 =null --set to null
update_issue endpoint belongs to Issues table(s), and can therefore be used via those table(s).
Update issue in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your JiraDSN DSN from the list.
Jira Connector actions
Need another use case? Pick the next Jira action in Alteryx below.
You now know how to update issue in Alteryx without writing complex code. Jira ODBC Driver handled pagination and authentication automatically.
