Create data source using Azure DevOps ODBC Driver
Watch this quick walkthrough to see how to configure your Azure DevOps ODBC data source, or scroll down for the step-by-step written guide.
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Azure DevOps Connector.
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Azure DevOps" from the list of Popular Connectors. If "Azure DevOps" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    AzureDevopsDSN
    Azure DevOps
    • Configure the authentication in Azure DevOps.
    User Credentials
    Azure DevOps authentication
    Delegated access using OAuth authorization code flow. Users sign in with their Azure AD account. [API reference]
    WARNING: To automate your company's processes, make sure you use a system/generic account (e.g. automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.
    1. Navigate to the Azure Portal and log in using your credentials.
    2. Access Microsoft Entra ID.
    3. Register a new application by going to App registrations and clicking on New registration button: Start new app registration in Microsoft Entra ID
      INFO: Find more information on how to register an application in Graph API reference.
    4. When configuration window opens, configure these fields:
      • Supported account type
        • Use Accounts in this organizational directory only, if you need access to data in your organization only.
      • Redirect URI:
        • Set the type to Public client/native (mobile & desktop).
        • Use https://zappysys.com/oauth as the URL.
      Register app in Microsoft Entra ID
    5. After registering the app, copy the Application (client) ID for later: Copy client ID of Microsoft Entra ID app
    6. Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration: Copy Auth and Token URLs in Microsoft Entra ID app
    7. Now go to SSIS package or ODBC data source and use the copied values in User Credentials authentication configuration:
      • In the Authorization URL field paste the OAuth authorization endpoint (v2) URL value you copied in the previous step.
      • In the Token URL field paste the OAuth token endpoint (v2) URL value you copied in the previous step.
      • In the Client ID field paste the Application (client) ID value you copied in the previous step.
      • In the Scope field use the default value or select individual scopes, e.g.:
        • vso.project
        • vso.work_full
        Admin consent note:
        • Token generation can still ask for admin approval, even when delegated scopes are listed in API permissions.
        • A Global Administrator can allow user consent for selected low-impact delegated permissions.
        • If tenant policy blocks user consent, an administrator must approve the requested delegated permissions.
        Settings: User consent settings (Entra ID > Enterprise apps > Consent and permissions > User consent settings). Docs: configure user consent, recommended settings.
    8. Press Generate Token button to generate Access and Refresh Tokens.
    9. Optional step. Choose Default Drive Id from the drop down menu.
    10. Click Test Connection to confirm the connection is working. After that, choose Default Project Name in connection settings. Some endpoints (for example, work items) often work more reliably when a default project is selected; otherwise, you must supply the Project value each time.
    11. Done! Now you are ready to use the API Connector!
    1. Set Authentication Type to User Credentials [OAuth]
    AzureDevopsDSN
    Azure DevOps
    https://dev.azure.com
    Authorization URL Fill-in the parameter...
    Token URL Fill-in the parameter...
    Application (client) ID Fill-in the parameter...
    Organization name or Id (e.g. mycompany) Fill-in the parameter...
    Return URL Fill-in the parameter...
    Scopes (Must match with App Registration) Fill-in the parameter...
    API Version Fill-in the parameter...
    Client Secret
    Refresh Token File Path
    Default Project Name (Choose after Generating Token)
    Find full details in the Azure DevOps Connector authentication reference.
    Azure App Credentials
    Use Azure AD service principal credentials (client id + secret) with the client credentials flow. Recommended for automated server-to-server access instead of PAT or delegated OAuth. [API reference]
    Step 1: Register the App in Microsoft Entra ID (AAD)
    1. Go to the Azure Portal > Microsoft Entra ID > App registrations and click New registration: Start new app registration in Microsoft Entra ID
    2. Name it (e.g., ZS-AzureDevOps-AppCred).
    3. Set Supported account types to "Accounts in this organizational directory only" (Single Tenant): Register app in Microsoft Entra ID
    4. Leave Redirect URI blank (it's not used for Client Credentials).
    5. Click Register.
    Step 2: Create a Client Secret
    1. In your new app, go to Certificates & secrets.
    2. Click New client secret, give it a name, and set an expiration.
    3. Copy the Secret Value immediately. You will never see it again once you leave the page: Copy client Secret of Microsoft Entra ID app
    Step 3: Set Permissions and Admin Consent
    1. Go to API permissions > Add a permission.
    2. Select Azure DevOps and click Delegated permissions.
    3. Check the necessary scopes (e.g., vso.project, vso.work_full).
    4. Crucial: Click Grant admin consent for [Your Tenant]. Without this, the app cannot authenticate in the background.
    Step 4: Map the App to Azure DevOps Organization
    1. Copy your Application (client) ID from the App Overview page.
    2. Open Organization settings > Users (you must add the Entra app here as a user). Use any of these ways to reach that page:
      • Direct URL: after you sign in, open https://dev.azure.com/YOUR_ORG_NAME/_settings/users, replacing YOUR_ORG_NAME with your organization name (the same value you enter in the connector Organization field). Example: https://dev.azure.com/contoso/_settings/users.
      • From the DevOps home page: go to https://dev.azure.com, select your organization, then in the lower-left corner choose Organization settings (gear). In the left pane under General, open Users.
      See also: About user, team, project, and organization-level settings and Add users to your organization or project.
    3. Click Add users, paste the Application (client) ID in the search box, and select the App.
    4. Assign an Access level (usually Basic) and add it to the relevant Projects.
    Step 5: Connection Settings
    In your SSIS package or ODBC data source, use the following in the App Credentials configuration:
    • In the Token URL field, paste the OAuth token endpoint (v2) URL from the Azure Portal 'Endpoints' tab.
    • In the Client ID field, paste the Application (client) ID.
    • In the Client Secret field, paste the Secret Value copied in Step 2.
    • In the Scope field, use: https://app.vssps.visualstudio.com/.default
    Step 6: Finalize Connection
    1. Press Generate Token button to fetch the token using the Client Secret.
    2. Click Test Connection to confirm the setup. After that, choose Default Project Name in connection settings. Some endpoints (for example, work items) often work more reliably when a default project is selected; otherwise, you must supply the Project value each time.
    3. Done! You are ready to use the API Connector!
    1. Set Authentication Type to Azure App Credentials [OAuth]
    AzureDevopsDSN
    Azure DevOps
    Scopes (Use .default for App Credentials) Fill-in the parameter...
    Organization name or Id Fill-in the parameter...
    Azure App Credentials with Certificate (Sign JWT with Private Key)
    Same as Application Credentials but uses a client certificate instead of a secret. [API reference]
    2. Name it (e.g., ZS-AzureDevOps-CertAuth).
    4. Leave Redirect URI blank (it's not used for Client Credentials flows).
    5. Click Register.
    Step 2: Upload Client Certificate
    2. Click the Certificates tab, then click Upload certificate.
    3. Upload your public key certificate (.cer, .pem, or .crt). Keep the private key secure on your system.
    4. Copy the Thumbprint for your configuration: Copy certificate thumbprint
    3. Select the required scopes (e.g., vso.project, vso.work_full).
    4. Crucial: Click Grant admin consent for [Your Tenant]. Without this, the background service cannot acquire a token.
    3. Click Add users and paste the Application (client) ID in the search box to find the App.
    In your SSIS package or ODBC data source, use the following in the Client Certificate configuration:
    • Configure your Certificate Path or Thumbprint in the Client Certificate tab of the connector.
    • In the Scope field, make sure to use: https://app.vssps.visualstudio.com/.default
    1. Press Generate Token. The connector will sign the request using your certificate to fetch a token.
    3. Done! Your certificate-based connection is ready!
    1. Set Authentication Type to Azure App Credentials with Certificate (Sign JWT with Private Key) [OAuth]
    AzureDevopsDSN
    Azure DevOps
    Certificate: *** Configure [Client Certificate] Tab *** Fill-in the parameter...
    (Cloud) OAuth App - User Credentials (DEPRECATED)
    **DEPRECATED:** this OAuth-based user credential flow is legacy; for new integrations prefer the Azure App Credentials options below. Connecting to your Azure DevOps data requires you to authenticate your REST API access. Follow the instructions below:
    1. Go to https://app.vsaex.visualstudio.com/app/register to register your app.
    2. Fill in your application and company's information as required, and then select the scopes that your application needs. This should typically be Project and team (read and write) and Work items (read and write).
      Your selected scopes when registering your app must match the scopes you enter here on the connector screen. If they don't match, the connector will not be able to work with your Azure DevOps account!
      If you need further information about the scopes used in Azure DevOps, or need to see what to enter into the connector screen to match up with your selected scopes, visit https://learn.microsoft.com/en-us/azure/devops/integrate/get-started/authentication/oauth?view=azure-devops.
      Create OAuth application in Azure DevOps
      NOTE: For Authorization callback URL use your company's OAuth Redirect URL (if IT administrator provides you one) or you can use https://zappysys.com/oauth (it's safe).
    3. Select Create Application and then the Application Settings page will be displayed.
    4. Record the App ID for us to use later: Copy App ID in Azure DevOps
    5. And do the same with Client Secret: Use Client Secret to read Azure DevOps REST API data
    6. Then go to https://aex.dev.azure.com and select relevant organization on the left.
    7. Then copy Organization's host name part (e.g. acmeinc, if full host name is acmeinc.visualstudio.com), save it to a file, then open that organization by clicking its name in the list (this takes you into Azure DevOps for that org): Copy Organization Host in Azure DevOps
    8. Back at the connector screen, enter the App ID into the Client Id (App ID) field that was recorded in the previous step.
    9. Enter the Client Secret that was recorded in the previous step into the Client Secret field. In order to edit the text in this field, select the ellipses (...) button that appears when the textbox is clicked, and edit the Client Secret with the dialog box that appears.
    10. Enter the organization that was recorded in step 5 into the Organization name or Id for url field.
    11. Click Generate Token. If proper authentication occurs, you will see a notice saying so. You can click Yes to save a backup file of your generated tokens.
    12. Select the project you want to connect to by default from the Default Project (Choose after Generating Token) field.
    13. Select the Security tab.
    14. Enter https://auditservice.dev.azure.com,https://almsearch.dev.azure.com into the Additional Trusted Domains field.
    15. Select the Test Connection button at the bottom of the window to verify proper connectivity with your Azure DevOps account. After that, choose Default Project Name in connection settings. Some endpoints (for example, work items) often work more reliably when a default project is selected; otherwise, you must supply the Project value each time.
    16. If the connection test succeeds, select OK.
    17. To edit previously created app you can visit https://app.vsaex.visualstudio.com/me and see Applications and services section. Click on your desired app name.
    1. Set Authentication Type to (Cloud) OAuth App - User Credentials (DEPRECATED) [OAuth]
    AzureDevopsDSN
    Azure DevOps
    Client Id (App ID) Fill-in the parameter...
    (Cloud) Personal Access Token (PAT) (DEPRECATED)
    **DEPRECATED:** Personal Access Tokens are still supported but the new Azure App Credentials auth is recommended for security and automation. To connect to Azure DevOps using a Personal Access Token (PAT), you must first create a valid PAT:
    1. Start by going to https://aex.dev.azure.com and selecting relevant organization on the left.
    2. Then copy Organization's host name part (e.g. acmeinc, if full host name is acmeinc.visualstudio.com), save it to a file, then open that organization by clicking its name in the list (this takes you into Azure DevOps for that org): Copy Organization Host in Azure DevOps
    3. Next, click User settings icon and then click Personal access tokens: Click User Settings icon in Azure DevOps
    4. Then click New Token button to create a new personal access token: Create new token in Azure DevOps
    5. Continue by...
      • naming your token
      • selecting the right Organization
      • setting token's Expiration date (it's recommended to use Custom defined option and make it expire after one year or later)
      • and setting the Scopes:
      Finish creating token in Azure DevOps
      NOTE: You may be restricted from creating full-scoped PATs. If so, your Azure DevOps administrator in Azure AD has enabled a policy which limits you to a specific custom defined set of scopes.
    6. Now click Copy button and save the newly created token into a file for quick access later: Use Azure DevOps token to read REST API data
    7. Go back to the connector screen, input the token you saved in a previous step into the Personal Access Token (PAT) field.
    8. Then enter the Organization host name part that you noted recorded in previous step into Organization name or Id for url field.
    9. Enter the name or Id of the project you want to connect to by default in the Default Project (Choose after above fields) field.
    10. Select the Security tab.
    11. Enter https://auditservice.dev.azure.com,https://almsearch.dev.azure.com,https://analytics.dev.azure.com into the Additional Trusted Domains field.
    12. Select the Test Connection button at the bottom of the window to verify proper connectivity with your Azure DevOps account. After that, choose Default Project Name in connection settings. Some endpoints (for example, work items) often work more reliably when a default project is selected; otherwise, you must supply the Project value each time.
    13. Done!
    1. Set Authentication Type to (Cloud) Personal Access Token (PAT) (DEPRECATED) [Http]
    AzureDevopsDSN
    Azure DevOps
    Personal Access Token (PAT) Fill-in the parameter...
    Organization name or Id for url Fill-in the parameter...
    AuthScheme Bearer
    AuthHeader Authorization
    (On-Premises) Personal Access Token (PAT) (DEPRECATED)
    **DEPRECATED:** On-premises PAT method is legacy; consider Azure App Credentials if your server supports Azure AD apps. To connect to Azure DevOps On-Premises Server using a Personal Access Token (PAT), you must first create a valid PAT:
    1. Start by navigating to your on-premises Azure DevOps Server URL.
      NOTE: The screenshots shown below are from the cloud version, so your interface may look slightly different depending on which on-premises Azure DevOps Server version you’re using — however, the overall concepts and steps are very similar between the cloud and on-premises editions.
    2. Now open any project and capture Collection Name from the URL. For example if your URL is
      https://tfs.mycompany.local/tfs/MyCollection/MyProject/
      then your collection name is MyCollection usually after /tfs/. Copy this collection name and later we will enter on Connection UI.
    5. Continue by...
      • naming your token
    13. Done!
    1. Set Authentication Type to (On-Premises) Personal Access Token (PAT) (DEPRECATED) [Http]
    AzureDevopsDSN
    Azure DevOps
    Collection name (e.g. MyCollection) Fill-in the parameter...
    AuthScheme Bearer
    ZappySys API Driver - Azure DevOps
    Read and write Azure DevOps (Cloud or On-Premises) data effortlessly. Integrate, manage, and automate work items, projects, and teams — almost no coding required.
    AzureDevopsDSN
  8. Then simply select the Projects table and Insert operation.
    Projects
    Insert
    Project Name Select the value from the dropdown
    Project Abbreviation Select the value from the dropdown
    Project Description Select the value from the dropdown
    Source Control Type Select the value from the dropdown
    Template Type Id Select the value from the dropdown
    Visibility private
    INSERT INTO Projects (Name, Abbreviation, Description, SourceControlType, Visibility)
    VALUES
    ('My New Project', 'MNP',
    'The system we use for implementing point-of-service walk-in payment systems.',
    'Git', 'private')
    AzureDevopsDSN
    VALUES
    'Git', 'private')
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Azure DevOps API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Azure DevOps servers).
Azure DevOps SQL query examples
Create project
Creates a new project in the organization. Supply name, abbreviation, description, source control type (Git or Tfvc), and visibility (private or public). The project is created asynchronously; poll or refresh to see it in the list. Requires appropriate organization permissions.
VALUES
'Git', 'private')
add_project endpoint belongs to Projects table(s), and can therefore be used via those table(s).
Create project in Alteryx via SQL view
  6. Once the ODBC window opens, click Connect Asset and select your AzureDevopsDSN DSN from the list.
Azure DevOps Connector actions
Need another use case? Pick the next Azure DevOps action in Alteryx below.
You now know how to create project in Alteryx without writing complex code. Azure DevOps ODBC Driver handled pagination and authentication automatically.
