While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Jira Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Jira" from the list of Popular Connectors. If "Jira" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    JiraDSN
    Jira
    API Key based Authentication
    Jira authentication
    1. Go to Profile > Security.
    5. That's it!
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
    JiraDSN
    Jira
    CustomColumnsRegex
    Jira authentication
      Name OAuth app in Atlassian
        • offline_access (a must)
        • read:jira-user
        • read:jira-work
        • write:jira-work
        • manage:jira-project
        • manage:jira-configuration
    JiraDSN
    Jira
    ZappySys API Driver - Jira
    JiraDSN
  8. Then simply select the Read Issues endpoint (action).
    Read Issues
    Fields *all
    Search by JQL
    Project Key(s) - Comma Separated (CBS,BRK)
    JQL Expression (For Issue Search) created >= 1970-01-01
    Issue Key(s) or Ids - Comma Separated (CBS-10,PRA-13)
    CustomColumnsRegex
    Metadata Mode (Change if columns missing or NULL) **SLOW**
    PagingMaxRowsExpr $.total
    PagingMaxRowsDataPathExpr $.issues[*]
    Continue on Error String False
    Error String To Match does not exist
    PagingMode ByResponseAttribute
    NextUrlAttributeOrExpr $.nextPageToken
    NextUrlSuffix nextPageToken=<%nextlink%>
    SELECT * FROM Issues
    --//Query single issue by numeric Issue Id
    --SELECT * FROM Issues Where Id=101234
    --//Query issue by numeric Issue Ids (multiple)
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='101234,101235,101236')
    --//Query issue by Issue Key(s) (alpha-numeric)
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11')
    --SELECT * FROM Issues WITH(SearchBy='Key', Key='PROJ-11,PROJ-12,PROJ-13')
    --//Query issue by project(s)
    --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ')
    --SELECT * FROM Issues WITH(SearchBy='Project', Project='PROJ,KAN,CS')
    --//Query issue by JQL expression
    --SELECT * FROM Issues WITH(SearchBy='Jql', Jql='status IN (Done, Closed) AND created > -5d' )
    JiraDSN
Jira SQL query examples
Read issues
Gets all issues. By default the query returns every issue; you can narrow results by adding a WITH clause to search by Key, Project, or JQL expression (see the commented options in the code).
Use SearchBy='Key' with a single key or ID for one issue, or comma-separated keys/IDs for multiple. Use SearchBy='Project' to limit to one or more project codes. Use SearchBy='Jql' with a JQL expression for advanced filtering.
Read an issue by ID
Gets a single issue by its key (e.g. CS-123) or numeric ID (e.g. 10001). Supply the key or ID in the Key parameter; the connector returns that issue’s fields.
SELECT * FROM Issues WITH(SearchBy='Key', Key='10001')
Read an issue by ID — continue on specific error
By default, if the issue is not found or the search condition is invalid, the query returns an error. You can tell the connector to continue instead by setting ContineOnErrorForMessage=1 and supplying the error message (or a substring) to ignore in ErrorSubstringToMatch.
SELECT * FROM Issues WITH(SearchBy='Key', Key='10001', ContineOnErrorForMessage=1, ErrorSubstringToMatch='Issue does not exist')
Read an issue by Key
Gets a single issue by its project key and number (e.g. CS-1). Same as reading by ID; use whichever identifier you have.
SELECT * FROM Issues WITH(SearchBy='Key', Key='CS-1')
Read multiple issues by ID or Key
Gets multiple issues in one request. Supply comma-separated keys and/or numeric IDs in the Key parameter; the connector returns all matching issues.
SELECT * FROM Issues WITH(SearchBy='Key', Key='CS-1,CS-2,10003,10004')
Read issues for a project
Gets all issues belonging to a given project (or projects). Supply one or more project codes in Project; use a comma-separated list for multiple projects.
SELECT * FROM Issues WITH(SearchBy='Project', Project='CS')
Read issues (specific fields only)
Gets all issues but returns only the columns you specify in Fields, which can speed up the query when you need just a few fields. Use a comma-separated list of field names; *all returns every field.
SELECT * FROM Issues WITH(Fields='id,key,summary,status')
Read issues using JQL query
Gets issues that match a JQL (Jira Query Language) expression. Supply the JQL string in the Jql parameter; you can filter by status, project, date, assignee, text, and more.
See the commented examples in the code for common patterns (IDs, keys, dates, text search, etc.). JQL reference links are included in the snippet.
SELECT * FROM Issues WITH (Jql='status IN (Done, Closed) AND created > -5d' )
Useful links:
  https://support.atlassian.com/jira-work-management/docs/jql-fields/
  https://www.atlassian.com/software/jira/guides/jql/tutorials#advanced-search
  https://www.atlassian.com/blog/jira/jql-the-most-flexible-way-to-search-jira-14
Other Possible JQL expressions:
Ids (IN):       key IN(10001, 10002, 10003);
Keys (IN):       key IN(CS-1, CS-2, CS-3);
Projects (IN):       project IN(PROJ1, PROJ2, PROJ3);
Status (EQUAL):       status='Done';
Date (Expression 1):       created >=-5d;
Date (Expression 2):       created >=startOfMonth() AND created <=now();
Date (Expression 3):       created >=startOfYear() AND created <=startOfDay();
Date (Static):       created >= '2008/12/31';
Date (Static with time):       created >= '2008/12/31 23:59';
Project and Status (AND + IN):       project=CS AND status NOT IN ('Done', 'Open', 'Closed');
Assignee and Created Date:    assignee is NOT EMPTY and created < -1d;
Text (Contains - Fuzzy):       Summary ~ 'some words' OR description ~ 'some words';
Text (Contains - Fuzzy Wildcard):       Summary ~ 'some*' OR description ~ 'some*';
Text (Contains - Exact):       Summary ~ '\"exact words\"' OR description ~ '\"exact words\"';
Text (Does Not Contain - Fuzzy):       Summary !~ 'some words' OR description !~ 'some words';
Empty OR Null:   fixVersion is empty OR fixVersion is null;
Is Not Empty OR Is Not Null:    fixVersion is not empty OR fixVersion is not null;
WAS Operator (previous value):       status WAS "Resolved" BY (jsmith,srogen) BEFORE "2019/02/02";
WAS IN Operator:   status WAS IN ("Resolved", "In Progress");
WAS NOT IN Operator:    status WAS NOT IN ("Resolved", "In Progress");
WAS + BY + DURING (date range):       status WAS "Resolved" BY (jsmith,srogen) DURING("2019/02/02", "2020/02/02");
CHANGED operator:    assignee CHANGED;
CHANGED operator (multiple):       status CHANGED FROM "In Progress" TO "Open"
Read issues with all columns (including SLA / nested custom fields)
Gets issues with all columns exposed, including SLA and nested custom fields, without defining a META parameter. Set the connector’s Metadata Mode to MergeStaticDynamic so the driver scans sample data and merges static and dynamic columns. This approach is simpler but slower because of the extra requests used to infer column types from data.
-- No META needed. Set MetaDetectionOrder to MergeStaticDynamic so nested/SLA columns are discovered automatically.
-- Slower: driver makes extra requests to scan data and merge with static metadata.
SELECT *
FROM Issues
WITH(
	  JQL='project IN(SUP)'
	  ,MetaDetectionOrder='MergeStaticDynamic'
Read custom fields with nested structures (SLA fields)
Shows how to query custom fields that contain nested document structures (not arrays), such as SLA fields. Use META='@OverrideMode:1' to merge static and dynamic metadata so you can select both standard columns and nested custom field properties. Replace the example custom field IDs (e.g. customfield_10084) with your own; run SELECT * FROM Fields or check Jira project settings to find field IDs.
-- NOTE: Replace customfield_10084, customfield_10085, customfield_10086 with your own custom field IDs.
-- You can run [SELECT * FROM Fields] in preview tab to get the field IDs.
-- OR you can find field IDs in Jira: Project Settings > Issue types > Edit field > field ID in URL or API.
-- static fields
  id
, key
, summary
, statusname
-- dynamic fields
-- SLA: Time to Resolution (replace customfield_10084 with your SLA field ID)
,[fields.customfield_10084.id] as c10084_id
,[fields.customfield_10084.name] as c10084_name
,[fields.customfield_10084.ongoingCycle.startTime.friendly] as c10084_startTime_friendly
,[fields.customfield_10084.ongoingCycle.startTime.jira] as c10084_startTime_jira
,[fields.customfield_10084.ongoingCycle.breachTime.friendly] as c10084_breachTime_friendly
,[fields.customfield_10084.ongoingCycle.breachTime.jira] as c10084_breachTime_jira
,[fields.customfield_10084.ongoingCycle.elapsedTime.friendly] as c10084_elapsedTime_friendly
,[fields.customfield_10084.ongoingCycle.remainingTime.friendly] as c10084_remainingTime_friendly
,[fields.customfield_10084.ongoingCycle.goalDuration.friendly] as c10084_goalDuration_friendly
,[fields.customfield_10084.ongoingCycle.breached] as c10084_breached
,[fields.customfield_10084.ongoingCycle.paused] as c10084_paused
-- SLA: Time to First Response (replace customfield_10085 with your SLA field ID)
,[fields.customfield_10085.id] as c10085_id
,[fields.customfield_10085.name] as c10085_name
,[fields.customfield_10085.ongoingCycle.startTime.friendly] as c10085_startTime_friendly
,[fields.customfield_10085.ongoingCycle.startTime.jira] as c10085_startTime_jira
,[fields.customfield_10085.ongoingCycle.breachTime.friendly] as c10085_breachTime_friendly
,[fields.customfield_10085.ongoingCycle.breachTime.jira] as c10085_breachTime_jira
,[fields.customfield_10085.ongoingCycle.elapsedTime.friendly] as c10085_elapsedTime_friendly
,[fields.customfield_10085.ongoingCycle.remainingTime.friendly] as c10085_remainingTime_friendly
,[fields.customfield_10085.ongoingCycle.goalDuration.friendly] as c10085_goalDuration_friendly
,[fields.customfield_10085.ongoingCycle.breached] as c10085_breached
,[fields.customfield_10085.ongoingCycle.paused] as c10085_paused
-- SLA: Time to Close After Resolution (replace customfield_10086 with your SLA field ID)
,[fields.customfield_10086.id] as c10086_id
,[fields.customfield_10086.name] as c10086_name
-- Other nested custom fields (replace IDs as needed)
,[fields.customfield_10024.id] as c10024_id
,[fields.customfield_10024.name] as c10024_name
,[fields.customfield_10075.languageCode] as c10075_languageCode
,[fields.customfield_10075.displayName] as c10075_displayName
FROM Issues
WITH(
	  -- @OverrideMode:1 merges metadata so you can use static + dynamic fields together
	  ,META='@OverrideMode:1
	  ;fields.customfield_10084.id : string(10)
	  ;fields.customfield_10084.name : string(180)
	  ;fields.customfield_10084.ongoingCycle.startTime.friendly : string(130)
	  ;fields.customfield_10084.ongoingCycle.startTime.jira : DateTime
	  ;fields.customfield_10084.ongoingCycle.breachTime.friendly : string(130)
	  ;fields.customfield_10084.ongoingCycle.breachTime.jira : DateTime
	  ;fields.customfield_10084.ongoingCycle.elapsedTime.friendly : string(30)
	  ;fields.customfield_10084.ongoingCycle.remainingTime.friendly : string(70)
	  ;fields.customfield_10084.ongoingCycle.goalDuration.friendly : string(30)
	  ;fields.customfield_10084.ongoingCycle.breached : Boolean
	  ;fields.customfield_10084.ongoingCycle.paused : Boolean
	  ;fields.customfield_10085.id : string(10)
	  ;fields.customfield_10085.name : string(220)
	  ;fields.customfield_10085.ongoingCycle.startTime.friendly : string(130)
	  ;fields.customfield_10085.ongoingCycle.startTime.jira : DateTime
	  ;fields.customfield_10085.ongoingCycle.breachTime.friendly : string(130)
	  ;fields.customfield_10085.ongoingCycle.breachTime.jira : DateTime
	  ;fields.customfield_10085.ongoingCycle.elapsedTime.friendly : string(30)
	  ;fields.customfield_10085.ongoingCycle.remainingTime.friendly : string(70)
	  ;fields.customfield_10085.ongoingCycle.goalDuration.friendly : string(30)
	  ;fields.customfield_10085.ongoingCycle.breached : Boolean
	  ;fields.customfield_10085.ongoingCycle.paused : Boolean
	  ;fields.customfield_10086.id : string(10)
	  ;fields.customfield_10086.name : string(300)
	  ;fields.customfield_10024.id : string(40)
	  ;fields.customfield_10024.name : string(80)
	  ;fields.customfield_10075.languageCode : string(20)
	  ;fields.customfield_10075.displayName : string(70)
	  ;--add more nested custom field properties here as needed--
get_issues endpoint belongs to Issues table(s), and can therefore be used via those table(s).
Read issues in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your JiraDSN DSN from the list.
Jira Connector actions
Need another use case? Pick the next Jira action in Alteryx below.
You now know how to read issues in Alteryx without writing complex code. Jira ODBC Driver handled pagination and authentication automatically.
